Home » Eclipse Projects » Nebula » Submit a new widget to Nebula project - Full calendar / Planner
Submit a new widget to Nebula project - Full calendar / Planner [message #716960] Thu, 18 August 2011 17:48 Go to next message
Patrik Dufresne is currently offline Patrik Dufresne
Hi All,
I've been working on a widget recently and I really want to get it into Nebula as the widget is likely to be used in many business application.
The Widget is a full calendar (a la Outlook) that displayed events. Similar widget already exists but it doesn't fit with SWT api and doesn't provide a Viewer.
See screenshot :
http_://i51.tinypic.com/2rqp1e8.png
http_://i53.tinypic.com/291or40.png
http_://i55.tinypic.com/2r3jfva.png
As you may see, some work is still required :
* Display day of month in Month view
* Display a small arrow if a long event doesn't start withing the displayed time range.
* Add Viewer editor
* Provide a default drop target effect
Here is snapshot for those who want to try it.
http_://patrikdufresne.com/2011-08-18-planner.zip
Re: Submit a new widget to Nebula project - Full calendar / Planner [message #717042 is a reply to message #716960] Fri, 19 August 2011 02:32 Go to previous message
Thomas Schindl is currently offline Thomas Schindl
To bring a widget to nebula you simply file a bug [1] and attach your
sources. Aferwards please post to nebula-dev mailinglist (you need to
subscribe to the list first) that you want to contribute this widget.
We can then go on with the contribution process.
Tom
[1]https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Nebula&component=Core
Am 18.08.11 23:48, schrieb Patrik Dufresne:
> Hi All,
> See screenshot :
> * Add Viewer editor
Previous Topic:Need help on how to disable Table Combo Text Scrolling.
Next Topic:CalendarCombo - in an editor part - bug found
Current Time: Tue May 21 10:11:42 EDT 2013
Powered by FUDForum. Page generated in 0.01778 seconds
