Home » Eclipse Projects » EclipseLink » JPA (EclipseLink) can't seem to handle an inheritance hierarchy 3 levels deep(EclipseLink and inheritance hierarchy)
JPA (EclipseLink) can't seem to handle an inheritance hierarchy 3 levels deep [message #716795] Thu, 18 August 2011 09:38 Go to next message
Mika  is currently offline Mika
The EclipseLink implementation of the JPA seems to have problems processing the following class hierarchy anyone have any ideas why?
    public interface X {
    	String code();
    @Entity
    @Inheritance(strategy = InheritanceType.JOINED)
    public class XImpl implements X {
    	@Id
    	@Column(name = "code")
    	String code;
    	public XImpl(String code) {
    		this.code = code;
    	public String code() {
    		return code;
    public interface Y {
    @Entity
    public abstract class YImpl implements Y {
    	@Id
    	@OneToOne(targetEntity = XImpl.class, cascade = { CascadeType.PERSIST,
    			CascadeType.MERGE })
    	@JoinColumn(name = "code")
    	protected X x;
    	public YImpl(X x) {
    		this.x = x;
    @Entity
    public class Z extends YImpl {
    	public Z(X x) {
    		super(x);
The following exception occurs:
    Caused by: java.util.NoSuchElementException
    	at java.util.AbstractList$Itr.next(AbstractList.java:350)
    	at org.eclipse.persistence.internal.jpa.metadata.MetadataDescriptor.getPrimaryKeyField(MetadataDescriptor.java:972)
    	at org.eclipse.persistence.internal.jpa.metadata.accessors.MetadataAccessor.getReferencedField(MetadataAccessor.java:398)
    	at org.eclipse.persistence.internal.jpa.metadata.accessors.MetadataAccessor.getReferencedField(MetadataAccessor.java:386)
    	at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.addMultipleTableKeyFields(EntityAccessor.java:181)
    	at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.processInheritancePrimaryKeyJoinColumns(EntityAccessor.java:1009)
    	at org.eclipse.persistence.internal.jpa.metadata.inheritance.InheritanceMetadata.processInheritanceSubclass(InheritanceMetadata.java:284)
    	at org.eclipse.persistence.internal.jpa.metadata.inheritance.InheritanceMetadata.process(InheritanceMetadata.java:219)
    	at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.processInheritance(EntityAccessor.java:986)
    	at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.processTableAndInheritance(EntityAccessor.java:1200)
    	at org.eclipse.persistence.internal.jpa.metadata.accessors.classes.EntityAccessor.process(EntityAccessor.java:589)
    	at org.eclipse.persistence.internal.jpa.metadata.MetadataProject.processStage2(MetadataProject.java:1541)
    	at org.eclipse.persistence.internal.jpa.metadata.MetadataProcessor.processORMMetadata(MetadataProcessor.java:485)
    	at org.eclipse.persistence.internal.jpa.deployment.PersistenceUnitProcessor.processORMetadata(PersistenceUnitProcessor.java:454)
    	at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.predeploy(EntityManagerSetupImpl.java:1081)
    	... 31 more
Re: JPA (EclipseLink) can't seem to handle an inheritance hierarchy 3 levels deep [message #716914 is a reply to message #716795] Thu, 18 August 2011 15:02 Go to previous message
Chris Delahunt is currently offline Chris Delahunt
The Z class should not have the @Inheritance annotation as it will use its parents, but there should be a better exception if that is the cause.
What version of EclipseLink are you using, and can you try the latest nightly builds? Can you also try creating a basic mapping for your the code field and marking it as YImpl's ID and setting the OneToOne to X as insertable=false, updateable=false ?
Best Regards,
Chris
(no subject) [message #716918 is a reply to message #716795] Thu, 18 August 2011 15:02 Go to previous message
Best Regards,
Chris
Previous Topic:JPA BigDecimal scale difference between Oracle and DB2
Next Topic:(no subject)
Current Time: Sun May 19 04:05:13 EDT 2013
Powered by FUDForum. Page generated in 0.01565 seconds
