Home » Eclipse Projects » Mylyn » unhandled loop exception
unhandled loop exception [message #714356] Wed, 10 August 2011 08:01 Go to next message
dominik is currently offline dominik
hello
Every time I click on some trac comment inside eclipse I have: "Unhandled event
loop exception" and soon after that prompto to exit Eclipse.
The problem is present in few versions, I just updated to 3.6.1 and it's still
here. Is there any path for it?
I tried to find out some bugzilla report about problem but I found only very
similar stack traces, here is mine:
org.eclipse.swt.SWTError: Item not removed
at org.eclipse.swt.SWT.error(SWT.java:4303)
at org.eclipse.swt.SWT.error(SWT.java:4192)
at org.eclipse.swt.SWT.error(SWT.java:4163)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Tree.removeAll(Tree.java:3962)
at org.eclipse.jface.viewers.TreeViewer.removeAll(TreeViewer.java:325)
at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractTreeViewer.java:1474)
org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1422)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:403)
org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1383)
org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(AbstractTreeViewer.java:1469)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:280)
at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1669)
org.eclipse.mylyn.internal.tasks.ui.editors.TaskEditorOutlinePage.setInput(TaskEditorOutlinePage.java:44)
org.eclipse.mylyn.tasks.ui.editors.AbstractTaskEditorPage.updateOutlinePage(AbstractTaskEditorPage.java:1139)
org.eclipse.mylyn.tasks.ui.editors.AbstractTaskEditorPage.getAdapter(AbstractTaskEditorPage.java:1113)
at org.eclipse.mylyn.tasks.ui.editors.TaskEditor.getAdapter(TaskEditor.java:543)
org.eclipse.wst.sse.ui.internal.CustomFilterPropertyTester.test(CustomFilterPropertyTester.java:27)
at org.eclipse.core.internal.expressions.Property.test(Property.java:58)
org.eclipse.core.internal.expressions.TestExpression.evaluate(TestExpression.java:99)
org.eclipse.core.internal.expressions.CompositeExpression.evaluateAnd(CompositeExpression.java:53)
org.eclipse.core.internal.expressions.WithExpression.evaluate(WithExpression.java:72)
org.eclipse.ui.internal.services.EvaluationResultCache.evaluate(EvaluationResultCache.java:74)
org.eclipse.ui.internal.services.ExpressionAuthority.evaluate(ExpressionAuthority.java:165)
org.eclipse.ui.internal.services.EvaluationAuthority.refsWithSameExpression(EvaluationAuthority.java:155)
org.eclipse.ui.internal.services.EvaluationAuthority.sourceChanged(EvaluationAuthority.java:129)
org.eclipse.ui.internal.services.ExpressionAuthority.sourceChanged(ExpressionAuthority.java:311)
org.eclipse.ui.internal.services.ExpressionAuthority.sourceChanged(ExpressionAuthority.java:290)
org.eclipse.ui.AbstractSourceProvider.fireSourceChanged(AbstractSourceProvider.java:99)
org.eclipse.ui.internal.services.WorkbenchSourceProvider.checkActivePart(WorkbenchSourceProvider.java:401)
org.eclipse.ui.internal.services.WorkbenchSourceProvider.checkActivePart(WorkbenchSourceProvider.java:300)
org.eclipse.ui.internal.services.WorkbenchSourceProvider$1.partDeactivated(WorkbenchSourceProvider.java:247)
at org.eclipse.ui.internal.PartListenerList$4.run(PartListenerList.java:117)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.PartListenerList.fireEvent(PartListenerList.java:57)
org.eclipse.ui.internal.PartListenerList.firePartDeactivated(PartListenerList.java:115)
at org.eclipse.ui.internal.PartService.firePartDeactivated(PartService.java:238)
at org.eclipse.ui.internal.PartService.setActivePart(PartService.java:300)
org.eclipse.ui.internal.WWinPartService.updateActivePart(WWinPartService.java:134)
at org.eclipse.ui.internal.WWinPartService.access$0(WWinPartService.java:125)
org.eclipse.ui.internal.WWinPartService$WWinListener.partDeactivated(WWinPartService.java:50)
at org.eclipse.ui.internal.PartListenerList2$4.run(PartListenerList2.java:115)
at org.eclipse.ui.internal.PartListenerList2.fireEvent(PartListenerList2.java:55)
org.eclipse.ui.internal.PartListenerList2.firePartDeactivated(PartListenerList2.java:113)
at org.eclipse.ui.internal.PartService.firePartDeactivated(PartService.java:242)
org.eclipse.ui.internal.WorkbenchPagePartList.fireActivePartChanged(WorkbenchPagePartList.java:57)
at org.eclipse.ui.internal.PartList.setActivePart(PartList.java:136)
at org.eclipse.ui.internal.WorkbenchPage.setActivePart(WorkbenchPage.java:3636)
at org.eclipse.ui.internal.WorkbenchPage.requestActivation(WorkbenchPage.java:3159)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane.java:279)
at org.eclipse.ui.internal.EditorPane.requestActivation(EditorPane.java:98)
at org.eclipse.ui.internal.PartPane.handleEvent(PartPane.java:237)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1444)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2317)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4555)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2058)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4970)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2520)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4606)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3090)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3734)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
I'm using indigo with pdt, mylyn, trac etc.
Eclipse for PHP Developers
Version: Indigo Release
Build id: 20110319-2305
(c) Copyright Eclipse contributors and others 2000, 2011. All rights reserved.
Visit http://eclipse.org/
This product includes software developed by the
Apache Software Foundation http://apache.org/
If this problem should be reported in bugzilla let me know, if it's something
other that needs configuration only - please help me to solve it.;
/dmc
Re: unhandled loop exception [message #717388 is a reply to message #714356] Sat, 20 August 2011 06:32 Go to previous messageGo to next message
Steffen Pingel is currently offline Steffen Pingel
The stack trace is usually an indication that the system is out of
resources. lease feel free to comment on this bug:
300583: No more handles / Item not removed exception when searching in tasks
https://bugs.eclipse.org/bugs/show_bug.cgi?id=300583
Particularly steps to reproduce the problem would be very helpful to
identify any resource leaks.
Steffen
dominik wrote:
> hello
> event loop exception" and soon after that prompto to exit Eclipse.
> still here. Is there any path for it?
> very similar stack traces, here is mine:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at
> org.eclipse.core.runtime.Platform.run(Platform.java:888) at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.ui.internal.PartList.setActivePart(PartList.java:136) at
> at
> at
> at org.eclipse.ui.internal.PartPane.handleEvent(PartPane.java:237) at
> org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) at
> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053) at
> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077) at
> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058) at
> org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1444) at
> org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2317) at
> org.eclipse.swt.widgets.Control.windowProc(Control.java:4555) at
> org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341) at
> org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1610) at
> org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2058) at
> org.eclipse.swt.widgets.Display.windowProc(Display.java:4970) at
> org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method) at
> org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2520) at
> org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80) at
> org.eclipse.swt.widgets.Control.windowProc(Control.java:4606) at
> org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method) at
> org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3090) at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3734) at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696) at
> org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660) at
> org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494) at
> org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674) at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149) at
> at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> at
> at
> at
> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
> sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at
> java.lang.reflect.Method.invoke(Unknown Source) at
> org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622) at
> org.eclipse.equinox.launcher.Main.basicRun(Main.java:577) at
> org.eclipse.equinox.launcher.Main.run(Main.java:1410) at
> reserved. Visit http://eclipse.org/
> something other that needs configuration only - please help me to solve
> it.;
> /dmc
Re: unhandled loop exception [message #719189 is a reply to message #717388] Fri, 26 August 2011 06:31 Go to previous message
This not happens always, but it's very often error.
What resources are running out? What is mylyn doing when You click on comment?
I checked memory and it's 588MB/1332MB (when maximum is set to 2GB). What else
is too low?
/dmc
Previous Topic:Task UI context handling in the CDT perspective, local task
Next Topic:SVN commit comments are not updated when Jira issue is active
Current Time: Mon May 20 11:49:17 EDT 2013
Powered by FUDForum. Page generated in 0.02860 seconds
