| Target Definition for all platforms with missing dependencies [message #720230] |
Tue, 30 August 2011 03:44 |
Dominik Schadow Messages: 15 Registered: July 2009 |
Junior Member |
I'm using Eclipse Indigo and a target definition to build a RCP for multiple platforms. This is my target file:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.6"?>
<target name="RCP">
<locations>
<location includeAllPlatforms="true" includeMode="slicer" includeSource="false" type="InstallableUnit">
<unit id="org.eclipse.babel.nls_eclipse_de.feature.group" version="0.0.0"/>
<repository location="http://download.eclipse.org/technology/babel/update-site/R0.9.0/indigo"/>
</location>
<unit id="org.eclipse.equinox.p2.user.ui.source.feature.group" version="0.0.0"/>
<unit id="org.eclipse.rcp.sdk.id" version="0.0.0"/>
<unit id="org.eclipse.sdk.ide" version="0.0.0"/>
<unit id="org.eclipse.gef.sdk.feature.group" version="0.0.0"/>
<repository location="http://download.eclipse.org/releases/indigo"/>
</location>
</locations>
</target>
The includeAllPlatforms=true is causing some trouble. I have activated this via the edit content wizard with the include all environments options.
Now opening the target file shows me several warnings like "Unable to satisfy dependency from org.eclipse.rcp.configuration.feature.group 1.0.0.I20110613-1736 to org.eclipse.rcp.configuration_rouut.carbon.macosx.ppc [1.0.0.I20110613.1736]". Every warning contains some plug-in/fragment from another OS (but not Windows on which I'm working at the moment). I need to support Linux, OS X and Windows.
As a workaround, I can add a local directory containing the Eclipse delta pack. Unfortunately, this doesn't work with Eclipse Tycho, since directories are not supported there.
The target definition itself is fine for the active platform. It's working on Windows and OS X, but only for the OS currently used. How can I solve this? Any hint is welcome.
Thanks, Dominik
Re-posted my question in the PDE forum.
[Updated on: Tue, 30 August 2011 08:13] Report message to a moderator
FUDForum. Page generated in 0.76101 seconds
