Home » Eclipse Projects » Rich Client Platform (RCP) » error in context sensitive help with eclipse 3.6.2(null pointer exception in Share Project wizard)
error in context sensitive help with eclipse 3.6.2 [message #716543] Wed, 17 August 2011 12:29 Go to next message
Jane M.  is currently offline Jane M.
When my plugin was installed on eclipse 3.6, context sensitive Help would display for the extensions to the Share Project wizard when the '?' was selected at the bottom of the page. When we upgraded to eclipse 3.6.2 we get a null pointer exception for the same action, see below. Please advise if I should report this as a bug. It also occurs in eclipse 3.7. For the rest of our views, and dialogs pressing F1 displays eclipse default Help. Only for the wizard is this a problem. Thanks.
at org.eclipse.help.ui.internal.views.ContextHelpPart$SearchTerms.add(ContextHelpPart.java:430)
at org.eclipse.help.ui.internal.views.ContextHelpPart.computeSearchTerms(ContextHelpPart.java:456)
at org.eclipse.help.ui.internal.views.ContextHelpPart.updateSearchExpression(ContextHelpPart.java:394)
at org.eclipse.help.ui.internal.views.ContextHelpPart.updateSearchExpression(ContextHelpPart.java:293)
at org.eclipse.help.ui.internal.views.ContextHelpPart.handleActivation(ContextHelpPart.java:318)
at org.eclipse.help.ui.internal.views.ContextHelpPart.setFormInput(ContextHelpPart.java:707)
at org.eclipse.ui.forms.ManagedForm.setInput(ManagedForm.java:238)
Re: error in context sensitive help with eclipse 3.6.2 [message #716725 is a reply to message #716543] Thu, 18 August 2011 04:47 Go to previous message
Dani Megert is currently offline Dani Megert
> in eclipse 3.7.
Thanks for reporting this. I filed https://bugs.eclipse.org/355041 for
you. Until there is a fix you can simply set the wizard title in your
code to workaround the problem.
Dani
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
Previous Topic:Import Wizard does not appear
Next Topic:Custom listener for close RCP application
Current Time: Sat May 25 09:37:16 EDT 2013
Powered by FUDForum. Page generated in 0.01630 seconds
