Home » Modeling » OCL » OCLSettingDelegate extension
OCLSettingDelegate extension [message #714659] Thu, 11 August 2011 04:12 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising name
According to my experience, OCLSettingDelegate is not thread safe. I need to calculate the values of attributes of all classes for 1000 models. If i do it in single thread then it takes a lot of time (low performance). If i use multi threading then OCLSettingDelegate is not thread safe. I want to extend OCLSettingDelegate in order to try to make it thread safe. Can you guide me in this regard. I am trying to follow http://wiki.eclipse.org/EMF/New_and_Noteworthy/Helios#Defining_a_Setting_Delegate
The second part of question is "will OCLSettingDelegate be thread safe in upcomming version"?
Re: OCLSettingDelegate extension [message #714689 is a reply to message #714659] Thu, 11 August 2011 05:32 Go to previous messageGo to next message
Follwoing an earlier query
https://bugs.eclipse.org/bugs/show_bug.cgi?id=348606 is open to fix
this, but I'm afraid it does not have high priority.
If you're sufficiently motivated to try to fix it for yourself, we would
be grateful if you provide a patch so that it is fixed for everyone.
To do this you need to check out the org.eclipse.ocl.ecore plugin from
GIT and enhance the classes in the delegate package with appropriate
synchronize declarations. You may also need to check out the inherited
EMF classes (but I hope those are ok).
Ed Willink
On 11/08/2011 09:12, ModelGeek wrote:
> follow
Re: OCLSettingDelegate extension [message #716046 is a reply to message #714689] Tue, 16 August 2011 05:49 Go to previous messageGo to next message
As i mentioned URL http://wiki.eclipse.org/EMF/New_and_Noteworthy/Helios#Defining_a_Setting_Delegate
This tutorial guides to extends BasicSettingDelegate.Stateless.
Is this method recommended to have specialized delegates?
Re: OCLSettingDelegate extension [message #716212 is a reply to message #716046] Tue, 16 August 2011 12:48 Go to previous message
> As i mentioned URL
> This tutorial guides to extends BasicSettingDelegate.Stateless. Is
By 'method' do you mean 'approach' or 'Java function'.
The N&N was written before OCL delegates were actually implemented. The
real OCL delegates are provided by Eclipse OCL so you have
no need to implement them, but may want to revise them to make them
thread safe.
The actual delegates are nominally stateless, but they have lazily
initialized caches. Placing synchronized around the cache initializations
and the 'pointers' to the delegates could cure the thread safety.
If you are asking about EMF delegates in general, you should perhaps ask
on the EMF newsgroup.
Ed Willink
Previous Topic:extract elements from a collection
Next Topic:(no subject)
Current Time: Sat May 25 08:49:59 EDT 2013
Powered by FUDForum. Page generated in 0.03057 seconds
