Hi all,
I have a very simple web application using eclipselink to generate and populate one table. It's populated with a @PostConstruct method. All works fine while I have the one property defined in my persistence.xml:
<property name="eclipselink.ddl-generation" value="drop-and-create-tables" />
The moment I add the following properties, the table is not created let alone populated:
<property name="eclipselink.ddl-generation.output-mode" value="both" />
<property name="eclipselink.application-location" value="/home/andy/scripts/musson-generated" />
<property name="eclipselink.create-ddl-jdbc-file-name" value="create.sql" />
<property name="eclipselink.drop-ddl-jdbc-file-name" value="drop.sql" />
It appears to fail at the @PostConstruct method saying the table does not exist. However, the create and drop DDL scripts are created just fine.
Any ideas on the subject? It's taken me ages to realise that this was the problem.
Cheers!
[Updated on: Thu, 25 August 2011 09:31]
Report message to a moderator
