Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Are there any other debugger engine that DLTK is supporting than Komodo ActiveState?
Are there any other debugger engine that DLTK is supporting than Komodo ActiveState? [message #642381] Wed, 01 December 2010 02:01 Go to next message
Marcus Granath is currently offline Marcus Granath
Hi!
To be able to debug Tcl with DLTK I need to have an debug engine.
If a user do not have a license of Komodo ActiveState, are there any other debug engines to be able to debug Tcl with Eclipse (and DLTK)??
http://aspn.activestate.com/ASPN/Downloads/Komodo/RemoteDebu gging
Or do all users that need to debug Tcl buy an Komodo ActiveState license?
Are there any free and good working debug engines for Tcl?
Are there or will there be any debug engines included in DLTK for the future, and that case when is that then planned?
We are simply a couple of users that need to be able to debug Tcl and are not sure if we then need to buy Komodo licenses for all the users to be able to use the debug engine together with DLTK - or if there are other debug engines to use?
Best Regards
/Marcus
Re: Are there any other debugger engine that DLTK is supporting than Komodo ActiveState? [message #716258 is a reply to message #642381] Tue, 16 August 2011 15:55 Go to previous messageGo to next message
*bump*
No feedback on this one yeat?
Nobody got any info regarding this?
/Marcus
Re: Are there any other debugger engine that DLTK is supporting than Komodo ActiveState? [message #716672 is a reply to message #716258] Wed, 17 August 2011 23:58 Go to previous message
Timothy Wall is currently offline Timothy Wall
Any debugger that speaks DBGP should work. I'm not familiar with TCL debuggers, but you should be able to quickly determine if there's a DBGP-based alternative.
Previous Topic:Problem marker displays incorrect Resource for error
Next Topic:[BUILD] M-M201108170548-201108170548
Current Time: Mon May 20 01:41:36 EDT 2013
Powered by FUDForum. Page generated in 0.01491 seconds
