Home » Modeling » XSD » Problem with attributeGroups
Problem with attributeGroups [message #718124] Tue, 23 August 2011 06:28
Paul Cooper is currently offline Paul Cooper
I've hit a problem with referencing attributeGroup constructs across namespaces within an inheritance hierarchy. I'm getting the following error message: "The attribute 'http://ns3#problemAttribute' must present as in the base" at line 7 and column 10 of my sample WSDL document.
I hit this problem with a complicated WSDL document from the finance industry, the sample below is what remains after my attempts to simplify the recreate as far as possible. It sill involves several namespaces though.
I'm using XSD 2.6.1, but I've recreated the issue with XSD 2.7.
I can't see any reason for the schemas to be invalid, and if I replace the attributeGroup reference at line 20 with the equivalent attribute currently commented out at line 21, then everything works as expected. So the problem seems to be specifically with attributeGroups. I may of course have done something silly, but I've not found anything in the schema specification to explain this behaviour.
Any assistance will be appreciated!
Paul
<?xml version="1.0" encoding="ISO-8859-1"?>
<wsdl:definitions xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:wsdl="http://schemas.xmlsoap.org/wsdl/" xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/" xmlns:ns3="http://ns3" xmlns:ns2="http://ns2" xmlns:ns1="http://ns1" targetNamespace="http://ns1">
   <wsdl:types>
      <xs:schema targetNamespace="http://ns1">
         <xs:import namespace="http://ns2"/>
         <xs:element name="tagName" type="ns1:tagNameType"/>
         <xs:complexType name="tagNameType">
            <xs:complexContent>
               <xs:extension base="ns2:tagNameBaseType"/>
            </xs:complexContent>
         </xs:complexType>
      </xs:schema>
      <xs:schema targetNamespace="http://ns2">
         <xs:import namespace="http://ns3"/>
         <xs:complexType name="rootType"/>
         <xs:complexType name="tagNameBaseType">
            <xs:complexContent>
               <xs:extension base="ns2:rootType">
                  <xs:attributeGroup ref="ns3:otherAttrGroup"/>
                  <!--  <xs:attribute ref="ns3:problemAttribute"/> -->
               </xs:extension>
         </xs:complexType>
      </xs:schema>
      <xs:schema targetNamespace="http://ns3">
         <xs:attributeGroup name="otherAttrGroup">
         </xs:attributeGroup>
         <xs:attribute name="problemAttribute" type="xs:string"/>
      </xs:schema>
   </wsdl:types>
   <wsdl:message name="message">
      <wsdl:part element="ns1:tagName"/>
   </wsdl:message>
   <wsdl:portType name="PortType">
      <wsdl:operation name="operationName">
         <wsdl:input message="ns1:message"/>
      </wsdl:operation>
   </wsdl:portType>
   <wsdl:binding name="BindingName" type="ns1:PortType">
      <soap:binding style="document" transport="http://schemas.xmlsoap.org/soap/http"/>
         <wsdl:input>
            <soap:body parts="messagepart" use="literal"/>
         </wsdl:input>
      </wsdl:operation>
   </wsdl:binding>
</wsdl:definitions>
Previous Topic:XSD Complex Type Inheritance
Next Topic:Rstricting Content of multiple nodes
Current Time: Tue May 28 18:35:24 EDT 2013
Powered by FUDForum. Page generated in 0.02811 seconds
