| using the trim() on Strings [message #717001] |
Thu, 18 August 2011 23:42  |
vrm Messages: 31 Registered: June 2011 |
Member |
On the EOL String primitive type , the split() does not seem to work with a "." as the delimiter.The same is the case with replace().
For instance :
var str:String = "hello.world";
var seq:Sequence;
seq = str.split('.');
From the above code,I expect the sequence to hold two objects,but that is not the case.
What am I missing here ?
| Re: using the trim() on Strings [message #717103 is a reply to message #717001] |
Fri, 19 August 2011 06:20  |
Louis Rose Messages: 427 Registered: July 2009 Location: York, United Kingdom |
vrm wrote on Thu, 18 August 2011 23:42On the EOL String primitive type , the split() does not seem to work with a "." as the delimiter.The same is the case with replace().
For instance :
var seq:Sequence;
Hi vrm,
The short answer: to match a full stop with split or replace, use the following argument: "\\."
var seq:Sequence;
seq = str.split('\\.');
The long answer: the parameter to split() (and to replace()) is a Java regular expression. The full stop has special significance in regular expressions, so it needs to be escaped with a backslash, and we get: "\." However, the backslash is the Java escape character in a string literal, so we must escape the backslash, and we get: "\\."
Louis.
FUDForum. Page generated in 0.06714 seconds
