| Re: GMF on Eclipse 3.7 [message #659186 is a reply to message #659183] |
Fri, 11 March 2011 12:26   |
Ralph Gerbig Messages: 697 Registered: November 2009 |
I installed QVTo 3.1 from the Eclipse 3.7 site: http://download.eclipse.org/releases/indigo
use this QVTo site http://download.eclipse.org/modeling/m2m/updates/milestones/ . But when trying to install the missing QVTo OML plugins, which are Common and Developer Resource, from there I get:
| Quote: | Cannot complete the install because one or more required items could not be found.
Software being installed: Operational QVT Common 2.0.0.v20090410-1820-79-8ZAkF77g7VCZ3BeM7 (org.eclipse.m2m.qvt.oml.common.feature.group 2.0.0.v20090410-1820-79-8ZAkF77g7VCZ3BeM7)
Missing requirement: OCL 2.0 Binding for Ecore 1.3.0.v200905271400 (org.eclipse.ocl.ecore 1.3.0.v200905271400) requires 'bundle org.eclipse.emf.ecore [2.5.0,2.6.0)' but it could not be found
Cannot satisfy dependency:
From: Operational QVT Common 2.0.0.v20090410-1820-79-8ZAkF77g7VCZ3BeM7 (org.eclipse.m2m.qvt.oml.common.feature.group 2.0.0.v20090410-1820-79-8ZAkF77g7VCZ3BeM7)
To: org.eclipse.ocl.ecore [1.3.0,2.0.0)
So I tried to install OCL from http://download.eclipse.org/modeling/mdt/updates/milestones/ which produced
Software being installed: Object Constraint Language (OCL) 2.0 Examples 1.3.0.v200901271800-478-9oB55W58BQ8T55 (org.eclipse.emf.ocl.examples.feature.group 1.3.0.v200901271800-478-9oB55W58BQ8T55)
Missing requirement: OCL 2.0 Binding for Ecore 1.2.1.v200807301850 (org.eclipse.ocl.ecore 1.2.1.v200807301850) requires 'bundle org.eclipse.emf.ecore [2.4.0,2.5.0)' but it could not be found
From: Object Constraint Language (OCL) 2.0 Examples 1.3.0.v200901271800-478-9oB55W58BQ8T55 (org.eclipse.emf.ocl.examples.feature.group 1.3.0.v200901271800-478-9oB55W58BQ8T55)
To: org.eclipse.ocl.ecore [1.1.0,2.0.0)
What update sites do you suggest? Where can I get org.eclipse.ocl.ecore from? I plan to use GMF with OCL 3.1.
Ralph
[Updated on: Fri, 11 March 2011 12:30] Report message to a moderator
| Re: GMF on Eclipse 3.7 [message #687765 is a reply to message #666190] |
Thu, 23 June 2011 07:30   |
Vladimir  Messages: 7 Registered: June 2011 |
Junior Member |
Thanks for your reply, Borislav.
I've done as proposed und installed manually gmf-sdk-2.4.0M6 and m2m-qvtoml-SDK-3.1.0M6 on eclipse-SDK-3.7-win32 but i'm still not able to create a new gmf project.
Anything i've done wrong?
Vladimir
[Updated on: Thu, 23 June 2011 08:38] Report message to a moderator
FUDForum. Page generated in 0.02752 seconds
