Home » Eclipse Projects » Standard Widget Toolkit (SWT) » huge polyline performance(best practices to plot a huge number of lines)
| huge polyline performance [message #719461] |
Sat, 27 August 2011 06:17  |
andzsinszan Messages: 32 Registered: August 2011 |
Member |
I need to plot a sound file with many-many lines (for example, 30,000 lines for a 3sec phrase). I try to do the same thing I did previously in swing(awt).
- wav -> int []
- g2.scale # to fit into the client area
- g2.translate... #
- draw(int [])
In Swing, painting is pretty fast. I tried similar approach with SWT. The code works, but it is much slower (30k data points need 3sec to draw on AMD 945, onboard chip). Here are the steps.
- wav -> int[]
- new Transform(Display.getCurrent());
- transform.translate(...
- transform. scale(...
- e.gc.drawPolyline(int [])
In both cases the code is in the paint listener (Swing:paintComponent; SWT:PaintListener).
Is there better ways to plot a large number of connected dots - say, as in a sound file?
Any help is appreciated.
| (no subject) [message #719601 is a reply to message #719475] |
Sun, 28 August 2011 00:03   |
Member |
Tom,
Thanks for the advice.
I set double buffered (see code below). Paint duration is almost the same.
Time readings (repaint times) after resize events:
SWT (with setting linewidth) 2700ms
SWT (w/o setting linewidth) 790-830ms
AWT 2-20ms
I attached screenshots with and without setting linewidth.
Below is the code for reference.
public class WavPanel extends Composite{
public WavPanel(Composite parent){
super(parent, SWT.NONE);
this.setLayout(new FillLayout());
Canvas canvas = new Canvas(this, SWT.NONE|SWT.DOUBLE_BUFFERED);
canvas.addPaintListener(paintListener);
PaintListener paintListener = new PaintListener() {
public void paintControl(PaintEvent e) {
long t0 = System.nanoTime();
e.gc.setAdvanced(true);
// e.gc.setLineWidth(20); // faster if commented out
Transform transform = new Transform(Display.getCurrent());
transform.translate(...);
transform.scale(...);
e.gc.setTransform(transform);
e.gc.drawPolyline(waveCoordinates); // waveCoordinates.length= ~60,000
transform.dispose();
e.gc.setTransform(null);
long t1 = System.nanoTime();
MB5!.1PT*&@H````-24A$4@``!,T```%;"`(```!)3^Y6`````7-21T(`KLX<
MZ0````9B2T=$`/\`_P#_H+VGDP````EP2%ES```+$P``"Q,!`)J<&`````=T
M24U%!]L('`,?ZUO71L?>JZ[6"P:P>+.2W_G\-;A![__@P$`
M````````````5,9?_X>_OCR__)P>"((C'
M,<8(``````````!@^TBF23$O*A^5_4RR"
M5A`$1#(GHPGF%0``````````X&I(9IPDT^0;KWRCXO'?_OYO7Q2+;K^_]NEG7*=;+!9%42R*1;$HBJ)X^]&C__O?_S^0#```````
M````@.4PG\]?_]KK'_CN#W3=]^CU/_]7C#LS]6/P<```````````#JHC_L+XJJW*I_T#?9W'K.4#G6M3OH
M6AGE-WFFR1,;C<;O_\'_E::IZXR-1B-JMW_\[_Y$FF6@F0```````````$N#
MG7QU\QD;C0;1,76&5_Y>>(0B"\>7XY.V3=J_]W/N>"X+@_.0\
MF23/_V?/?_O?^O977G_%/(/FF>IAYO-Y$`1Q'#]\^%#=4+/9;(;-9J,9-()G
MGWTV"((LS9#;"0``````````L`+1#);CF4'CG9\89_CL__!9ZR\^\X\_\ZZK
M&&<@TCB^''_\AS]^Y_:=W_C<;YSWSH,@.'G>A\='!T
MH,^@>>:3_Z]#_\]&]^]I=5J#0^'Z@R:9RJ>2/0R2],\SX,@:#:;K5:KT6@TFXWP
MF_\V#03```````````@*5Y9K`LSPS>B7JUG>$S__@SZGAR<KZ+
M9SK.$$;AO_J?_M5H//JU_^;7/O/ISS2;S5NW;YV>GG>X,^O_<UKEF/,,P2+(`CN/G,W"((O_LD7_]E_]\_^
MR:_]DX.#@_.S\\_^QF=O/WOSJ=#I%2]7,```````````"@!EM\)V9UEL_J_I#HF.L,
MUA/*+\TSS&=S_O=/__1//_K1CQ[=.OK4+W^*#BOF!?W)/(/FF8I]4GYFEF6+
M15`4BS3-XDF<SW(^;_]W=\]'H]&%R/P3```````````@.51OUKL-],IR^)FK92URAFR)`N"8#:;
M?>`#'_BC/_JCCWWL8U$[^L5?_,67/_WRO_@?_T6CV1@<#/09%,^TU@$B1LND
MEM!NM^_>?>IK7_O:)S[Y"__^C^,,?_L,__,,?^9$?Z;0[/_=?_=SSSS__
M^NNO#X8#=0;-,ZU]38;#`_WPC<;=NT\]=?>I][__N_S59_@S!(@B"WJ`7!,%L-@O#,(JB[__^
MW_N]'_^)'W_E:Z]\_"<__OCD,;/(JGU-TBQ;+!;_X)?^H>NV_K?__7^]
M?_^-RV1\,;F$3````````````*Q&--]A9L4B"(+GGG_.<^R,__=-Q&K_XX1>+>1&VPG>=0?%,Y9P=
MC<>?^_QGBZ(HBF*Q6-"_[_
M@>K6\ADTSU3L\ZNOOXJ9!@``````````V`[FL_E+W_?2E_[5/_\G_^
MEY_XQ">*HIB.IQ_Z_@_Q&33/7*"2#P``````````P!4A2^^3]^
MN>)/7OS>%^?S>9\,?_7#%X^>S>9^\I_^M__T.S[P'>U.
MNQ$TPC!LMII%\2U_)GUH?.I3GGW,*````````````,"8S6:__6O
M?O7L]V>_YGN_YY"<_^2N_\BN?__SG+R\O7W_^<M_
M^9=_Z5'MH,D!P*Y@.!Q>^V?L=#H>VCD:C?AS4100"0``]AU^XQH``,!>X&,?
M^]@O_,(O?/"#'_S8QS[VXHLO?O[SGS\X./CPAS_\9W_V9TF2N'__NCH*`B"
MEU]^^1.?^,07OO"%+W_YRQ__^,<]OP7/!`!@@5M?^,(7?O(G?_*C'_UHO]\'SP0`
MX`J0IJGGK]UN%T,$`,`UQG0Z14DS``#V%V$8#@8#64BVT^G\T`_]T$<^\I$@
M"/K]?A1%X)D``.P3)I,)E#,``/8=2#4'`&#?(4DF_;?3Z:B*&U:@#A``7!F/
MPB!XL%@L,`@``.PB/TS`1V"9Z<$P``````P#,!`+@R(&8,V%]423X!`!,(5P$```#/!`!@
MJ_`T\PV"(`Q##!&PFXCC&(,`5,1X/,8@````@&<"P*-K_XPJ75-E,7FB:F_"X`!7!>FKM'8[]/OA`0``
M````SP2`W<6UU&65_;Y6^5DH^L!V(',OK8UM8>8``````/!,``"N`U2VJM7+
M!`!K@95;`@``````G@D`P'6#:EV(:I_`YB#CMR7GE&'>JJ(5``````#@F0``
M7!G6%>_::K4PF,"6.6>SB5<D<,VW5@```/!,``#V$OZ&F=71HCIVF*
M>=_'_7-=]!4````\$P"NU]JJM]NN(SW6>D0S`IL##!S`3DG1Y>5E
MZ3%YGF/,`0``SP0`X)MPI80!A/%X[/H3NE``F\,-]&<":\>M62=XF8#MP&4`ND0=A+Z%P+H@A<VUE;G";M'<%0``
M\$P```"GSK1<_)3*F>KCS9RU0!0
M:RR'*]E&7,YS%VO=YLMEC3TY49H(`,`S`0!8#Y9.0;R6GH1U6;)=?LO5#?SH
M8P$`P'JQH<U\Z9?+&CDP````>"8`0#79":CJNSOH+4%9EVL/JSMEC>X:`%#9
MDDML="Z!1*=E``#`,P$`^":N4Y^]M6/M-O+5O9&(Z;KVD!H\6W.6K@N-@M)`
MZ4:T!,]T&;SJ;G&>+L3K0MT<9NRQ``">"0#`>H"2?=N$-/8CT`NP@LO>)$G"
M@=Q+1W3?A$)!0%TH*K7&O:AN0^8M%-VI&P,"VRL`@&<"`+`IW.0,P&T6KH`V
M`UC!SJ4\SU<G`-<9_V
M5R_'!K4+:+5:UDW)91"16Y_+.E#%E;J*_!2A8@UN25D&P``\$P`
M`/8;C4:CAQGOW:\HR@J3<>M%2);)1E;WLGEY>4N#`ZHQ8[`91JK$M?JXIFN
M0!I@*@5(BOU[X.#@[7PTBU@N5J79>3&YW+Y^F*NU''PVP*
M``!X)@``5X^=JKXKU6O^O/;^%L`NH#3_5CK/:W'+&UM0&A:9U7'KUJUM7JYN
MOH:4;4]T"=)`````SP2`'<*-K:ZA-!+EL?0,RQ+]XJ5S";Z7&XY:66JUZIK<
M*"4;F9P>'!\?U_V)AE/U^G_TP?D_4%=;_!+:#T6B$YC=+KRET!E98W9@E'>FR`-6F@RP\='<3
M0,P(`(!G`@"P56RSA\=>>Y+MK#G24U4B:I%FC0`@&<"
M`+!9H$]`=4ACOV0"I?^K26^4QM?:[(<&DTJ<LS=]^V@@KA``">"0"`>_G=O-8F'FULN4PP
MJ3Q)MXS5(<#N*2M37<7>#^P:UI@`U9F8J]#K&E\H.S5KV%$!``#/!(!-
M`:DLU;&Y_MV29S*+D)XH#J;E>$BTH;^NL+K*I39\)<6B=F2CR+),LI1KV5UI
M0]A.A5@E)VL)%MWR7K>T:S1`Q2```,\$`$"BNJ*F7O85TPBO$XZ/CVMQ@^J0
M@UE1RT&VSW6"-;JUV^VR=\CE=:E%'E9T5>T(Y&+Q1/S>P`T*#'DM,(6J>CHK
M.NL``'@F``#?0O40)J6D+M$O>_?A=]IXU!U/K*-D\JXS+&&POZK^=<`F8%5D
MHR@J57"5Y/BM#QMUMER)E]7S1`BI]6-ST1E7LE]53^M0>V9*)WC:F-3M^QP
M`'8$VP_XE%Y3J617":K?\K;@*5F4)(E4Y:'6*WB")N2^I\9-^B&7V)&D:*VE
M`_/J'5DV&MH*IR4`@&<"`+`&(!%ETY`.!Y27N-Y8BPJ^-"2UD'ZA*JV,MNQ%
M]%.=IYYZ:HV$Y)K!$[GJ2H)0U+2BE/*K09GMSL@%>PGR@?E):S7!<D).YU.Z<8UF\U*
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M=24U`0R9KB8Y)V=(UBVQD^?Y<@)0)71PL64/:D41RU9I2G>189"N<YK=P$NUPU(%$=FV^PX7.ZJX
M)*4<5C<8N<2FU/.3)`DSO2OW^:C88@&*U*4UPO7'6A*B8B2N&W^CQ=/5V7V&;K
MFDT1)0L`X)D``&P*15%8_1A7Q9VN$&LIWE#%NH^0JAL(Z=]8;V*MY`#RLU3N
M5XE9V$1X^7+\W,,>51S!#4P'N))I\I`TR?Q9X.,XYH4@5X2R=<K3RE1AZS.J
M5Y6K.R@```!X)@!<`5Q^C)N&I6/M7(WO7<>L'3<YR79?(.=H7<)`EA%2Z$WI
ME6RVKO)M#294"OV&'$'R*K=NW9)_JEZ=""MB:W!9UHZ.CLPOY0P.!@.7:UV:
M_.0QUEI9"+T!```\$P"`:XLJSJ+J#J4E\H76;BF`3V#MD*Q/JLNE7G2/&BV9
MGIRRBXN+%>]6GIF]B$HJ-M2\03ZO8K8>E]W:LP3W'179U^J%A57JIE7@E[XZ
M63&Q@UO6G<N7.GE-&M:RZ62]Q5+(XC44NE
M:VNU7CVM7U!VQ2\V+E.4)Q19_40:+S919DD*+7/4+,NL6]_J5:\\0+-B``#/
M!```/'/O,1Z/*U("R49,9K+VJB>U*O$"5;#]"J@R#7@\'EL)K=3"%8OSUY79
MFBZ.8E=5%:9F<4#.Z\QI&G`51*VED0M@2IGEF2/C^]VNZY`:%=,!PO\9#+A
M<YI>(*Y8/5EQ,IFP3F\-7`P<(9=77CPL21))W95E9&NAO%<+3\+J=HHV5915
M:T*RRY:1)(DTFLC#-E%-S?3TKJ5R%9/SMV[=TTBNCGX_7(NXJ3NC>_Y
M>L/C>3L_/W?M/^N->:Y"J$J9VWP^YTIIZH1\MTHPEB-RZ_7#+U$#"2D)``">
M"0#7%A4='8A5JXXEE&^K;T%2B"MQ5")W=Z=@M374LBR,QV/V\C4:#1=_J^XC
MVLZVL!;KB6J(<A.$9#@<>EJ`2*:W7E_T6L+XI]-IZ7D4J:MXW8T&>`\&`^NR
M\HPP4A(``#P3`&X<%,>83J>HA;`<I'KGLG9;Q[9Z*Q'6)MDTOHJ-G$DO9GRG
ML(JM@0DA"X;'P"1UXE([E!3IW;>*=<5
M=<TB%=WU``"`9P+`]8'),5#;?76X5(H5>_VQ19SUQ2441_Z)U2T`W^;NH'KG
M50:GS$FRZFH*(AE(:5JC%%W>(M8;"NAQ^%3W!<%HHOB/K!>4
MT;S@F6O'TO[)NK5/Y%*53JTJ0FLJP54XR7K]8Y*UJONI+OE+D/.]0/5R/JN,
M@,GG*S)\M;.QV8)W6GG_L@;5BF1,FA44IU46A^TXNCU7V8XS&0``\$P`V!54
M>?-=RP)"_HYS'GU%Y62ZE#^I\9?Z?*IKD&LINLB*(P^"53>"7VA=*(VO&PP&
M:TEUDU+]^/'C6HS1E($JF\/F0@%5K9?JD;J;*$RZ"U#5?3S;LI*E@X.#ZBS.
MW*PJ%MTI-4=6W$]</$UNO)YGEW]:5Z'=6AF_:/H*`."9``!\2P'U,R&A"_"Q6!\B3)T\PW6N!=;*D(#6;S77IQ"0AD\ED.]X;
MUF:T*KU=IF:JYTI<K/'DXK_#(VI!5W+14(JT@Q6UG>S?<WK]:HX$JM'
M=JR]T$!=.00O!0#P3```2G33:PE/E9&--F%3:M827LHE*@.9^M:*W5:`ZKJ[
MG"_7RF)Y4#8@IITT-4='1VF:DGQ6#URQ4NA/G
M\^!Z8KP=)#7!7%5;TZ5Q_YBD=6>?6H8?'L6NOUN);69RZ]50``
MP#,!X(8"14<9ZXTK9@7.Q0^98W0ZG=53M4`ZE*2:9#ZGIZ?+G62OO4:R9D^>Y]*AK9S;#QX\
MD$?*'U9<Z6H+DI/NB72P1
M^A:KZ.F%'Q(`P#,!`%@25C)S0WJ=KQ=5XK)8@7.5TV".$461V5&@;J2KWX+.
M?2BV6BU)1ZO$=+CL
M(,IS6\HS35&Q^GAA=04`\$P``):$4DKH17O]?%F*2FTB&K:NYW@M75A,K*7!8-T&C%<+18U4
M-*:<6441;]^^+?\KNYXHWZ9LRW%X>+C>J7FKO@``(`!)1$%4V33%DN2M>@BT
M?$;K?-EJ2?:A2J[I99[Q?2D
M6;UB30M6W"\O+RL2C<^S+?!<_/?NU='G8119%<
MJLHIK=R/DEO>O7M7_DF2-ZMG6XJ-E0MYIM5U_U:30>G>LL3FXY_NBLT_UPC/
M(_@31.$U!0#P3`#88]0R6B-F<D4<'Q^OBWY8:>'2-2VLJ9B0@>W#-1&>\$6/
M@8#DH<J4,=.8S^?2%U2]M*R'S:XQDTU%'%0W#.V7']48JNEB!TN,E[;PV+7^+HI##;CH;I9`H1J=L
M"H\>/7(=*6?3ZL]<2S->%]]K-!HR9X$W'N*N:-%4:AAV9RL>FX;
M(2$``)X)`(`3&TJ^NEK4>O=O(3VU;BH:Z6VF1EB19\H?FO-K5>-N0C^;2I>,B*1=3XK2?"01E*8_(JF)Z#1_T1H8;(U
M2$97JG-+CM?M=M7\\JGR/$_3E"@*<;!NM\O*<1S'S%AZO9[53>TADWY-79WM
M2CR-GC#1W8<B@7(\U6K4;R-8PA/H.B$)*FTR;%^3TU3%6":-"XI(
M+<MS;>5"76]WO@57\KK-2(```">
M"0`;A+4CXDV&/\A0:?R>^+VKJHZC**B50)H<F'47*X-EUF%5S3>1M74S4;W$
MSA*B6T5$Y?RZSE;JBK1F_15%L48CU`TLA2+CJ*7GN92WO_#""_*_,O]\.!Q*
M&2@MC"3W#1*#P6`@?\6Y
M=4#=!%&F.LJ*P31@C7F\FZO:LIM0IISY?.YQXJG!4;]UF<94+\VUO"SDM9@[
M%47A,E5(MZ&DB\0)JS##+,NLMC`SYD*-@WPTZ\ZV=$%:EZPNG8"-5S8`@&<"
MP-Y@1=.I5&(N+R^O966@?8%T7;+&9E6/6/5A:F'E`'[9>.NMMS#FZ\6Z\KND
MRXAGUC0NJ,NMTMHASW,7>6!&Q.)T5:[^QX\?JI/&_JMZMGQI*<
M5(G,=TF4HKXL#Z;\TY%^@9$QWDL;O^1>9WVTI:-5UQ
MQU9G&(_'I2'H2!8``/!,``#*834`6V.KJI1G-,N'U60YHDR9T[=V@J*^KZ;+`W6:M5:6-YL,I`K8:K0)5Y\8#)I&DA,MU!RJ*A
MM&?B#Z2R^R=1<@FY8\CX!3XY"97U6?B>U\M^9;REQ_6GI'>/>*8_3MCO
M/97_Y38VU;>LY3QR15'4)6.\]RKQD'LR_<G,V%PE?]+<\TOOW!JY4S=!VK7H
MKH&Y%@#`,P$`<*(Z.8RBR/^"!PE9+Z(H4D-:D5O*:"MV82E3,OJ$7PA]G<Q6<WSG*WI_"7K;5:>L`D/,%`%JW0'D<LVRS(EYW7SW"3/
MI!5D5BM)TY1%:SLR<WY^+O];U]VT.0"4TKN_96G-Q&FY(70Z';G,S0"'-9;V
ME;":F3Q.=9Z+7J]'G]7N)-\^69:I9^232`%S9?9*:FW.>ZO56GOYG.H)R>O%
M'IE+```\$P"`Y4%O;MFG>Q/L:\OPTV:/!VF]?3ZL7F+)%<,P]"CK9N05Z?U$
M98E4!'7,_.;]//744YOF##<!<J:D?ES7`Y-E&5,]GU<>T\;N"
MF95'HJ+>>?OV;;-$Y(8&ZJ9!:JMRD*W#Z]>&^:^LS9M6GGZ_SU'03!62).%5
MS"=9CI6UV^TJO2B6\`6Y+%9^=5]*>*_7NRH?5%U4)_E!$)R=G<EJKHK8RR5?
MW7B1IBGO(58WIKGM^R?"/_)^UNJ2)6E3*"T$8.YULD)2:2"WN1RVF5)1?1,`
M```\$P!V'=7K$"CESWSU"HW<*I1&D9G._
M=1$8CX]]L5BPD)"5H6I%>);5:#22TV%N
M.\O%RGHL(%78KW]2*C(T__;%$DN>3%.<)I/)>#RNNR-=;94@``#`,P'@VL(T
M+;L4WRB*2NMJ7(-8R@VU7J@+5L4D7J]BC)@KBFYR6M/YOSGFR276K$!W30``SP2`
M_88KH"0-#-XRY+RH.U?N337=:GBKQX@RF3<W!WE.
MZ_31F/MW%5<$N)_PUVW$Q1N@N:#NWKWK$BKU4%$4F=,,N$2+1
M;#9GLYDKD5B98'8J!"--4T^CCJ.C(\^=^)YE@A)D`_%Q$9&W4N^NMP(>'Q$KFA>=:%=;KDDNZ&:DZB6K9\F/??<<]4Y
M9T6RK4:X5K%6E?I;:W5TNUTY+/Q7:Q`*/1U?KB@*UXR7Q@Z8.Z%5_-9E5/6_
M-&'7`P#P3`#8#U37M.C=9CW>:B!GA?)Z^S.)\I7Z)#U$5(Y>E>DH;5CJ`FF0
MI)EY]"KIZOO4@YXCSSHIY+C8QGNY`6(CJ_RDLD
M\3"3M^4N,9O-^'ZJ5":3ST5B4+W,E:=IC<G->KV>O,\XCB4=??KIIZMS]8IL
M<%U)(GY/+_IG`@!X)@#L!TKKQZIWF_7])]_0S)18X=BOS&8WKV4I^M
MAY))56\+O49))>4I8P4QBJ(XCDW^Z6*DU!\%*VAU5!E&CQ)\?'QLZKA5")6D
M!/1;Q3/G\WDM8F;MB$-?TIIJM5K6$R[',ZV4U80K_777]AD3BDQZ-ADUJNHQ
M*T:4T&'6,F\\AG3,>#R6]Y8D"4\]$A
M<BC1>:3K7K)<?^,-J\E#ECLFM;LH"B(_)F_G):S&2IG`MAS^?7EYN339#L-0
M^@!51(F'>)<&B%K%@Z9/45":09(<Z2=,TW0\'N=Y7K$6\=*,M-/IT'5IUY)/
M+6]5RC;O9G3P\?&Q:]+K"H/'6K2NID2NZ2ZU4````)X)`'O#(>OZ)_<NNG*)
MJ"0S_$QJTC(@K0JI\$"R/JMBR@J624C4Q+DT3J::-''6H#O2([$B-J<URHF6
MBG@55ND)WAN/Q_+,5F7:10^J.`/Y6>;SN?E<+NV_XHJ3/S'%FY,_26V6)V-<K2-CW:YI*SL_/Y="0AR/=A4IEEF6F68%#^H.
MNSR^2IBN7`Z3R82>ET5N7;F.2VSL4115K\E4BYFCC!``@&<"P$S`*5B)9\V/%D6^,--I[]^XI
M_9((QG0Z/3@XR++,.G&D&+WQQAO5N0?@A^1U7,Y7#JRI-4I.4L5;(M5Q5Q46
MEAR7]B;0.ZSV;8VZ=!2GJW6YW.1=ZZ:Z[=%H9*K^9(9GSD_S
M9;7N\Q59[?B)(#D:BYMO>9(!L>3XL,;Z99<SEV
M:*ZE=8-4;3G[,K35-*`$[Q2>96%K-ILL[?/Y/$F2Q6+1[78EJ:@8,V6,Z+F5Y%266!)37==`L.FAVZW
MRZN>II+`_/X-OE/I6;=?>299NDC>MXD
M2123;+5:K`\UFTU_B&#U9"%2!_EL-$'T;ZO5LFI"-*=F+T%Z%OJOJ:&2VW,V
MFW6[79Y3[I2@J@H!2^OW+HYGA?P3N18/#P^M[AU>:%$467MCDE+.M%#Q,>()
MLL2QJ<$S'U9BL'01T24X29S:[]0=<*ZY&1%J`1IM25V
M.AUY>X/!0$OM]?['B;K?;;K=9%$EC5G=57&3=CH=:>_@_22.
M8_YY*6GT\.1:#&H\'G-K$Y),T\TN`S>L;Z5'CQ[)9\GSW-S&3T]/S7NV/F;%
M^_?34?]?Y_-Y:3@N\AT``#P3`*X,Q#&LE3.D)3NH5BK0FNZUA:KWFR8&-`Y<
M=)&U?*7_3:=3IF&DW`?O#HFL6%"'A]TD=2[=A55&JZ>+."J?K=_OR\.HN5RS
MV;3V2.`K0E]9+SQJ*$6HTI31S"Z16L;3/9_/\SQ728QT0BFB<GXE`Y&:KA0;
M]HVKN&LK<H!D2ME,!@H1N2OH]/O]\U<0169O&*-KA5AME&5?$89$<P`
MDPVMQ$ZGP_2;)K=6\((U$(;$S)1>)J(>NY7KQ6'=16G0Y$_DRTC&<7@$P"20
M?!(>\VZW:]X`-QR2)ZD8R.,/X?;GEP!Z_M9A+_-^Y<T=J3E)EEQJ&5&>C*"+EAL9D-!J-1B.7:W?U
M)FFL6/O]J*2UJ&GBGY#ZSO\E=4IU2@3;7`72^6"2)=9?^_T^B42C<<FN5JU7PM&)JM]NTX;=:+0K9H%W%L^?[
M&SN9)@\EA]7J])$E<-8=<ACQUO+RN)')<?6HVF]$]LQSR3ZSW+*]+
M/S'O9+F&R:6_*@TP6:*F.@"`9P(`L`Q,XRCI6RO6K)-Y/G7H]U4YI*-:'\6SH;J7KS^9PB
M0CM*:2/16J0Y"=DF\5H-.*_EGHRI]-I%75?
MV8Q<J]+5(\=:[,?DKBS_<1Q;HQL\E-A%'NC2),/<3%*2,7ZTP6"@5O3IZ2G)
MK?I^R_F9YL8B[S_+,CGL_7Y_Z5R#TII,TFQAFK>(D_1Z/1URK&EFOUU-1'OU^GW=(L^4FA:*0V)LQR2RES6;3(\SF#-(]
MF#_Q![(9!P``/!,`M@IZ:ZX8VLHZZW(FVQU'M]M5R+)&2A3'%Y-'4
ME67!9:)BD6BWVWP#<1R3?$H*(0F#)XK/5737KQY!
ML.)T*YXO9YGZQU1D7QY#AA7RS";#,:>`!DI&I:XK#T(:4.1GV@P]2<@5WS*3
MR81&E<9$F>=DZ++,+"TEL5QLN2@*,V+<T]/8M8[\4^8/5>AT.J79N:@0#@#@
MF0!PQ5C.Y<@O2'Y/6Y,#:N%I85:A6J\7DJM/IS.=S>9C4D#J=#FN!2E,D
MM9M#$UD_MHZ8-=+)5=R"E!NZI4ZG0P%OQ!C#,!P.ASP[15&HB:;BHJ2(Y'EN
M#28,PY`[/09+)0H"M8P^2A2EZB^55#D1?$QIC!R))1]&RK?2=%E@DB2ILC-T
M.AT23A)^R3"3)*&2L*Q_>PB>O'G*&9:0PLDWS.M(>M?YGCN=CNQV*T^RHE.N
M+DS'G8IWD,_N=V$I]Y3:$$K]M/*Z\K<TDC2PI@>,MS5%DY;K"6G=.=7Y/9)<
M,6QXL5AXXG2D8'NZ"IE#H7S1\KU`^SE]D"6[)2J:@:JCM&+3ED4=`,`S`0#0
MJ"FM1ULBWYY]_?F>?W6R*X.?)2;705)DO`4F'X,%C\I<F0X,$F"5,TKIF"UVVV:;D5[
M3+;`-UD4A>F!E&TP2"HXX+#?[\OG"L.0^[=(V43U;G"LU45J:%)&3U(@)E4N&J\.Z
MDZRRO<1Q7+T6@'P**W&=O`-U5U9O:A1%/(/T83*9R,1FM3]0`I*Z6)`DK+JQVL&(]G4Y58W13MV!5B3_S3Z;3Z6PV"\.0_B0?<#`8
MT'75X_!]2HUV/!Z'82A=H,J3V>_W4<EP"9L.+T-S/7)9X"B*^*^ER\>OFBLK
MR1(<P+R!/,^98,AS4J<?R5I-WN+Q@$GN9VXO]$VSV211IZU&/IU5LR^*0IZ6
M]OM]3]TFWH%E`'GIZX]_Y5H^15&PK$91Q#NM]951%(7Z7M%15XERSY<N
M@XLZ;6D$./(S`0`\$P"V@;K%?DS/@R1.OE+5I%GL]D2D4EL-IU.J8-BX(BRXU;CRBY@<H#)9.*I
MD;OCDDTO54T[Q2P@OV-EL9I;3K$YLS#LT2Y*<
MGY^K9WSVV6==IY7<+XYCM0KHHH/!0#XLKSA9@LO#P?B>MQS^?7IZZIFCS14E
MZG:*%.V-,HZC+N=I-!KR*N:NTFPVDR1QB2CQ4NO>
M2Z>E`R3QDV6<76FBGD7!W_.FW6@TU.8Y&`RD;9%I:MT2!J4>VM+*R=;4#```
MP#,!X"KIEO7U9JJYH]'(7Z=^/I_O<GZFO^`AX?+R4G7^<.DBTA*?Y@RE/04-K')T\Q"1WBQUQ,%@8/J=N!*/4M/-06;&Q9(F@WA5])VIM:LF
M-Y>7EZ;ST&,?L?H_/>`.HM:3CT8CU>!1FFD"X:12I(57S9;#O_O]OFKM*-U0
MP^'0?S]+>U^C*%+^+KE'>>(1;MVZY?J3BR&&6):FL,IG\X3).P*$*5=
MR-H,AD2(9$#90ZT#SB&FGIVMV^WRG?!)%%4.ZI1)R_/<XY,LG7J/<=.<<0``
MP#,!8"?HEI5GNEZ'_`JGJJ>FKK,CCVR(GY^?FZ*
MMV2>T^F4GXG4S'S-<:UTLQ*PM#K
M]21KNKBX\+"U8+5R.]6;;:KP9MD#21J>Y#2Y6!#]B@2@-+!SB:<K%2>_BUA-
M[F0R.3L2>U*GN]GE7VS)\G2>(ADZM,O9^?`P``G@D`F])QU\A.
MF\TFOV*M07%FI%">Y_M8!(_O679QH-PA3W03E>21RE88AJPG,?4UE1*I-_O!
M]5UH4LQ@2*F.TW])621MK-%H3"83J3Z:&O]@,#"%9]5K=5Q+>.JR2'53
M]??SA]O5#<:34\F?I6KNBACTE`,].#B0MR%EH]?K,8_R;$'6Q^>GZW0Z9M\=
MUL)'HQ%]5H3-M7Q,S5Z)9:F;J!;F\*T-.
MT]0E;_ZE724>!]D-``">"0#;TW%+]:?JF4ND5=32)$CE
M4F&6'EXG<T2C*&JWV[(#"BMPU^ENL]JE84OI]L;<MHGRYLL
MXD*_XA6DGH(C+-2^YQ?")$E6]`*IR\D6HW3_DH3D>>YQGYI1`R:H?7<+#4KH_SV:S-$WE85$4N5XN)N.B_;-4;OU^2\6W%6LU1XF$BM(6U(`W
MFTTRM_'3N01`_E`V(C:73ZU`'I?-SK_PJZ15HPX0`(!G`L#V8-4FI;K@SQ12
M1F+U*JT8F!K'\7*NL!7!&6YU56VS[20K,>J1[]V=FIUH9B:7KCY*6U!EL2B!EN\_29(LRTR&7Q0%EXSF
MKL5TD[)KJW5!T2R]+%8N'OC`(``'@F`*P3KJKT2C'J]_MF=F4?=AEYPRZ.D<>LI_3,YBSV6RYSJA7
MXLK>$4CUFJ9&%@J6E-*JLC-7X?8>'IBR3>>7&BU=A3R-9N<&18?Z_3ZWP6PV
MFZR%\R.P`U]ISY2WJ1R/54BX:],8C\?RZ8;#H;S5@X,#'KTLRXCKJJW)]*1)
MAM;O]Y64UO5:J\?DYB)6//?<<VKBU(;C(;WTI/SXZK;C.!Z/QW)#X`W*8R2Z
MO+SDT3`+1)'@T8#(69#=;I9@GLNA8G-(CU^4]CHR0<IAM]HUZ``:3PI4H9-G
M6<:#3`-K;I.1AG;9MDYJ9K/9S&.+M;[D9#:I4^WC\^#&-1JUPQ#S/51DD
M%1K'GTFM)_V`-`EJ<%_E*O*6.$F)Y]2L1TJ4E8H,M5HM5EPDY59%2I1RYM*P
M:R6P2;7'Q'BN#$D+/ZIO/Y](6TV@TE+8]G4YT.K+;"M^;V@:+
MHI#Y=7$<JYOQ.X"CQ,/@Q#5BM=/BY^
M<+XKJ9#)GBNF`BU5*`7K]U;#_-'1$<]X75?V-=.3>'S(LL`Q>'*BB82H@:IB
M]:`%6X7)*YU>74N:DQX_?JP47R7J2I)5=Q_^TKJ9R&U'"GF695)$BZ(@KQ$/
MA9(*L](U657R/"=?(IW-],'R":7<1E%4RQ!F!N6JR3+;=:B`3P_K\Q`D%ZA3
M4>F^K7*`63B?>>89>6]*-J1%C!^3\RU-LX@KIM>LJ>.B5=4'AZT/E(0I;\;,
M36`#3;O=EC-(P]+O]_GG<@3,K9A&3XHW/:E:AI[(;96OZV'.2Q#OW:GW#@#@
MF0!PXR`K']32DNGMI5ZEUH!/,QPNR[(K::+(S0\DY3/OI-?K24UN.!S2K\(P
MC*)(JHS6T&(ZTN3J4NEAO*P=CK]61Y
M*BE4/(9T?)JFUD%0"ZK3Z:ANM\J.I@9$51137D\=KUY5JCIN
MDB1<>HJZFRIQI>.M(V/6PZL+<H%:_U2:4EMJL;UF^?```)X)`/N$Q6)1*W_#
M[#RFWNBJO4;!-)DIA&=*4S]?M]4C)ZO9/I=#F3D'QVQ0:E1Y'FR(RM=0U=I]-1
MC^#*T369&/G/Y433!RFNZO@J,WAQ<<&W5#%89C:;^0/CKR0#!0#`,P$`L(.T
M!%F>D704TR%6O0(>O^I,RNH*A;(6*=DTH^CW^R(Q.!@,7$]*HLYW(JTS
M%.7.X17L_C4'QS.DG4Y'/G*_WY<473I7F5.ILREKFJ<`K(NDR47A<8Z9;4*[
MW:Z:A==>>TUN5BZ/EHL\NZ(8_+L6Y8*6\A^Z?U>W7H%G%EV
M7<^R;#P>J5?JM6.]PT:C
MP8>98<F!(Y/</)44;RFN@:U$C5H+:9JZ(CM4ZF.5I3V93$I+-1U6#3;KQH)2!JR2+EF_BH)6
M9.$?<T73J+)GM=5JT2RHFXRB:#:;Q7%,CG2Y#=*F:M)4?[$#3TQU:9)_K2H`
M``"`9P+`>F"2$*E)N`RHZGM91\&C<Y@O[':[;9)8;D>V1IA=]63_=;J5*S@=#KE3)?E_>`M_HEW";I5)3/2<??@P0/7UC$>CZWC(PD>7=T<
M!#-KU!1O%>]=%(5D;L/A4.U7:KJ5)W8RF?`!=)Z#@P.7N-GIDDB?0F95G&QE?9)5Y8@5YGA//['0Z)&#F=*B`V"`(3DY.
M%*EN-IOR\8?#H6)3ZK3*GSF93"0I*HK"0QN"=PK;5%^>01`<'Q^K*WI^KDXN
M+3N>;8$/D]'19L=7>6EKDJ'RO\G=3`HPGX>S897!3CT%GY;%;#@<DCCQRZL*
M+WX<&D#5OIB&B$]B
MSJSY^E"S.9_//8H:WQ0+`,P%@#V"J&E3147Y#;U9^;9,&$,<QO^U*
M>VEXX.I5;9;C)X=A19U8G5;>+6O)ZAA7Q7RIKZA7^&0RH?*`KM^2>B1]E>/Q
MN-%H6'4@5N/H,4U=G%5M]2Q6=Z*?KK@P&`R&P^%\/A\,!ORPK-5)U9`U0G5"
M%@;*X>3IX'N6U2Q<>J?+G[FS*49TP;%5.S
MVI8U9H_GI=UN2TGVZZQA&'+L*RTT5^]-J]8819&DRKU>S]J?@VZ);YMF@052
M11Q8G>JF=6DP&"B]7SYUN]WV!*B;WW262*ZC?-4OEDZG4Z2)"2Z-)5R<#AQ_>SLS'S?T6C+UP'?ZF*QD"9+
MZI-,LB0-!S1$M!;,X:(]V9-4(FFJ*985.Y#M"ZY3^7$`/!,`KB'B.#9M\](-
M9555^<5IOK3DV2HR'RM+C./8M/&'86B^=],T-0-B924&5AW,0"REKJGS6#G#
M8K&0YRF*PI\=1!JDTN&DA*>6/Y9RIBE4:>7(_;3786D7-DK?WC\N"I$K4NBD)CPJ5EZ>:5
M(*G*6\Q)K,^EOD_35(JHBILUE[.RLPP&`NO?$TPB
MJO9A=7N2MJGL2IDZRZ/--\]^PE()7*6-AY7<+@W3>DB;%5MP3&;8:K6R+)/)
MZG)"N7168#1PHI!:'D!KXL-H-)*BSG-!/VPVFYU.QVKK(5$Q.#DYD2]"\[7GTHGI;>?1JJN_MZQ*I^P/22_45WL.,I.ON"E@NCR3;F:_BEE6I5V<*EB+D>3>1*I6_"O3.>DM4B)M2@N
MJ=>LE*B&*Y/)A.^9?NXJ09&FJ0H49(V9'T3U/&3E50ZX#&/>47";ML-N,XSZJS.!EN:M]92PXIUELW48ODN*.5@/%ERW.(X=OE[Z?CY?"ZM)/**3SWU%+M,>?"3
M)*%Q[G0ZT^E43@J)'^W#Z@&
M2Y0IE]_950JRF_T/%,P;D+W7Y>5,160VFYG$.,]S]4+M=KO*:Y$DB>*BSS[[
MK!EQQ-_P_9`NSJHDGX0<%ZQM*-W+?/>3(LY/))\W35./.RM)$D^\$(^&U%%8
M5>6AF=9QO=)]T.MV*E,I>G9H&,H=XX'BD=@L5C(SN8R1M2L&J5D
MC)JFN%C']0,]K%*@><2XK*79%,>4V/E\7CI<<BJME@ZY6*00FD$*+D9W='0T
MG\^9PCWUU%-RN=%G94N2FJY:UXO%PM.\GC\?'AZ:#)"IA21L="UZ=I/^*3(F
M?]CM=OF1Z2GXKW1.N8AHF;.0<Z,:4X4D.(UW(
MO_^K4/D@")X\>:)>(K4LC'0_IM.[-J/2C.YK`):-O:XS!X!G`L!^@'0L5\5V!>N+K=%H
M5&E>,A@,Z-UIM;/V^WU3@RR*HF+8;;?;-1GIP<&!4NFL]Z]4Y"B*/*5W69LD
M+<>J2WG>XM8>H5+W4BQ.1;=:7Y8*IA_&>F.D8T519,Z="A>4*AV=7#E>:$S(
M-F_FCLHR,T51R#;K/&5RZI7JR?>?99E\M&O3B]S,I.)'D]2.K0"4?J8>W*?B)U.3,7
MCA<(#2./F!P3.H:8H5+*V^VV_$::=6:SF62\1!M<Q5IX3?$!9)6;3J<R$5=M
M=&F:*B68IB7Q`\MS*,\1QK*:>)(0'3<J/G!TU%WS/)@F7NP0-H-JC_%NW
MJ>)7[P/D@7];6"P6<KM39#N.8][*E'GE]NW;<I1&H]%D,J&J;ZXT2$_HBI)P
MEC?3S>AZRY"TFPN37F>T9\JJ;-6Q1^5J72RZNI#4JJX'@&<"`+`,Z#UZ[]X]
M%7)6/;>^U^NQPL0O8Y.]\#G;[;;I$VLVFZ:>(5493IYAOJIT%+-Z"M6$4%<I
M;7"O=&[F.4H#JYN`YU*`),LEM<#Z^G1I+>;!'I9K+2!,`D`Z(@V.>0;5;]WJ
M4U(46J;SR0(M/`[C\9C%0`ZX=&>U6BV^E@R-/CX^+G6/;Q_+I3;-YW.EH-,C
MT\QR]4@6.7F54N?#8#!0LRE7F<=%%@CG*EW7#&&=S^>J=8?))#T+@1>L6OA^
MOL&,VJHC6JTJJJ*/:<>A1U,:MI)G#L+/\YQ2-U6?$MX?Z#S]?I^&EPH7R:'F
MK#P/[W*I^[0Z.IU.EF72#$&?/7JS,ABYKB5WYLED(I,4Y!84QS$-J2F-GNA9
MTY5-L-9VLFXF_B7F,KU5WZM5U]G%8D&7;K5:<O]O-!JR?JQ5`EW9SK+>+&VY
M+'YR0MOM-E_"K/<C+VJ==+KZ$M3=NE*2)-G!_=:TK)5*@FL,E]NWH3V"9P(`
M4`Y6I\Q:+*597JP7JN(<5FTCSW,FG^:97=5<^?:*HJ!CR)^C]OI6JV42R*(H
M%-V5#K=2!BC?N\/A\-EGGUUB>-,TI3.8B:#T7QHQ&;)E/0\]LJDFULJ),@=$
MCDP<QS0X\A[H&PHY\U]:5=*756I9W6FU6E*/X7-*!>ONW;NRC1Y?1:J\9LVG
M70`_\O'Q,=_J*MH,-1UA%4J>BN9E,!C(+ZT+-L]S^;UD1Z:&2IN`U62C^-MB
ML9A.IV^^^:9)4V58H#656GVC9-[#"OK]OD=U3I)$1FA+V98"IEQY/&O*^"4+
MV$H>510%%>E1!83X2>D>I"N>9DIN98$MM(%NP+4#T(S+2C;F&4PV*_F,XC\,
MU4!8SAT;!SF3D.>(OI?1L\I\0/,H]ULI;\JM[7)3J[>`GS'*M2`W.B;2L@$F
MW1C-D3DF\_D\SW-Y0BD>/)CM=MM:C8GNDS[W>CTI"4F2*(I"W9Y:K18_)G5G
MY2$R2WG+8K]6@:$K6B.T`V]=,1XK6<RL*(J-MD)9KF211_C5.]T4JB1)3%FB
M`:^8G0%?*'@F```U8+565JP?.!@,Y,^Y2H')9+B%@%4[ESOXPX</267A5^SY
M^3E]EN[01X\>T=LBBB(KLS6=$LN9(94&;QI]90"ATI#X$<PV).JE-1P.E1JM
MQLH,<BY]*<I.:[/9C`?$HZ3*>:<0+ZL36!;P['0Z)R<GB\6"-;/#PT.Z^21)
M>`2D/[/;[?((=#H=R2WY)&$8RE&RJB/+57;=$$@RS\[.V`51Y?;4I+-*YU%E
MK)12.J5="YFH8!S'?J^C6OO\W^%P*-U?9O$;<RUWNUVIB_-G>1[YV:/1AF'H
M207/\YR6`S>*D,/"*Y03O%NMUG`XI`(_C4;CX.!`NG.YDRW-8*?3H4%8+!;-
M9K/7Z_',TL+A!442SM71J&]-DB1FCQ`U!32G+N<>#9%9WL9CX;(*C+E/>@QM
M+($TL)+O2>^ZY&#\='1%E1?@DG\6,*O,\]R%84AW2UL$GYP$CXUQD\E$5C[C
MPY(D4>'3=+=JR=!C<NXESS(_OF2`IE&&;D!*,A4:(#DQ7T!A&,9Q?'IZ*K/B
MJ5HR#8MR;J=I2FDF-.PJ&WDRF6191M$?K@'WU,>20\HB),VX:PEOKF7J=4EF
M=1.>6FBSV<RZ^]'B4MYCUU50F!<\$P"`&K!J\.8;U/I*4%NV2OGC=^U@,*!7
M5)(D\G+\WN)?'1T=D;8Q&HWX<KU>CT.8^%4=QS%M]]/IE(]DTMOK]=1+@M[H
MBBQ5*8`T'H_E>X7*0DBEC5_/YBM<JNS\X/U^7WYOOK1ZO5Z_W^>'4AJP&GRE
M1,J#Z0`:!^N\F+9\\ZU,^A:W)I>'M=OMV6S6;K<;C88T$LL<0AZ<V6QF;079
M[7;E3$E/$>M881C*^V<9J*YY>[3PU<'][B@'S`Q`]8`GU%53Q)00JYY$096F
M+$G211+HM[8H%ZB'_MVY<\<5]2#+M$BOEZODE2D5UG.Z_LK[@$D;:'C9:<9M
M$KD5RC///$.+40T=31Q%[,NNH6F:CL=COF<:&19:^M!H-$ATZ:+2VR_=1.;6
MRK3!^A1R[;?;[>JJMMQM&HV&/'EU2PT]*?WVO>]]+W^6/69X$!J-AI(9N>U+
M:BJI;RF-D2/`#T5S0>>7CC@SW_+QX\<5'U.*Y7@\)AF@R>6-B.KW\+//9K.#
M@P.>5I[QT6C$-D07QU-QU)3*3B(JYXX&G-),Z'MEF"B*@N2SU^O1@*CHCX.#
M`P^OD_7;>(5*056_O:K>E>8.9F8XNRS:29)XTE!??_UUTT3K,<$`X)D``)1#
M&FY5?W,%,R'0NA'S;Y697WTFYT#P;B]HFJ:DQ"C5A-21.([YY/?NW2.]@;T-
MDF<61<$O;WK7,C^4YU2:JY6!<)P8WSG]2C5!*07]?#*9A&$H]6SY(J<76!B&
M4A?,LLPZ'33XK+1)MX/'+R0G42IY](P4$LGCSY\7BT51%)Q'1,%4G4Z';EB]
MU[D;>+O=EH/&+W@9B2=U+%D/P]7H[^#@@&=YN??]VLM=T&V0E=V,**[Z/G/G
M6YKE<UB3ED-J78^E[3U8YBF9UJJ&RF7"HM5L-FG=2568[%,DTK0ZY`C<NG6+
MIX`G5&:C]?M]E_(JEXDJFN41`ZH@Q5N$K`]$0\<#*(6-GY'24'G;:30:Y(JG
M?7(ZG=)3<*4?KJ3*(90</,]V-'-Y'AP<T(W1@YA]?4TWM8P"F,UFU=M7#H=#
MZX:O=''K;[O=[IT[=\@*1I.E%BGO*OU^7VVMO&:)CYFFA\#PSGDHC1P0>@3K
MULUTJPIXCR5K9E$4%+O>:#387B!'C,:?1T.VV3P^/I8F,+XW5S:L6:&`HU7E
MBN:)ZW0ZM(U;FX4&[X3S<+]EN>=[HF!84"5=E^6.S(+MJV^>2\2D*!N-+!?,
MXRQ3_96E>#J=6C<9&9)#TY=E&3%Y=7[X,\$S`0`H![WLZ=7"NB![8UQ=I_TT
MU?7ZR?/<9#[GY^=L$9>.,E+=I"["9?0:C89\/5.&V&*Q8$63DU)DS49ZLYHV
M3E-#M3(0MH":;VBI[I0.ERSHHM0R?BBE-Y!^$,>QIQ(#CS8YCN@V..V*%5"I
M]M'8*LV,N8&JI:G&BL[#UGUY0JD$,^GE(9*U?*1>%<<QRX:4')F/1\57Y(C1
MG\S$URM1`N05E9>IM"6=8@@J)M`E1<R]6>OE<;822[/X%M\Y,YPHBJSF"?6E
MZ524ZT*6U8GC6&::2;SQQAN4\TR6!0Z(#</0.GWJ'KK=[G`XK&)EH+W%]*UU
M.ITT34>C$:O@\KH\AE$4S6:S^7Q.9^!6*S3:C4:#:1+]G"8NCF-:YO/YG$[%
MA7-4#*JU`I":P4ZG0WOLO7OWK,](M85=G2==E@ZZBIQ-7N\N*D(9"G)%JPU3
MMMZ55Z?`AU)R(@/[E1BH;5,^+,53R*U8AGC(?8-6@;E`:-'QC9V?G]->2BU_
M!X,!S3ZM%%GSZ>#@(`Q#FG3:`TDFU8LFRS*:H-NW;_//5>*T$N8XCFDZK%M!
M%$47%Q>45&^-Z:!GX1)N\N2J7K$2)'/`6ZT6'RP%@R)X5]\\EW"*4CWMX-W5
MGDD4GSQY<G%QD:;I^?DY[RIQ'*N8(*X@/9U.Q^-QDB3T@9^:1NSR\I)XYMG9
M&1U/V\5X/%XNE`8`SP2`&[:$FDUIJ64EC+XQO9>#P<#46F2S+\]KPS3)SV8S
MNA9EE2C;9)9E,H22SB_]+:U6ZZ677@K>70"0]51YN;?>>DM=FEX29O\`5A>4
M`5C>7JO5LOJ7Y#O8&N!'KT;KNUDJ'_2`LB1#4136`,5.I]/I=%2SN/%X+`]6
M+=?IQNCDE-*6YSF/\V@TDK]EK=>,+E8/^-QSSTG5A.Z9;H9/+EU8:A#XF%ZO
MQV>.XYBU25FW-HJB>_?ND6IX?GYNTA)KH2"IIZX]W(M#N*U4TP^I=G-JF=\]
M)1/#+BXNZ&SP)DL``"``241!5-(\5E8-TI0?^I79`U9.$-U&M]MU47>Z6YH%
M&4/(TLN20RU2^+^RDVK@B'\>#H?,#[DB%S].H]$@LX6B.EF6F;7$U(SP4P\&
M`QY_^:LLRSCJDNZ9KD6ADKU>CS5R^M!NMWFL:)>@_8K\^7P)3L.35:.D#,@\
M4CG(699=7E[2/=!<+!8+N7=E649_I7WOSIT[\F&MOC[)G6J!%QW%#TO14MO"
M8#"@B.5.IV,ER7$<6V\@BB+K*C:+XK"H2.8I%[MJW$+5Q<Q-F"6-[H</D)6?
MU<EI$F7\PG@\-LO#T@WT^WURDY(,<R()G=E:LV<RF;AF9SP>GYR<4'BMJQI<
MK]?C%X<<!.DY5S@Z.J(AY5`C]5F27ADQM&DH:QW;:R:329JFQ\?'Q!(?/GQ(
MC)UH(?_JP8,':H=A2GEQ<7'__OT\ST>C$5DM)=D^/S^G"7KSS3<O+R])&*B(
M`*U<%TL'P#,!`/B6'M!NM\WZ$]/IU'1N/'SX4+V?HBB2O=VH&K[UG6?NRVSD
MEC^Y>_<NNQ]5I0>Z*]8G%HL%?584@MZ4G-&7YSE](W64M]]^._#&3WH2,V05
M$%-W[_?[G/8I':TRVI`4%"N7X+Q'F1T4O-/"3I775PXH&@W99UQ"!GW1R<,P
MI-36*(JX!ZG)P53[.*GA46TA[DHO60274>$3D@>)'TKJ+GQ,FJ8R95=R,$F\
MF;Y>7%SP;TF?SK+,JIQ)IE&J'GF:L[%R3_=#^LW%Q85JM\CL(@Q#EGS3J-'I
M=/C+9K/IJ0EL:JXT4-3Z+W"[R#S<V/6G/,]IB'B@K`<3?Z#CXS@FZBOE1R5,
M6HO<+A:+)T^>4,"D61I'NIZZW>Y[WO,>:P,D5>O([]#F8.\@"`X/#RG!6,D,
M%_+I=#I)DM!*H4FG2%HVS]%\\3E)S-@*D&49K4H2!AZQT6C$](,&D,N32NN#
MS-">S6:4)D"!]^/Q6(H<MUJA$RJS@J?ZFC5FP>1@15'(5C1T&"5O\Q9D%@2>
M3":GIZ<T._*69$]=N8/)#9FG7E%NZX-899[$0)Z?S90DDW)/D(D;-%.<J4$W
M'\>Q\L32P_*446-5=BPS_9/WS&$IS6:3YHN>CM.&I;F!'.DNH]5[WO.>X7`X
M&HU<+R.BTW3/T@:J[,)J<Z/OR8[#MRKK%?,44P$M*P\TR?;JAKS9;$97F<UF
MY^?G%&]%,4IG9V>SV8SNG*TPL]F,:/]T.BV*0M5FHS?%Q<7%DR=/6)@IP(''
MBCZ33)Z=G;%PT@APP2?^YMIT=0;`,P%@;:`M]>[=NU9F8GYI>D4ZG8ZLR"\U
M/%E\7V;]26V#[>YFB4C9?)S[C,EWME2L^?.M6[?X?</GI(1/#C]37-<Z,HJ"
M>M(=Y3GS/*>V!ZP&<0D02=5DB!TQ7CD=@<T=2@>K?O2EJ7<N:ZM9T)^H9G69
MH6H39(R@`6^U6C+5C523=KLMZRC**S(WD#U1J>D\'\^S(^.N1Z.1-1@UCF/R
M9942+=.//9U.9:].)0!2,V.9'(U&]*O%8O'X\6-6!^D&\CSG^L8<G/GDR1.E
MUDO/I"1+IF7$.A&UB@];:89K?-22M_I,^(9E5JKD\'1+%!]+XZ,"\+(LH^_I
M&.685>N1(U=YFMKM-@TLW:3BI7+NS"5/8KE8+"C-V-01>:(I`8_DF7:5\7C,
MY:\;C08]@HP7&(U&]!1$4/F)HBBB\W"&I[1#J0D-@D#6UXVBB(66=TC7`G_P
MX(%UIF@TY)A4V>AD\+-JPTL%=15WDCL\NR4E*W:YZ:P&()?ZGN<Y_\FDQ_U^
MGRLY\9>W;MWRF%=DFF48AJH[SGP^IZ?CBUJ?XN3DA+<^DW1Q@2BK*98_AV%(
MF:5YGKMB4_GQS85/3:TI75Q5%V/)M`[U8K'@R[&P26F1_)-RCZUFV366`6?O
M*ULWCH^/R9U())"O]?CQ8S)KTD*8S6:7EY??^,8W:#?FPQX\>$#G/#\_)ZNT
M',`'#QZ06?#1HT>SV>SX^/C\_)QRO$F`*;>34FEDRQP6C.K[,`">"0#7'YSD
M=GAXJ-X-,F?2SZ_HO67V4J.0,]J+DR2A5QTS$-*3S$JM['Z4]\/M$V6]6?*B
MT)>LYK(GC:K#!R)L+$U35C)8#S,9'1</E*],=1@_NV*_ZK`HBEP.7GY%R;^2
M.FCJV=UN]^3DA"/N^$WO4@JM7S)7#QQ)@Z5A/\K'(B?H_/S\N>>>DR4*.0]-
M%JJ1?4UX+GC*B$A+'PY?@K1POAR[!:0_D/2`)$DX.\ZD3V^__3:EXL@T*O(%
M\>.KRKK!N_-_&!<7%Q3-.)E,WGKKK;.SL_OW[T\F$^J?27^ET\[G\Y.3$PKH
MHE.QULXM"LU;98K."\?D@9(M^_.%K)E752##05TF)\I"I$4A32'TF2LW2A,`
M)<Y1U&6OUY-<0G%:DE52_EANB>PIMS/U*5&W)WF%?`I:LRK(7,H;"R>!?LMQ
MMOPO2RG]2YM;J]6B_S:;S7:[36$.P3OQ#F3:(^\N%T:BSHJT$'BRY&":K,;?
MH(+6"YV!GW$RF<@!,<F&N3,HL4^2A,_&@<T4Q"LCY.D1SL[.>']3'0[5C9E3
M3^36DPQ\<7%A5O.67KC@W2D/=`POD\/#0TGA.'R&'I!K7/'-<U=,-I%P"2AI
MF^#_\CC+I3<8#/B`,`SE_"HZ3=U0`IOCD1(9*`98)L#+8>1&G33^YOHRZ2OE
M6[+_ELUM[.T?C\?*6LJ!%:[<8$]9`4FJ_2\=CD;.LBQ-T\O+RS?>>(,M@[1=
M3Z?3^_?OT^7.SLY.3T_??//-T6A$,S(:C?CM_^C1HR1)R%<Y&HU(5J4ED0(B
MCH^/:;]Z[;77TC0].3DAZ^39V5D<Q[1,OO2E+\G9X<(64"S!,P$`T%NYK+3&
MKWEK]"`?IH):2<F0[S-V?$F%5>;&<+<`661R.!S2#Z?3*;^!&HT&O=*H^('2
M+;C88R#Z8G/5F6:S2<H<AW<&07#GSATZC^G[HO<K>YGX-6:UN]/W5FI'%1=9
M<U5O8LZ0E,-.T<NF:X@J,9!*=WEYR=J)K*S#MV$-QZ66XOP42I4W579)IUDW
M]:1R*56#*Z^,1B/6/MOM-E]7V@LX[I$H-!\_&`SD%:4P,$_H]7I/GCRA0::1
M)#WR]/246L#1D%(F*M/"*(J(M]!O294QR1N-R:-'CZ1'@B7MS3??I-P>:O?Z
M\.'#;WSC&Z1'$H\].3DY.3DY.SL;#`84OB5+SI!*9)HAR,,FA4KF!]+42]79
MGY9I+ELK)ZF^5W#E1A8SU7+&Y*)<FU3RVZ>??IJ>@LY#!;W,!^%`XB1)9*T4
M\D!ZB!;S-[HTC9MIER'BQ^/)_L-.IT/#0H8,WF$XQ92K^Y#&'X@6)H'HZT,L
ME/WG)&PTIZ3%2H\]%_941BZ^55[XK/>[E/5GGWV6%KL9@2)W/'.O4%*DFO3P
MW/$JIA1QZOS!.10T68HXT2"3,#")\N0A1U'$:T&)!-^J2B;GK%H^1NW;:9KR
M&`X&`RGY\A*T\]!?^6VENF)2X"7]RT]Z<7%Q]^Y=EP-6F@CIS/26D1'4/%"=
M3H=*$S]^_)@>1QI9PC"DE,ZB**REL[BGJ&PN*NF0:<RE>^,"5^QXY^+G=)\\
M:$1T36LI#QU-=&D3*1='I>DC+R5=8CJ=9EGVUEMO4<&%QX\?T\E'HQ%]DR0)
M[;1OOOEFEF74RG@ZG=)6?'EY>7%QP5K'=#J]N+B@S9]>!R<G)Y2B^?CQXR1)
M7GOM-7JA<(NU^_?OC\=CDFTJ.$19G4Q0>09WJK$S`)X)`%<&4HB9K:F7HNF=
M>^][WZO>"@<'!Z2%TYM,Y@A)U>?@X,`:S4B7D&]*CDGCU*9`E'GD0NW!NSVN
MK#TPX6$G)_4AD"I[$`0OOO@BE63@LG+*;*\R(95=UB26ICZG-#]KY&&2)*1J
M4"K.:#0:#`:F4T6"$C4)Y^?GG)/)FBBGS`7NP$MU9KJB>H1^OT_J`M7W#\K"
M.,U'4ZJ>C+E2M(>.4:9W*8$<@TK@>A6DK(_'8W*#DUH?AB$%N9%>0H<]>O2(
MNRPN%@OJDT8:!MFGR<4]G4Y/3T^/CX_/SLZ(4YV<G)#:03^_O+RD:,!.IT/?
M)TER[]Z]T]/3BXL+HK7$)UNMUL.'#XG!TJQ=7EZ2&?ZO__JOB9V:HVH-_O2(
MV6`PD!T[I'=4A3BZSLD*+DDL6UADCQDYIRKRL-_OW[MWSY,225+D\EJ0)%A[
M]%$&%`TF:8<R3H\[NP:&+T@%/:HV0A)'1T=<8RP0_17'XS'7`:*K<`<FLI1Q
M<EVSV:3-AT9;96KU>CV26[K$DR=/Y*28G6/EPN1T@#S/B9BI'C9,6=FJ99(Q
MDZ]ZM@)SP[%:T(C_\`UP,/!L-J-]DKM]4J56>G:J@$W#6*40EWS1L,B1GU]1
M)EX(/#YT/*>J<J-+JSF&#G-E1IB+469RROK`_7Z?:#G%Z3"%YLAS:FYI4D&*
M7.`%0N$5X_&8Y.KV[=LTJO(-\O;;;Y.?G+8+EK?A<!B&(67_4O"M^42R=OK)
MR0G_5E9"YO).,L6#;E[*$@T:5>22CFM9P&\5QL4YF4$0O/[ZZY/)9+%8C$:C
MX^/C/,_?>NLM?BD<'Q]3:&L<QT^>/*$_)4GR%W_Q%X\>/7KMM=<>/7HTG\^/
MCX^I*@0Q1@HP>?SX\70Z??CP(07$4C3*PX</N7P@O5^2)/G*5[Y"4;N/'CVB
M%\3IZ6F2)&3<I)"NR61R<G)"=WA5_44!\$P`V!62R9%::9K*UQB])^A%*),&
MI].I=!2XWMRF$9H+MT@%B(,AI==+<B16PGJ]'IV3E#RN`2C;\;%RS*H>UW;G
MRD"RGI!LQ7%Y>4DO4>:K]'ICHSL-#JL.)N/B'WI*R%AI)ZNG=-N'AX?TU++S
MFU)&^16NN)PT\%/==A<SM"8IT2.PNA.&H3(]<-=0EP8FCV3MG)^42Y6PZ8'/
M0]_3\+(:U^UV^09D:/1\/F=-E^H$SN=S,BU3>4"*6GSUU5>_]*4OO?KJJ]/I
M].SLC`*NJ&MBH]&X?_\^\8J+BXNSL[-'CQY1X=:O?O6K=*ODZGSCC3<HZO7Q
MX\=G9V<7%Q>4C?G**Z]0FBA1CC1-26"B*)I.IZ1U/7CP@(JL4N\0*CB1IND;
M;[R1IBEG)L_G<X[E4\IN:8,6RH^E2;?6Q*JHS=/(JU`Z6;>)U3YKMIC5(^HI
MLJ6ZX,A*PN;CT[_D:>1SD@V"146Q:'F3[&2S2BDW3*+;D$8<&CV.Z>5"LG$<
ML[>G*`H*P^8536?H=KLTI,0Z9)"%E?[1TN-XO."="FWTJR1)*/E9+6?9F$15
MD%(#XI$$_CG7**H%.C-5X985O-C'RZM8OE]H@EBZ^(/5;\D#1?57Y6:HBL2:
M8ED4Q6`PX.V(8AFL!L'A<,A7E,/5:K5D>JV47C5<5`&(RD3=N7.'*9#,AI">
M22E7RF],MK#@G6`!LJK(''(::GI`6?*WT6APTUHJ`D3G-^TLS"HY@5;6/9+Y
M"#Q!]+ST_6PVXX3\9K.ILFS8<,SQQE5`9RN*8CP>TV>R&Y(ID!;:U[_^]?/S
M<_KOR<G)^?GY&V^\<7Q\_.3)DP</'GSE*U_Y_]E[DR4YKO/\.VN>Y^H)0S=`
M0`1-PA0U6]K(BG^$M+8OP2O?D1>^`>\<H0A'>*>-%984$F62-@F"`^:Q&]U=
M<W6-W^+W]1,OSLG*;H`@"8#Y+A"%ZJS,DV=\Q^?AH;N[N[=NW5HNES@-#P\/
M.YW.X\>//_[X8S;\:]>N/7SX$.?@;#:[?__^W;MW=W=W2Z72__[O_[)OW[MW
MC][@Y\OEDM1<,MY)K_C\\\^Q<HF48FT2S^_U>@\?/E1=.OWFEQ?%$MN9L<3R
MV@HG#>&^_?U]>Q3ECR5X.O5H,IG8##<IRM86TJ'NX"AP2&OOEJ'KJ*H"%K*^
M6`6F[-$N9'^;^3:=3FEPI5)1L!17NKVL6"P^>?)$;9:*I@1=6BOKT:(X1BC0
MCIH2<26=`W.7OK1L!.ETVJ^XLR$=&;V._29+\O0$7]P37<U2I?O:6S:;55]%
M8"/)VB^52KH^F\WJ)]A[SGT<;5@UO8[>62J59$BT6BU0+N6DOW?O'M4U>WM[
MY7+YHX\^"H+@XX\_YOY??/'%O7OW#@\/Q^,Q(5!@/`DT'1P<W+QYD^*?;#;[
M\<<??_GEE_O[^V@M=^[<N7?OWF>??;:WM[>_O\^41DE%<4010</@)]1ZX27!
MUXX*-9U.4>^RV:Q5Q=3AT-5@33GN'KMX]:4Z7-:C1>Z-$-KO&XIV6EJ-WUYI
MK]'W-BSC3(D(GXLU\$*%2=)JM31)_.FG;G2H5JUQ8G_%A%0?9C(93(CY?`XG
M!"N.-`%V+;X4X42Q6$PD$@Z8YW0Z72P63$AP2E7)MKV];7<`1>>T[6CUP3AE
M]\!FL^EX=NRX6/3+B$3$B"V+_<3'8XL6905;"J+@Z<I2'U[;R<.GKY3-[AN?
MRN&4(T\YG-Q\57*FXU!3/K,O-MO3YN'+VM=#A?+-L6+M7F#,P.!U$EAH";3#
MH?:\#V:+E44B[N[N+FL<[-]FLZFJ0D&%.T8O,$*KSB#.FDPF4ZO5F,`<IA;F
M1_]E<.UQ`"Z7?1&;3RNG@[.QK")%8_]D9`>#P>W;MY\\>?+HT:.//OIHN5Q^
M\LDGH]&HV^W^X0]_`"%V-IL!??_PX<.//OKH\>/'N5PNF\W>N'&CT^FPWJE9
MF,UFMV_?KE:KX_%X;V_O^O7KP^'PBR^^&(_'G4Z'O%SVY,ED<N/&C60RB0^Q
MW^_?N'&#`;U^_?K^_CX)S')!XM8\/#R\>?/F9#)Y\.`!W"<4:#Q\^'`P&.SN
M[N+E_,,?_@"?Y[5KUU85[,02VYFQQ/+:"MQK'#9H6M3R^8?W]O:V'PKC^$DF
MD_Q67CU;U2;`MT0BP0X[G4Y%>B96`+SR4IATYG&*^`H6MY)'5KE&UCS>W]\7
MSYYTG>ET:A$O5$@INCQ%S!"+"BOB!(4"0L].Q\[TCWR']](:#])3K>7`G_2R
MTFYAA'.T;8`Q;4@PPB8D,<_ZU_G7S_6U_.F^!D-J'Z"O*JO3A+$TIVH88\W,
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M=H1F@&6B]O-S33R*"5?=@:0X5%4M!,MCE$ZG[2XW&`S*Y3(-YAJR]42N@RZN
M\DX?,$P)^3!PVN!/L5A44X?#H1W]<KELZUV=C<A?ML[0^\DCUDR2O\`Q$BPN
MES,-[*#8#=R9JYU.QY)/^'N+/[O\K`K';6&;Y)Q-_-<F;%L:7C8]?;^J5-6^
M&BWI=#I.);QM(<:GGJMYR`RW5:QV\O=ZO6*Q:"E#+2^4+8'.Y_,4"Q!/`PC7
M@1=F<[8,+OYNP-1*)!(.)[8JP!6Q#TS5<6"0KF0;<W,-A!#[N(EFD="A+%D+
M4^7V[=M!$#QX\*#7ZSUZ].BSSS[[]--/__,___/Z]>OOO__^C1LW;M^^_<<_
M_K'?[__UKW_%QKMSYPZV'!AL^_O[;+`???31^^^_/QP.4ZE4+I>[=^_>:#2B
MCAK'7[?;_?SSS['V27':W]^_>?-FI5+!1'STZ!$GPMV[=P\/#VNUVE__^E<R
MF7'IWKIUZ[///J/E#QX\Z'0Z]^_?W]W=??+D"7L^M?I__.,?:=C!P<&?__SG
MSS___/[]^ZU6B^H);&!+\&,]6<_!:AO+MV9GGAYB^#17KAK[R62B?1.8>SR:
M).Q1>26E=G$LP7$P76C(2D@06J,V=VT$8/>K6(C]0ENAK8X@FF%A+7T/"G]U
MT)D%5\W[ZD'+Y5+TZR?**2][OL&*Y?FBE[U>CU($YY!#OW>F!\@Q5G.UWFX+
MY<_)[40D;!I5<(PI:BVBV6R62"14DF?)&P7TPID'1Q:[,,^R(0AN;E&(I'4Q
MC1N-AD4LT-QNM]N*V0J64)=9S[KEB[>GH_@YK1[#_7VO.="4O@/;*H7@TY+R
M"OJ?5!:'8X;\3-\73NJLD%ILV-`J^H[NY>NF=F0=+9!\1?0_1W\ME\OS^9P&
MJ)]E']K7MX@X@4D#"YZFJM=G[9E,#[IHN5R2\HJKF.VQ6"S>O7OWT:-'#Q\^
M?/#@P;OOOKN_O]]JM=#A.IW.EU]^^<477S2;S<5B\>C1HWZ___GGGY\[=VX^
MGW_^^>=,E0</'I#F>OOV[>5RV>UV,4=);_[\\\_;[?:M6[<FD\D77WRQM[>'
M'R252BV72TCM:K5:K]>C[A>(?-[ZR9,G:"3T`#6E,I]6.07$HH$?1,/7:#1\
MN\L>#8')1G.R5:--OF@;X%DU(0*Y05C^GEWIH=R/-L@?&!":4*LCG\^S6"S+
MGS-%K66R7"ZMNP3Z):`^=!QC)6)4H"OCLV"9B+\45UJY7":KEA4DV$_'XI+[
M0-]CK5F87%'):U!LGGPJE5)7D*<:D?4:NKK]53D<#K6B&0N[*QX>'D:8Z$BH
MM:;$&5%01J1"2`#0HAG^=FK!5%?MJ#Y_9G`<ZJ?<3E>".:3/Z$XJN[#OHI/(
M7PM,0E;99#*AY8RLM1[)@-7F)HC77"YG,U!4ST)8VV'O!`1(+,W6N4.#:4:Q
M6&1\[>9O8:N<$*B,\W0Z+:Z@(`PTR%(0R21VW$-D4^M[H3I1VD`[T8VWMK:H
M>_^W?_NWCS_^^$]_^M.U:]?^[__^[^;-FY]\\DFOU_OBBR\&@\%L-OOTTT_O
MWKT['H^O7;N62"3V]O;NWKV;S69OW[X]'`X?/7I$*'(RF9PY<R:?SX/^C9.7
MVHK[]^_+]X1:/A@,.IU.O5X'5.G^_?O<O]OM=KO=Y7+YZ:>?GCESAA-G;V\/
MV[[;[3:;S6*Q^*<__0D`V_%X?.?.G?OW[V/_DR#SE[_\Y>[=N\5B\=-//QT,
M!C=OWIS-9KN[NX/!X/#P\.#@8&]O[]&C1UBGAX>'W6Z7.6:=Z8XE'\LW*8E_
M_N=__I=_^1=J]Q\^?'@:#.588HDEEEABB2666&*))9988K'R-W_S-T$0W+U[
M]U__]5^?<M%M;F["]1PM1.1P/#M^4_\;*\08`5VP%?D6CRLXQLGFQ6)".
M.)O-2$X#\0(<.;"/5=A@'RT.`]C5YO-YM5KE$;U>#RAV+B!1D`(&_@4]C_0V
M&L`WN#PI4L=!8J$U]%#EZ",.]@!H`5]E_*([.9:O2<C#S.?S3%=<@*52R98M
M@?%3J50>/'BPM;6UO[]/P1(.PDJE,IE,FLWF]>O7WWSS3<6C*I7*PX</27$L
ME\O<D#F93J>KU6JOUV/.@&PQ'H^Y+;.4FQ#5@5H:F!^>R_V9A-UNE[M5*A6B
M.HE$@I#:[N[NVMH:J4>$&JB=H]FL$3U"\)6`\A&)ZO?[=^_>?>NMM_30P\-#
M0(;T#9_5(5M;6Q;RA^_I/9!:^1P<DVX'0?#@P8-*I4).,@$<[L.="5_@Z"V7
MR\ED4JF2@"[0.8\>/;I\^;)^4BJ52.!4AA[MX:W5*KZ$I)O"'@)N:CGKW8]Z
MJ1HJF\T^>/``/$/<YW0@5`']?A_`C,%@D$ZG,YD,W&[L8-R3HD=B<4(990C$
MTD92&5FUE"8J+A0<QU<?/WY\Y\Z=5JLUF4SJ]?I?_O(7TJTO7;KT'__Q'^5R
MF:&!G+!0*-R_?Q]LQHV-C<>/'R>3R5JMMKFY>>W:M8.#@W:[_=O?_O:?_NF?
M4JG4M6O7@B#8WMY^^/#A=#H%S*/=;K___OL___G/#P\/WWSSS<>/'W_PP0>_
M_.4O?__[W__D)S^A-`@$VD*A0-XL??[QQQ_O[.P\?/CP9S_[6;5:_>RSSPJ%
M0K%8O';MVJ]^]:LWWGBC6JVRRM@5F3"M5HO)Z<PK^Z^F(E6F7/;EEU^^\<8;
M3+FMK:W=W=V#@P,N9K)Q?P9+_^HIK'I=P$T`Z!H.AZ21"R.W7"X?'AZFTVGF
M&+]B,O3[_7:[3;)?O]_7ZW2[74&SKCH71J/1^OJZ?4>M$1ZA#H'W<G-STX'=
MLC_4-YJ$3"?]E5EJ>^/FS9OM=KM6JP&C`N5L.IVV*T4K%%P65BC)HA1\*@[)
M]:52"05@.!S:6!-EC?/Y7)M2)I,1,BH_U&=_G^$H#X*`#[U>CSQYN][M$M93
MG-V,<==G#:C=WVP7\5L0L&[<N*$L8D)>7/#PX<-NM\LD))CYYIMOWKMWC\V!
M+6AM;8VGW+IU:V=GY\F3)ZU6Z]&C1QL;&_U^O]ELWKIU:VMK2SOJ<#C4S.1!
M?G#UP8,'9\Z<65]?YSZ0&VD;#(ZY,1@=.YUTA]W=W5JMQBH.CK%>M5=7*A4(
MP!Q>TZ.C([9Q.C"=3A\>'K(G.[T7!,'^_OZ9,V?&XW$JE>IT.O96!P<'V]O;
M!P<'[/8;&QL???31A0L7*,M$6[,-/C@X6%M;2Z52Y%EH.=!=BI1R-#`M50#,
MCBT(!L*\;,6*8<(6Z^S&?,..S;_V&IV;Y/2)8#.52J&+DKO$G@D0]&]_^]M_
M_,=_O'[].BOK=[_[7:O5NG7K%CO;O7OWMK>W/_SPP]_\YC?7KU^_<>/&G3MW
MKEZ]^M>__O7__;__-Y_//_WTTZVMK8</'S+?+EVZ],477R23R1__^,?[^_O_
M\S__4ZU6+UZ\F$ZG]_;V*I7*^OKZ_O[^;#9[]]UWKU^_?O[\^6*Q^,DGGVQM
M;=VX<8..JM5J'WSPP<;&QIDS9W9V=G[WN]_]]*<_O7W[=KO=/CP\Y$`G&:K1
M:'SPP0?GSY^'0;K;[38:C9_\Y"?__N__GLEDUM?706-J-IOGSY__\,,/2Z52
M/I^_<N5*)I-A\]_8V.""Z73Z\.'#^5*SX@``(`!)1$%41J-!9)5JID0B00VY
M!0X\33I`+"]*GL?@$5*<;^U$VS\0+EOJ-GUO32^F!<HE1FDFDX&;7B5/.IE`
M3+&E1SK_=/-*I5*OU_6(2J52J]5T@6C!`(MC)1<*!6`>=6CE<CE+CD1C0G-I
MX$I*)I/^FP;/R+2VJO_CB?LM+)5DDNG'=&TVF^+\X$LR(34ZG)TVN[)<+F/#
MG#]_WMYY/I]35N1,)UM[@',D"`+2065;!L?IXN!8BG5*0/#">-27@O;9W=T5
M`P3)6M@2@<&$5%J1G7B%0L%""M&>_?U]Z="!8<E3T2;?^YEIS@+ASI3>Z:&J
M4Z76:S0:^9`8ZDR+4JB$*TIH'-Y"-56+UVE,:)(;)JY47CM>$5QV]LX^#B&O
MB4+)-$#)X$L+"JJ7)7T16U0;"_TL,I7`)&<J;Q:$9*I)8;[9V=GAZ,UFL^^\
M\P[39CP>[^SLK*VM7;AP`=6'JLY&H_'&&V\`'81%-)O-WG[[[8.#@ZM7KUZY
M<@7CK=EL9C*94JE4K58W-S<[G<[Z^GJM5CLX.,CE<M___O?Y+54/]7J]U6J1
MB`L"9!`$W6[WRI4KJ+FD5*73Z;_]V[\=C497KERY=.F2V&7+Y;+JV00O><IU
M;5/R'/07F](<"B^L<2F52AHL_S)20_T[^]E#6MJ"1PI,[;0%I?33()?+9:%0
ML/5II"D)5$S33*FGUCSP%R8/LI0D_G/]U-]VNPU<<"J5XJVIRQ+B=+%8%$\2
M_F*\78%)U.>O#`>9\'SOK#BJ9NP>2^F=KAP,!JOR5">3R7`XI`<`,;8)BEH^
M3@6U3P,3#6D6FH@[F\T&@P$&0Z52H6_9'S0BVDGLH0"E1*%0<&XK%BMJ!7FN
M97!!GPF=YPYV$;L*G"*#P8#!HBL8S>%PJ/F#]R%X.G.X6JW2'C0KIR[`4BL#
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ML^];![&\O'9F++'$DL_G"?19+'X47`(%3J&+/G0Z'4>=Y3`CKF@/PF0R*?LJ
MD\EP;+-[6A4!'#FJJF0,<]+CJ<&KYQQO,!8&Q_2)\N"H%,W2V0NQ`)4.*\*!
ME^AT.A<N7)"B``JH3#6+ZAFMBEF[*W@:&95^X!B6K>L<WOS51]"Q\"?R?_NV
MO042.-'7HYMSZCLUWA)'-;<(']#$\0J@DN`RI^:-IU`*I;Y2=W&05RH5ZF!Y
M.GTE0'\-QV@T4@8'ING9LV='HQ&P,<0*UM?7[]V[M[:V]LX[[[1:+;S75ZY<
M@6*D6"S6ZW6Z[NS9L^?/G\<!O[&Q4:O5WGOOO=EL=GAXN+&QH>J^6JW6:K6J
MU2K]7*U66ZW6SLX.=)&;FYM@76K5O/GFFP!.T$6$(*K5ZO>^]SU8.J%L;3:;
M;[SQANPW!ZV4Q6754Y]>THZ=M0#IGU`M9+%8B!G2UU>$4G,:?%HV#3NLUOL@
M>\`27<HL=+!S%1R;3J?0S8E&"-<^Z!V")RB7RW#?6:-""\19FT*1L5UT(G]Z
MK5;[]--/CXZ.%#ZBZE)4EI1-BE!DN5R*8!-CP+&H<4]K_MM((S?4_I!,)DDW
MP(;4AAQJR3MUO`"NR&2%%5!`;DJ+T`5.L?IIO$N2P\-#S4;+!<+L52%NX-&!
MIE*I6JW&N@CU:&AGL[JUP&9U3UDR^/&7RR5O9P\FBQGF[(H66X[N56]@DF'5
M:*3LD#'N(J'1S-<]';X69S&JCM'98V>S&:ZQ1"*A0U,EV=0E^O2S!!7QB7#"
M"G:;9F-OE\ME>9.I)98OPR+W:$1L1?%BL>`:A48T?]0\C91#A2*^I>!I<E>0
M&NR+4("=S6;7UM9RN=PO?_G+2J7R\Y__?&=GYX<__.$__,,_Y'(Y&'I;K5:E
M4OG%+WZ13J=_]:M?%0J%<KE\]>K5BQ<ODBATY<J51J/1;K?!]1T,!N^\\\Z%
M"Q>8,]O;VSL[.[5:#6<BYP4X$=O;V[E<[LTWWYQ,)MBE9\^>):\AG\^#[=1J
MM0C#GCU[MM%HT.?U>OV'/_QAJ]6Z<N5*N5S>WMX&$^[O__[O+U^^C*6ZL[.3
MR^6:S>;ERY<W-C8X=&S0R[HA5O$,QQ+;F;'$\BH)075+$;E<+A7!PP(4`JUU
MZSIH!'ZLS/$TRWP2<([-I9%APSU'HY%5"FD8T4X_FL&7H+1Q;@&@Q4F)ZD"S
M!5(O"KMNMXOY@2(;!,&9,V=0$6CV<#A<Q0:^ZJWM-1:YQ!)(YO-Y-`QB<;3V
MX.#`1V!2;)-3QW:+\J;`NI1"(#M?%Y,+#<F'(J6.>9!.IZ47HJ/8\;6,;9R"
M#DDWS4/-12EAF&2"!@:+0AQB\-F0QV%U#GJ2)UKD"9Y"1J+P3H"!Q4X[=^X<
M'GTRFDJE4JE4*A0*K5:K4"C\Y"<_P=X;C4:M5@L<0@*25Z]>W=[>;C0:[[WW
M7KU>KU:K]7J]V6Q>NG3I\N7+:VMKI**<.7-&Q.MOO?56,IDD(Q3+!\]]O5X?
MC\>M5DN9(%>O7JW5:A<O7AR/Q_RV7"ZOKZ^3WRBD&7E`0F6Y7*92*2?P(B>(
M]6)8#&0NT!RFPU>MW%"EWW&@*%0%5,G!P8&C+(K&AF14WV2UH2%ZP`)$,3\9
M=`A+Y:JP4]JV*I%(:.K:L+FE$PR"`/X#S?#0$).UEM][[SVBY?0>-!7@3DE[
MIL=8Q1H7PB-T@DPLR\KK`&(Q'&I;J50BZ*115D9&1`#6[E'ZJQ",9.#9^T0`
M_UKFI^!IEAW_2[O_Z$^6QE-[!04:F.ZR!DE^#E;#((>RLUC/&JW2@/J+*!31
M2H]C*Y;]B=D`A(RU#^T[<K+<O'G3]N1H-"(9U7:X<Q#H<`''T>>@7BZ76$J4
M>,C")'@.!:BSX@@YXN,C:QW*$YF@Q6(1[Y)2AS@CM%'8]`%KF<N&U"'%4.H@
M!LP\>)H0*Y5*.1DQH>EO.G.=*+'0:#<V-AC];#9;+!;??OOM]]Y[;V=GAW#?
MY<N7SYX]>_GRY4:C4:O5,-O.GCU+KO[&QD:A4-C:VLIFL_(,DEJUOK[.7W.Y
MW/;V-D5AV]O;<%W6Z_5,)G/^_/F-C8WE<DG:"QD*R63R1S_ZT7*Y?..--XB:
M-AJ-Z71Z^?+E5JOUHQ_]Z.+%BQP65Z]>Q20N%`H_^]G/2*!E75,QH4Y>%9.,
M8Y6QG1E++*^5H,>42B4"&B0:6>TSG4[[E`80'W,2<&9;9%1]4&4O-`\ZJ$2H
M:%'XA8"G<D1K2?*!.TMC0_$52XH]*64.H<FAKUR_?IV,%RFX)%L*L=:^NP-*
M:74O1T]5L(6;6U6LU^L!/DGH-3#L;1SPBNV$IC72,)%N!V&,$5+%1$]J"3GA
MNA"C].'A(8CP^B&:C6].<]Z'TH)+D["A`":)</PM&7JE4D$OH=I'65CX[\7\
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M$:OJ0IV`%91Z("G0AP`NV):7RV6^P:-!J217TM1^OP]B+3--\4F(YH-CMD",
M;85J`P_>&713O:Q`LT.98RQ1;718,@*6-IE,WK]_WYI5_MC9]U((FH;)P\(3
M87#%#RBKTFZDC*E/G>K/S`@#.R)]PYF'_HL[Q,M.#%88&8X]+UN7U\QD,HP(
M*W<P&*AXRN;#V\GI;_CT:C*9E*MN,!B0G(E/RE+U:#)7J]5<+J?T:1QYI.Z3
MM<LKB_;3EB'@C%/S9!-:B'+K[=5;6.AORS7M#UEHD91_,1.@5"J!.Z!5`,S[
M^OKZ][[W/>;_F3-GR#(EKX0T$T*1E4JEW6Y3^]-H-"AZK-?K&.KE<KG9;.)-
M)N]@?7U]:VOKC3?>`#R6_?_<N7/U>IV?$ZMD@VVU6M0,3Z?3W_SF-_RVT6BL
MK:UM;&QDLUER9$1)2J9WJ]6R*_K==]^-=<[8SHPEEN^6`+'#8<#1-1Z/T2"/
MCH[0$GSU#GXYK";.#%RM2IR3Y68S/'7V2!L6A\'FYB8J(\^552/.+OY*^I`R
MUGB*18.PO-ZH`L)OX/LS9\X$Q]@S&'L*4P#>8%55JR7;T"[?ZV+=7$=O-IO%
MC"3X%JK@*@`2,3I6OT&A(0?O1&H!?\A$'TI@,SB)R=W:^?K&JI(T7EJ4M3E5
MO::*7(Y>&XM#G>)UT'6(06D24F%K/>@:%SZ3^<P<2":3I#^UVVT*CTE2*I5*
M%'`FDTER]K`AZ<^-C0VRK:K5JDKI<KE<K5:KU^O8#Z52">WAZM6K@:G=2J?3
M.SL[H$3D\_F=G9UVNPT,!BA6F4QF<W,3L*6CHR,4*4)A@K_:W]]7FIQT+P40
M`)FPFK&2P^W,1,5<9=%IK=E2S."X[-]2`85./U[$65SH4G:Q^%5J["VAK)LD
MC/D)`FMK:]UN5XIO/I^OU6IHY,UF4U@L-F/3/C'"V/!A]IRY#4Z>^K_9;%HB
ML:.C(]PB\JD)T&4T&N&>8U:H\I#4<75.L5@4H^!L-@/?2YL8MTTD$F2ZVB4O
MTF!R(L0V3$#>B1=%9YI$B-V@J%NVKHK0F*><4$^>/,%9:>-:Q*)I9Z_7<VI0
MG:$!",#9M?SKK0N,TP<OU70Z]:>9K"E:J$5!9SJU\5P,2AQC9PF<P/>R-^]V
MNT0C-8B6J2LX#K,3X;0N$@:+'<EQS>3S>>X&!XQ-PR&1$B^2"D`H9(7.47.@
M5JMQ\+'O!08K1/7#\$YI6]8I8#<0ZI/UO67+E.6IU10QY2Q5S(G^;KLY^'_%
M\-O>WBZ52K5:33FKP3'_<*%0H!Z!0R2?SY\_?YYMG.AQJ]6JU6KM=AN+E/UY
M?7V]4JE<O7I5_+=K:VO-9K/9;%ZX<&%C8^/<N7/4CF+J7[IT:7U]G=3<LV?/
MVF7.Z4!?R6?D3.,(^(-88CLSEEA>6SO3:FE4K$$/114<2"W1$0`=*OO[^Z@@
M;/V6SZU:K>HGCO^X6"Q*I>OU>LK=!5W0ZASY?%Z-(6;%W53K(K"K@X,#R\K(
M/3<V-H2-01M`@O&M:-1!::[":'7ZRDG*XA2A=M^Y9[?;S>5RUK0#PX!FH&P%
MI@9&.H<H^]1IN5S.(H5(\].+J([1*F<V'D@S(F(:JX;;5REPBCLQ-!'*XQ?7
M0,C"(4Y^='1$&9Y%H.$.UC"@5%A=)W6'*0K`.,8J%9@J\5U;6UM?7Q?8%3.S
MU6K-9C,I6_)9P*2J+H*;SO&L6WVHT6@`I::22`J0SIT[AVZGW#.>VVZW*93B
M%3#5,"T`M+"\>7XDBM'G68Z#@((ED%V5=6R+8!TW!V_DI"V$/MK2U5H-7LV0
MCL4T<V94O5ZW3Q'REKYT4'S(VY=9]>677^K^B42B5JL5BT5"Y32I4JG8^T?D
M@JZ*=-F",=D2[7:;#+KE<LF#2'^03@GR"FL0&T,YA-HBJ$,6C(I(*67GR,T$
M(U_P-"B+U?CMVK&=#&ZS77V^3F_M<"U>/TE5.S->10+^RA/Q.U:YS4Q%\@M`
MW.&]=('R2C1I57RH%BJC0;6[P=,1<F?;L1XHV:C!TR4;JIBUX<%<+@<$JV-C
MZQR9'@L!24WXZ73*-6PF;""!J>1/I5*RZUA<*EM5W-LN.O!I]`W^+)N`S9Q1
M!0>3C1[6N<FKD4,A[T/P-*VEG+!*(`(_6=,@U,X4VJ7UF-A_58).JP1_Y9\.
MIV1$][.(?=G>WJ9:_L*%"^OKZ^5CT3+<V=DAMV5K:VMK:^OMM]^N5JNU6BV7
MRUV^?+E2J?`E5+U454`_6ZO5\)6H3PJ%P@]^\`-RE;>VMHK%(N%3T(^#(+AX
M\:(2@G0>J:G*6(DUS-C.C"66[[JP35M^ZLED8L^&>KUNU<=0%$&=Q[CJ"6=1
MPF2K$718SN=SV5'!<7:0<S>B0XY[%0PWQU=Z='2D1"_!_S0:#3)[+9>W@`=E
MN);+Y5NW;BGOBY,#W,M"H9#)9+!@]18TV\(_V+ZR>,[6\1\<H]>N@HQ3198P
M8X4KJ[I$Y_R6)]X"M#KZEJT+U1!;]N<3?0>GVH*/'RVV>L5^J=CD\-8$4$`[
MG\^3.(<F!!.,K=[$M^VXA(55R"0A,Y8INK:V1D=1'D,XB$QLFPB'1>J86P#V
M!!X,@WXH;=NB7R!GSIQAY@!R2!9NN]T6D7HRF=S>WK8&,#]<7U\?C4;D=TEO
MDX9MIU9$>3"S#CX5E1]'A*%"XT5*5PZ-<5GI=#KJ3\VT4!L/"'3Y;EBY\J'P
M=K(KR"*6%5HJE4"#E-G`U.*W-EJK-OCNL%`]+]0T%?&2$OA)<`6NAIQ;\CN8
MYYB:4MP%%RQ#"YN9M4G<U;I1`@.UA9&FQ%J+CJN]RU*F[>[NKGH7\CZL(:?V
M.%V]:B[12)P@HHB+<$A9TX[=AMXC&YS7=^PZ^Q,M0PQO>HQ:;@X:"QGEOS68
MJ/9[[3:[N[MRPU6K5:6PDDFAN6T+\C73P%YR0D_\E_P"S"H+:<8*/3@X4'DD
M'6+QVUD%M.KHZ(CAUC(4+X"Z)9_/BX"$1W>[7:AQ@N,,`FV&%L<(W"/!7%OC
MDQX#TL:QWB$#TTUT0X'<XM]4(]4V2L=#)\GI.?"B+\.CM[&Q018&6W2U6L4!
M5"P620`F3Y5((Y"M^(PH82#5!7S:9K-9K58;C<;V]C9*#K#D]`S)M[E<[NVW
MWT:7P"F,0U!N37+F=<*2L:+_1F3IQQ+;F;'$\AT2X#H#@X-'R27'F)^/Q*D)
MMZ0.>T<MED6QN;G)?9;+)51[P3%=BE4=Q*D0'&>G2*/5&>QCBEBU$MB`P!0Z
M)A()F]U'LS$_`H-]!V0\T2UAF=KSU<GY=(*?D%4X6AK?"!_"_Y6#]1H8`H9D
M,FE5'\4QG'B1!0;TU6M]8TTF#1-AP-ELYB2#<32&`G(X.H3(,.V=Q;MKS68;
M%1&H/81L<*A:D@!H/[@&#"'5`3I8_'JI0J$@1[@J>_E>":X:"_V5;A&'DV-Z
MB>G4[P1['ZN&UFJU\^?/@W^SMK8&ANK9LV=I=JO5:K?;%(XZ]ZS5:MUNUX&M
MEYUY&NC74,MJ%=[LJH@?E*>^N6@G@\V_556A+G"LUDJE`GVN!336I.4#;R<#
MDLB,]H'#PT/M'GJ*S;V7:\/..AN&6F4@,<$<"XT,?Q:@EB0O1:TF>*W\%3X/
M)LE\/I?-$!Q3'03'U=<JG!/5C31^QT^G]2(K@NI0EH:`@OO]OC)49?2RX9"G
M8(DKB(F=,J#D-$95IHZZ[]NE]7K=7D9H:']_G[TK]`ZT$!.(B6=#<-:\M+OK
M8#"H5JM*$P78UG%]#H=#)C]N2E)AQ0YEP^,1YHWO0F6V*&N:V*/3L4)LUF0`
MU=QN%"K+="IIA\/ADR=/>`I,LRKT#8XK!3"QU#P*LZ&"%VHNCP!/2_DXM,HN
M.I[B;/64%#J3WQEW"_5L-QD52OCVX0N!3B4V6*U6-31,=;G"*;QG:VHVFZ3+
M4D[/!:)X9:6\_?;;5%=R4LAQQA#H3&DT&EBMVO.Y@-N2HH(5JINK#V/,V-C.
MC"666`)94+`\+Q8+W,DZMX3EX!\Y.F\LD*-.-4`=5=O9[_>!2^%N#LJ"529D
M75BU0"B4@:&)5RD4AI,T2YY2K595VZE7D/=1V5;``/`69'C^^<]_UGM-IU.!
MC],`YVQV:FS0OSG=.8I4K,5SH;D#SX#F80R+<D`!3*FD$-\K)'BB!0(IKJ]<
M6M;*7"XGPH-5(2"KHSNN65M[R9U!TK-^<1FBRKM^_/BQ5"L9I:H:Y;-\ZA0@
MZ0XV`&L5FDJE(A>#&.V#XVIA9[!\*\M7**-5!-LG]EDV:KVUM05;23J=%JFZ
MLG/]>^*5#U8`8X:.T2K"PVJUZI0@`G++_0>#@9.<IEGD%Q&1XJO^`</),3RL
MD2!H5FL5[.WM.>C3H3U`U5FGTX'Q0C^'XU=;S7P^E]D96A)&*$GP77X^_&0R
M49(JKZS<5^Y?K5;)D`\,K1':)UH['C%FK^YCPVCB/E'&K*A]A(C&!6PL?BZ]
MP\\Q'`Y3J11./=Y(9%'L5RH?P#+I]7IVI>_M[3D&@#@/[5@XVX7>SB8V!T\'
M_ZV3PBGM4PJH?P>ZE*B1,CDAVU![;&6$4-."XQ3]P\-#NIH1M$@SMGH<Y-+)
M9,+/A2<7NG!HI&:[2C^T`('/T5NSMP^'PU:K)<Z/Z72JE1X<%U%S3_BE[49J
M`X/.`4=MOQ`$`H,;Q#<VM;A2J<A_IU6I9<[.#%D7C;>E`?XBTA+FA%*W:WP9
MD=!M:A5*TXD,6Z<7QP.(0UP(4A`C!T&POKXNPP_(V;-GS];K=;O[I=-IZNK9
MEW03-O.MK2W[%$*7.JQUT#2;39##X_S8V,Z,)9985@IE).2RXHR78U4;J)0_
MD2CXX$#3Z=1A/B2"82F;Y2S4ONPH9QR-.C6O7;NF8UA?6C`>%3LIAT?Y3B(>
MX/QS3@)(#H-C?D[IP8/!0-8RRH$2V(3^(OW5!Q+D08>'A^/Q&#U2V7&*?I!:
M+'MRE>;-\8P70"J(R#^M[NY8DA"91!BB]B>R_'T;QO88X*[.?6RLVW*B,FUL
M"A9/W-K:D@8\F\T$'R4S$IJ3B&Z1KF--&FM9.3K-JN-?/Q?E@),C5RP60_$\
MH^\6'*=MKZVM<0?5P<JH\'^.BH-UI-P\QS0*#`&LQ@MN`/OZ%CU2[;&PKB02
M:\&*5<41P('MG7N]'JM)S$!6(S\X.%!\1D,L?Y.US)W(K28)S#$VHL("X?Y<
MOZI^53N)'JT<"E\;7BP6-N:INDI"W"JL98M@>E0J%;P&2O*GL%/YZJ31ZIX6
M7F4\'@L1A.M[O=ZC1X\"4]HGOM#`9!J/1B.N)\_";JV4JMJ*`]X7BGEG0LJ^
MU4#+CV,O\[<+"_WB3!)K`O&:UI@\C<[-;54"K;7&G+3+I%JMSF8S>_]5=LM@
M,.`R)=Q2'1H<X^YP#3DRVLVL,T+KCCO0/UR)/>\T@`-(;$/9;):\V>"8/H1G
M[>[N8E7:*A*+42<7&TL,9%12-T.]2Q8I!SZD3J?C;!K"@5=K;:Z-[S5S9#0:
M6=PUBX\0ZN3RJ6NUDYP2!^@YA-IX0'H"DPVD7J6CY%SVMW0A>[7;;97;))-)
MG5G!,2#_N7/G@B#XP0]^@!W[3+,]EMC.C"66[[3D\_E"H4`I(YFBT@)5C:#-
M5&>&T`YU;AT='>%EI[B%+=[JN#KP9,=*0;%FB35[=*#:+$WM\K:DS8+$Z"`4
M*JPB(1'G'S54^7S^RI4K:JU(YQ0[G<UF_!##P#G`A)$K:-9"H=#O]^VS=(!9
M1G(GGB`2424P6X7,FGS6DTV_S68SJXBH,W6E-.8@"!AW"\NDZ_O]OE7O-$`:
M"T=-X8?,`0P5C;L8YVVQJ.QY>:FAW!"&ODVEMDJ,?>7G@^]3RZ4_^>ES7S'K
M"8;T4"4L-#,9S48E@H[MJAENAQYH7&:1)1H-U4TUOKHS'I!5@*+6\`!V17B,
M2DS09(!LT!8GH^DZ/"M<L+N[J]5JISTML5GK@<FMS>?SX*8$*_`M3U3X5L7G
M&8[)9,)L5P/D@P!V*)?+B5(8JUC3GF1O0$W5#&U-K%]>(3@&P=*5(@RDPJW7
MZ_%?;2D*?EIB1HLK.YU.#P\/;9Q'Y0;HS;3D67%H6<YL7\XDL9.0UEI6DE5,
MF'YX&1`LS;'9;$:^KFV_$]VE`QV*8.W&>@1]J^4`5G!PS%U9+I=7]<:J_<3&
M\8;#H1-75Z%$I],1>W-P7.*;2"1XNCBBB+R1J()?E5"\6J7^A!B,GVM"VC4U
MG4Z;S29XVM:,I[08E%J[5.WH1.!FV>J5Y7*I64VQP^EG$:[#KT-OT6FB*F*6
MB?J!M)V(.^#84MH1[93#6O<!=9SOY0QRG)*Q&AG;F;'$$DN4V!H_;;CV2+/J
M((#^HM;0#V4,<-Z+14T_U$U\WCPG$4Y:X'OOO6=5/<<``.:1STJ>'`P&#MP%
M;F;G3$57<Y0G#M'1:&3SIFB8Y24/CMDIX-*0QB/R%84R@F,:3X>5%.6LW6ZC
M5*GP+T*$5!1*%&%O:QDO[5DK%4K004*,T!T(&4'7%M$8FXHLH2!M.!R2]*5!
M)++M6`B6-?[HZ(CG,ME$HVKGX2JK[^5W)_LM]$/KP3'CJ%6O'?4E-/#H6`68
M.M;:W-W=U5`"LD*&7BJ5HK#P-(UGAJ!X$5LCQUY+%0<-A6%,42AJ)I,)L3OK
M]YG-9B)BM;8TUH5FJ6,)L#"CF7A"=[;3:-6!H8KI=KMR?JEM1)7%$$M-J0*5
M%GM)`4Q560N?4U'H8K%(/5YP'&)U7`#^PK=\)QL;&ZH=T#(7OY3%7N*VZEB+
M$7JBA#+!<!_KO"!=17'[$X-7VHZ$JBKCS6X.@<D$"9Z._I$/+_Y&"TCN0%);
M"UG%%/`)V[[U>WMW=Y?A@Q2:G%A^A;7&O]/IE$.0"7-X>)A,)E5)2Q$[>`'J
M,39)&)C@/B'H:MTZUOP&;<A"#.@UA0]G_;9V2U$)C)W_V@T5([A````@`$E$
M052&PZ&3TNR<AJ&5JZOV6\>C9.5KBF=R:#HNO&<R^9R+&5/?-+5[3JCA&DK$
M$DML9\822RR!54:IQZ`.$-L#!A$V5GL*ZMAP4JUD]6&2P6=E]3P=D^SOUI:S
MA@0@,?Y)X(/R6UO%'@`Z"V7J3*=3QU!)I],6ME$*)9J33Q<FPD-5X]`\7I:\
M7QU(K58+R$3;7?:X(NA'HA3/THL0._)?W%*;KM(+=W9V+(<[N(A^FIF4&)1@
M]`,%IH)CB`5[?OM4;]8QX9S<%MXC,/G2P=/%O1S/@*^006>518N4ZVNZOO/B
MY7$MBQ+6\8"LDKMW[[*:1'(C>\;V[:K`HQU?!J7?[\/00.V634\(CBN$_<"X
MHQJRNK76?!).$LL9,OF)*/H597P0EE"G_$`+<#48#`@L.%B[HICG,M[%H@>'
MBN):W,3/]!.^E]T05BF:>-`T=0DQI5(ID2[R[M0<*GU7'!5Z3?4_Y9WJ4B[`
MU0)X9F"R!D(C;]8-I&+L1"*A;$FUI%PNJ^5@B0<>TF^$TTJ[EE:6)4YT'$!.
M%G?HMB/L(L!+[8)U"#;8)*WUPD1R8'MM'U:K58:>Q@O&*3"9O<UFDRYUDLR=
M,TY,)Q#\.N^52J4JE<K>WIZ27&B>2%P"$P:T<U6N-/*NF3-:X,)^<QQ`C@G'
MR47-L`T\VNT:%"[!V_K>EFB_E?#8?#LJ=(A7N1B2R>0I\6:?S]1TV@8`F[,;
MVQ4=X:CBA(7RQ,+\VF/H69F38HGMS%ABB>7_/W)(OP'JH%JM+A:+;K>K5%A[
M5`AZQ]?>BL6BI020:]_1C=!O+&^UU1N<^AR=;=KN=08(%-'Q2JIA.A$Y/.QE
MJ@^,.("EB4($&AKB(U8`QIU5]Y/)9+?;%1N[[F\;;!/)]%+@9UHV"*L.RJA0
M"%0J9CJ=KM5J]+Q(.$4T8GM#"H$08GRQA7QTM:/-Z$7\#$]J2JT+P'*F2__0
M^XY&(QM!XH<JD_/%#IPSK"\#Q!]M:#:;/J[IJJ[6#]$O;<*M?64G>]`:I<[3
MQ3AO5URP`D#(]B%:&C:DU;PMUI>_9@N%@J)/>@23P<;J&7TUV%%8+4UH<%R\
MQQQ()I/6)O&A,J.52#]L"[7/:#2RB\CN2XXE3Q6<#-'%8D%6<&!0.M'^Q1:K
MX*WL;9:,"E^U@NAG=A*1+DZG4XK'[*+0+FKW@;6U-:V4=#I]<'``;P?6K%6[
M)Y.)DXT<NA?U>CT"U':(':XF71\ZHX`Z<]:L=8CPLIHASBQ5[D;P-%25W1!L
MNH3=1540(?<6QIC_RL[TZW:[Q6+164V\YG`X=)"B58)K;V(AA8/CE./`8Y&U
M?6(?)QO)>5/?)E1>,5WGKP7E9B^7R^?;$IT-Q#DZ0[T2H4ORZ\;(<6[N>$``
M`;(GU"J63MM+MC@SEEAB.S.66%Z`@+6@[5AX?3KF55X2')-,"C'<*CTRYV:S
MV>'AH;)G,6DH!;0.0F70!<9_+W1XY_R0XJ)V"F?%T0Q\QVJ]7G>T"NSJT!]*
MM>(4Q\A<+I?"1@H\?@4=L=9G/YO-['%%?UK_ZX,'#]05,@_T5[!D5&+*@ZQF
M3_.X`P^BUDN018X2[\"THHZLXA[L]7I2)7E0M]OU51;K@"@4"MRM7J\O%@M9
MSC8KVP%L#(X=WBA2SQ&-_)J*?YY5?-Y1ROE.TSS-88V^-%3KHY'AC3<'OD$_
M6.TDHSKNF%"KP#+<6L7142B%6V/M#368Y'#'D>%\ED&5S^<A/@F.,PEU-ZG4
M;!<*;=F":DNJZ2SSX.D`K]:7;;:^%!$.#>.'`J>Q>P5-Y;D`SZH-3NQ7V$7T
MJG8&K!T^B*TG,(003"&EC\)VHQ%QR"0LX=-T.@72&<Y#X&=M/JIN$KJU2FR>
MJE"['4Q4/F@3<W8M#:6(B.'+4:S8&0B*]QPWQ"IQDDOM3306(+?QCLUF4_`_
MZ72Z7"XS!.2R.G-8"&1*?K93BQ0`_]'BYE7[;7PRE4K!S0@9LBTZU3QDRH%2
M6R@41+ZBN+W?:>IV(07XMI/X8"P2>VB7KOK3JE(.!]O6/C'T^Z\UGBD)-0N)
M9-H=.*(8)*ZQC"6V,V.)Y6N4LV?/IM-I6ZWA6!3VE"5-RQ)78/S,9C-'4;#)
M)\ED4O_5J6!!:W58AJKFJ53*AY%0S8QS$/H.5$M<KC8[-JJJ*^4DEIIN=73:
MZ:AKZKH(#/?'CQ_/YW.2)-543CXIT#=OWK3ML2R1$%2H?VBJ$B#1C>[?O^_7
MT_J:BFX[&`S45_("(,UF4ZT2J*^>I91C>\"3YYE*I2P[16`P_4('UT$9?=7%
MR5H\C5\\]!H_.]VFBUMV!+M4;7&R4+(L7T)@DKVM<*7"/K)G+,2KG6EJB1@U
M^OV^)K^:1SF<;QAP\W*YK,=)R7;*B87V3'VF.D?D''[7V;5I:U/5/$N.IQY6
MP@)8LLZ8XH22'PI3G]<4HXF(3-@/94PZ>1QBW"5$IL@AVZEL.=$SBK'3-DGV
MS'@\/C@X('<7AP)YGKI22*0T/J)8SF[R),8[?$*^F\E!JQX,!C)6>2CVDK)Y
ME6JA&UJ'G2:;#W_ML`?W^WT+7"QP&ILH2U6MY@P0W!:DA]O2L99EE/I;NX7N
M[^\[6,?P@I9*)=P!L-V(^\J>>H5"X<LOOU09/(_#(%?;2*X9#`:4[&)S!B;"
M[SR=7534RK[@""@6BX):#96(4.<JG*15=F/$4[Z!_?:4WL9OJY&QQ'9F++%\
MUX5456NTR`TLMLG`@#V@@CCGKA,SR60RSNDH[<$>;[Z+T2^Q")ZF\++'AG]R
MB$L]5&N7^/D\]^_?M\H*A&E6E[458O8^P0J20^=*4EA%!V?U&,@)2)?R]7+!
M]/->5K?H]_O4,3J#0K&?'<I0F[/;[=)(%6Y)F?/C'B*JEEVMX*J:E,OET(!M
M(\?CL;15ZWK0;+$7O-*2S68UJ4`Y/LVO@)+B)[YZ=R*IIKU`M"@VSUP.&O&.
M^--5,T>1$'Y^X\8-YP4!I$$MGDZGFIRK3&AG)@1/%_<R9^RZ\`OA^(GF,X`Z
MRD$-GHY%^%N'C&1-:2<I],Z=.VP[FL].)$?IM<*;#4ST7L.A)HF-DS]QF0K>
M(%:Q?<(-\87)QB#7P](JVMT5C$U<!IH`\B,XG2#V5">]WYHZB41"9IBVM7Z_
M[QAXVL=\[X-L.6?WLQ.`PEJ'3T6H:9JH:D8BD<!P=?;>Y7+9;K<SF0RS@GG(
M;8G#4S)@G\5^>__^?<=3:3^`6:5R<3OM:1+FJ.#N!/)$L+W5:G&9!2$'P4[!
M3')P5+HOP]C"O"<2"0Q1V=C.J&G'<."@['')VNEVNZLP5\E%7[4IK:JWE+<E
M](G?O)QH.MKY&5=7QA+;F;'$\NW(<#BT6J/LO7P^SY$F1@$.O^%PV&@TK*4D
MIWN[W99JXJ`LA-9I^$==:'*734^R]PS-`PP-<OJ_=9`DOOCB"_^A.IQX5C:;
M56C4%A?I5O;8LZB`MB7B,;.`-X/!`#YH(:]*8\,VDVV`ESHPZ7R%0@$("IM`
M)7U==)0RO_WTLWP^C[9JTZ5"LXRX"?YRZ18*:DE;LL%GZMDB%)IL-OMZ0/;Y
M4_0T.6/*?R:U3V.-,:^^M:-FISV4CUK(&`FE4DF3P6KG063R&,)SR^7R8#`0
M9Z;6`DE]J*$VTU+STW$E6#>'G!KC\9BG%`H%1<Z9>)JWW$=ZO&Q(V!KL^PJR
M)=3WX?NV1J,1MZ4-2D;`NO#AP9;+)0:2144^.CK2KF*K9Y7?2YL%PR-K,)5*
MX8OA!859R@7R%@GIEY\/!@/ZAWX&U)0_0:>IB3293$B:D,]"DS"?S\/VZ4PD
MMA1K:0>&1\=)H02IV+=4@Z>S3D*G6;_?;[?;0NMAK[8S!'L/9P?I`!<N7-!^
M<G1T)*QLD*[T6_;`P$#RX/IDSAP=';7;;?P%#'<NE]O=W:6K.?M2J90EQK2O
MIAJ_3J?#3?SD&O)H(&]4!G5PC.XCPU7@L8R+K""`D31U:0"L)[ZO\,3P'1G[
M_7X_PI(D!KOJKZ&.W0A[TA+;O%1B%WXTS4DLL<1V9BRQ?%TB'='J&=;><T@:
M`<;P78G3Z50:\&`PL/@BL]G,+R,)3<Y1PIAC.OHGG$VEDTA[B+8\#P\/G4B1
M#B&TP%ZO)P`/6C693'*YG)X(WQVM0O.`6M!Y$-^H*ZSZJ_"I=#+E-/K5<?;@
M3":3A'2FTZFZQ08$>")D#`RNX\K5N^LIJ*J6_2\"OP&UB>EA85U$]F!_&X$<
M&SS-D_GZR>GQ).S,L;U7+!;3Z72_WV>DH(=U%$V+"BNXU^`82XD[*]<T-/9N
MUQ$/ZG0Z"G<[D2XGM]8Q?55UA@X]'H^SV2QU>BBC(L7I=KN4%UJ0%2<61P<R
MQV1'A4XGWDL3FRW+1YGV=P.IR*QW']=7G(?J21
| (no subject) [message #719607 is a reply to message #719475] |
Member |
Tom,
AWT 2-20ms
M`UC!SJ4\SU<G`-<9_V
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M?2BV6BU)1ZO$=+CL
M+WX<&D#5OIB&B$]B
| (no subject) [message #719612 is a reply to message #719475] |
Member |
Tom,
AWT 2-20ms
M`UC!SJ4\SU<G`-<9_V
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M?2BV6BU)1ZO$=+CL
M+WX<&D#5OIB&B$]B
| (no subject) [message #719617 is a reply to message #719475] |
Member |
Tom,
AWT 2-20ms
M`UC!SJ4\SU<G`-<9_V
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M?2BV6BU)1ZO$=+CL
M+WX<&D#5OIB&B$]B
| (no subject) [message #719622 is a reply to message #719475] |
Member |
Tom,
AWT 2-20ms
M`UC!SJ4\SU<G`-<9_V
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M?2BV6BU)1ZO$=+CL
M+WX<&D#5OIB&B$]B
| (no subject) [message #719625 is a reply to message #719475] |
Member |
Tom,
AWT 2-20ms
M`UC!SJ4\SU<G`-<9_V
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M?2BV6BU)1ZO$=+CL
M+WX<&D#5OIB&B$]B
| (no subject) [message #719629 is a reply to message #719475] |
Member |
Tom,
AWT 2-20ms
[Updated on: Sat, 15 October 2011 06:59] Report message to a moderator
| (no subject) [message #719635 is a reply to message #719475] |
Member |
Tom,
AWT 2-20ms
M`UC!SJ4\SU<G`-<9_V
MA=\E7&'N\@KJ0"<$4Z
MNO;BI;M7SYI?_(S9'/
M?2BV6BU)1ZO$=+CL
M+WX<&D#5OIB&B$]B
| (no subject) [message #719638 is a reply to message #719475] |
Member |
Tom,
AWT 2-20ms
[Updated on: Sun, 04 September 2011 00:20] Report message to a moderator
| Re: huge polyline performance [message #719800 is a reply to message #719680] |
Mon, 29 August 2011 00:54   |
Vijay Raj Messages: 603 Registered: July 2009 |
Although problem solved,i am curious why SWT is not performing well,
One thing i noticed is you are creating the Transform Resource again and again in each paint,Why not create it once in the constructor and reuse it..
Also setAntialias(SWT.ON); should also help
Try it i think this will make thire performances match.
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
[Updated on: Mon, 29 August 2011 07:10] Report message to a moderator
| Re: huge polyline performance [message #719801 is a reply to message #719800] |
Mon, 29 August 2011 00:57   |
And i think this repeated posting is a bug,this has happened secound time in two weeks.
Vijay
| Re: huge polyline performance [message #737721 is a reply to message #721553] |
Sat, 15 October 2011 06:57  |
Member |
Sorry, my follow-up is long overdue.
Here is what I did - in case someone is interested.
Although I worked with JLabel and AWT's 2D Graphics, I'm sure it's also doable with SWT as well.
//-- Creating the polyline with the zillion data point
GeneralPath polyline = new GeneralPath(GeneralPath.WIND_EVEN_ODD, samples.length);
//-- Painting a BufferedImage of the wave graph .
//-- The calculation takes place for each resize event.
//-- In order to avoid performance issues, resize events that
//-- are too close in time are collapsed (code omitted here).
BufferedImage waveAsImg = new BufferedImage(w, h, BufferedImage.TYPE_INT_ARGB);
Graphics2D g2 = (Graphics2D) waveAsImg.createGraphics();
g2.translate(...); //-- resize to fit JLabel (=my canvas)
g2.scale(...);
g2.draw(polyline);
g2.dispose();
//-- During paint only the memory-buffered graph is repainted.
//-- This allows for animations.
public void paintComponent(Graphics g) {
super.paintComponent(g);
Graphics2D g2 = (Graphics2D) g.create();
g2.drawImage(img, null, 0, 0);
Current Time: Thu May 23 07:40:55 EDT 2013
Powered by FUDForum. Page generated in 0.03818 seconds
