Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Why is there a limit on no of widgets, based on no of handles?
Why is there a limit on no of widgets, based on no of handles? [message #714721] Thu, 11 August 2011 07:29 Go to next message
Vijay Raj
What is the underlying reson for having limited no of handles for widgets?
why is it not only dependend on the amount of memory available?
which resource is captured,when u use up a handle by creating a widget?
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
[Updated on: Fri, 12 August 2011 00:16]
Report message to a moderator
(no subject) [message #714757 is a reply to message #714721] Thu, 11 August 2011 08:51 Go to previous messageGo to next message
Eclipse User
Originally posted by:
widgets?
Because this is an OS-specific property.
It is a very persistent misunderstanding that "resources" and "memory
resources" are not the very same thing. Would you also expect that the
number of open files depends on the available memory? If yes: This is
another misunderstanding, even though the available memory is of-course
a *further* limitation.
I don't understand this question. But for feedback reasons it makes
sense to ask, why you need to know this? You should always ensure that
non-Java-memory are properly released, otherwise you will have severe
problems.
HTH & Greetings from Bremen,
Daniel Krügler
Re: (no subject) [message #715002 is a reply to message #714757] Thu, 11 August 2011 23:58 Go to previous messageGo to next message
Vijay Raj
We have a large application with lots of views and multipage editors and we encounter out of handles a lot of time(note:all font,image,color etc resources have been checked for and optimized)
The reason is,there are simply more no of controls and there is no solution for this apart from reducing the no of controls even if i improve my hardware.
So i was wondering,even if handles is a OS limitation,what exactly is it? is it a memory address?which due to OS type(32bit/64bit) will be limited to int max or long max times? or is it something else...
what if i have to increase this no of handles?
With Regards,
Vijay
Vijay
Re: (no subject) [message #715228 is a reply to message #715002] Fri, 12 August 2011 16:36 Go to previous messageGo to next message
Grant Gayed is currently offline Grant Gayed
Sometimes SWT throws a No More Handles error when it doesn't know what
caused a failure, but this does not necessarily mean that the pool of OS
handles has been exhausted (unless you're on Windows 98 or earlier). Is
there a specific scenario where you see this error happen? Or does it
seem random?
Grant
Re: (no subject) [message #715239 is a reply to message #715228] Fri, 12 August 2011 17:22 Go to previous messageGo to next message
Vijay Raj
Yes it comes up in a specific scenario only,like we have a multipage editor with 15 pages,with each page having many widgets.
If this editor is opened more then 13 times out of handles is thrown.
this can be again reproduced by just opening 10 multipage editors and some more other views..
Vijay
Re: (no subject) [message #716114 is a reply to message #715239] Tue, 16 August 2011 09:32 Go to previous messageGo to next message
Do the multi-page editors contain many OleClientSite controls (the
Browser is an example of one of these on win32)? I know of a case where
Browser creation was failing with a No More Handles exception after ~160
simultaneously-open instances, because each instance creates a temporary
working file, and some OS limit was being reached (not exactly sure
which limit). Could this be what you're seeing? Or do your 15-page
editors just contain simple controls like Buttons, Texts, etc?
Grant
Re: (no subject) [message #716681 is a reply to message #716114] Thu, 18 August 2011 00:46 Go to previous messageGo to next message
Vijay Raj
The editor contains only standard controls....
(although browser issue was new info,thanks Grant for this,is there any issue logged for the same)
apart from coding malpractices,lets suppose say there is a genuine need for more controls,
I was wondering given that there is a OS limit on handles ,what are the ways to increase it?
i know swing can be used to work around this problem since there are many controls there,which are rendered instead of using the underlying controls..but then again performance overheads creep up there..
Vijay
Re: (no subject) [message #716787 is a reply to message #716681] Thu, 18 August 2011 09:25 Go to previous messageGo to next message
There isn't a bugzilla report regarding the OleClientSite thing I
mentioned, it's just something I was shown internally.
I don't think there's a way to increase the number of native handles
available, but unless you're on a very old Windows release, the upper
limit on handles is quite high and should not realistically be hit, even
by a big/complex app. I wonder if you're actually running into another
problem (eg.- out of memory) and SWT is throwing a NO_MORE_HANDLES
exception because a native call that should never fail is failing as a
result.
This may seem like a disconnected question, but is your app being
launched by pointing at a JRE's java executable (java.exe/javaw.exe), or
by pointing at its jvm.dll? And if you aren't specifying a "-vm"
argument at launch time then see if your app's .ini file is (eg.-
eclipse.ini). I ask because in the case with too many Browser instances
this actually proved to make a big difference; specifying -vm to point
at java.exe/javaw.exe launches a separate process, which avoids these
NO_MORE_HANDLES errors for much longer.
Grant
> for more controls,
Re: (no subject) [message #717028 is a reply to message #716787] Fri, 19 August 2011 01:52 Go to previous messageGo to next message
Vijay Raj
Its a plain RCP application with program arguments and vmarguments,
the -vm argument is not there, so will try it with that and get back to you with the results..(although there are no browser or OLE instances in my scenario but still)
But i thought a standalone RCP application or for that matter any java application starts in its own process right?,so i am not clear what you are pointing to.
Thanks Grant
Vijay
Re: (no subject) [message #718505 is a reply to message #717028] Wed, 24 August 2011 10:03 Go to previous messageGo to next message
The eclipse launcher changed at some point to load the JRE into the
launcher's process by default. As a result if you look at the Task
Manager you'll see a process such as eclipse.exe, but not an
accompanying javaw.exe. When you launch an app from a running eclipse
then javaw.exe appears in the Task Manager because the JRE is simply
launched in a new process. There's not an obvious reason why these two
scenarios would cause different behaviours, but the Browsers case did
demonstrate this happening. The cause has not been determined yet.
Grant
> are pointing to.
> Thanks Grant
Re: (no subject) [message #720984 is a reply to message #718505] Wed, 31 August 2011 11:17 Go to previous message
FWIW the Eclipse bug, including the cause of this difference, is in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=356354 .
Grant
> Grant
>> are pointing to.
>> Thanks Grant
Previous Topic:Bad text alignment for Label
Next Topic:enable overwrite in text widget
Current Time: Sat May 25 22:22:07 EDT 2013
Powered by FUDForum. Page generated in 0.07036 seconds
