Home » Eclipse Projects » Eclipse 4 » InteractiveSplash screen not load
InteractiveSplash screen not load [message #699715] Fri, 22 July 2011 03:26 Go to next message
etudes-developpements is currently offline etudes-developpements
Hi, I want to display a splash screen with log-in session. But with E4 when I set in
file "Product definition" > Splash > Customization > Template > Interactive-Asimulated log-in session, the file assiciated to the spash screen did not executed.
Is anybody have run spash with this feature?
In my file I have this line :
<splash
location="com.smacl.application"
handlerType="interactive" />
And in plugin.xml :
<extension
point="org.eclipse.ui.splashHandlers">
<splashHandler
class="com.smacl.application.splashHandlers.InteractiveSplashHandler"
id="com.smacl.application.splashHandlers.interactive">
</splashHandler>
<splashHandlerProductBinding
productId="com.smacl.application.product"
splashId="com.smacl.application.splashHandlers.interactive">
</splashHandlerProductBinding>
</extension>
Re: InteractiveSplash screen not load [message #715303 is a reply to message #699715] Sat, 13 August 2011 03:53 Go to previous message
Deepak  is currently offline Deepak
The following is the answer for Eclipse 3.7
I am not sure whether this is a plugin or RCP. But the following XML should work if your are testing a Plugin. Note the attribute
productId="org.eclipse.platform.ide"
Hence the extension should look like the following
<extension
      <splashHandler
            class="sample6.splashHandlers.InteractiveSplashHandler"
            id="sample6.splashHandlers.interactive">
      </splashHandler>
            splashId="sample6.splashHandlers.interactive"
            productId="org.eclipse.platform.ide">
   </extension>
Previous Topic:org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/ui/2008
Next Topic:(no subject)
Current Time: Mon May 20 09:45:29 EDT 2013
Powered by FUDForum. Page generated in 0.04143 seconds
