Home » Modeling » BPEL Designer » About developing BPEL Designer......
About developing BPEL Designer...... [message #717191] Fri, 19 August 2011 10:47 Go to next message
huhai  is currently offline huhai
sorry,i am not very goog at in english ...
when i using BPEL Designer to structure our software.
In assign Node, autogeneration the code :
<bpel:copy>
 <bpel:from variable="qualityRemark"></bpel:from>
 <bpel:to part="parameters" variable="storeQualityRemarkRequest">
 <bpel:query
queryLanguage="urn:oasis:names:tc:wsbpel:2.0:sublang:xpath1.0">
 <![CDATA[sdl:sensorDataList/wg:waterGauge/wg:qualityRemark]]>
 </bpel:query>
 </bpel:to>
 </bpel:copy>
how can I let the BPEL Designer autogeneration the code like this:
<bpel:copy>
 <bpel:query
 <![CDATA[sdl:sensorDataList.wg:waterGauge.wg:qualityRemark]]>
 </bpel:query>
 </bpel:to>
 </bpel:copy>
I really need some help,may be chang the souce.
where should i do......
Re: About developing BPEL Designer...... [message #718182 is a reply to message #717191] Tue, 23 August 2011 10:17 Go to previous message
Robert Brodt is currently offline Robert Brodt
I would start by looking at org.eclipse.bpel.model.impl.QueryImpl - you can probably hack in whatever you need there.
Previous Topic:Problem Creating BPEL Process File
Next Topic:BPEL Expressions
Current Time: Fri May 24 06:06:27 EDT 2013
Powered by FUDForum. Page generated in 0.02654 seconds
