Home » Eclipse Projects » Equinox » OSGi + Http Service
| OSGi + Http Service [message #714736] |
Thu, 11 August 2011 08:10  |
StefanK Messages: 25 Registered: July 2009 |
Junior Member |
Hi everyone,
i created an simple application to learn how to use the OSGi Service Platform. I´m using the HttpService specified in the OSGi Service Compendium to display a simple html page for the user to input some values.
If i´m running the application within the eclipse platform, everything works just fine. But if i´m trying to start the application through the windows xp command shell, the created Log says the following:
!SESSION 2011-08-11 13:34:45.156 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -configuration c:\OSGi\deploy\config -console -clean
!ENTRY SimpleCalculatorHttpFrontEnd 4 0 2011-08-11 13:36:09.593
!MESSAGE [SCR] Error while trying to bind reference Reference[name = simpleCalcualtorHttpService, interface = org.osgi.service.http.HttpService, policy = dynamic, cardinality = 0..n, target = null, bind = setHttpService, unbind = unsetHttpService]
Details:
Problematic reference = Reference[name = simpleCalcualtorHttpService, interface = org.osgi.service.http.HttpService, policy = dynamic, cardinality = 0..n, target = null, bind = setHttpService, unbind = unsetHttpService]
of service component = simplecalculatorHttpFrontEnd
component implementation class = de.ict.simplecalculator.activator.SimpleCalculatorHttpStarter
located in bundle with symbolic name = SimpleCalculatorHttpFrontEnd
bundle location = initial@file:/C:/OSGI/deploy/plugins/SimpleCalculatorHttpFrontEnd_1.0.0.201108110902.jar
!STACK 0
java.lang.reflect.InvocationTargetException
at org.eclipse.equinox.internal.ds.model.ComponentReference.bind(ComponentReference.java:360)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.bindReference(ServiceComponentProp.java:434)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.bind(ServiceComponentProp.java:211)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:337)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:588)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:196)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:441)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:213)
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:800)
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:767)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70)
Caused by: java.lang.NullPointerException
at de.ict.simplecalculator.activator.SimpleCalculatorHttpStarter.setHttpService(SimpleCalculatorHttpStarter.java:40)
... 16 more
Root exception:
I´m using the declarative service mechanism to bind the HttpService Object registered in the registry to the SimpleCalculatorHttpStarter object. The funny thing is, if i´m using a service tracker to track down the HttpService it works just fine..
So is there a problem with declarative services or am i missing something? The OSGI-INF/http.xml file is exported with the .jar file. It basically contains the following xml code:
<?xml version="1.0"?>
<component name="simplecalculatorHttpFrontEnd">
<implementation
class="de.ict.simplecalculator.activator.SimpleCalculatorHttpStarter" />
<reference name="simpleCalculatorHttpReference" interface="org.osgi.service.http.HttpService"
bind="setHttpService" unbind="unsetHttpService" cardinality="0..n"
policy="dynamic"/>
</component>
I´m calling the bundles using the following command:
java -jar -Dorg.osgi.service.http.port=1234 c:\..\deploy\org.eclipse.osgi.jar -configure c:\..\deploy\config -console -clean
The config.ini includes the following bundles:
osgi.bundles=\
file:/C:/OSGI/deploy/plugins/SimpleCalculatorBackEnd_1.0.0.201108110902.jar@:start,\
file:/C:/OSGI/deploy/plugins/SimpleCalculatorEventReceiver_1.0.0.201108110902.jar@:start,\
file:/C:/OSGI/deploy/plugins/SimpleCalculatorHttpFrontEnd_1.0.0.201108110902.jar@:start,\
file:/C:/OSGI/deploy/plugins/SimpleCalculatorLogReceiver_1.0.0.201108110902.jar@:start,\
file:/C:/OSGI/equinox/plugins/javax.servlet_2.5.0.v200910301333.jar@:start,\
file:/C:/OSGI/equinox/plugins/org.eclipse.osgi.services_3.2.100.v20100503.jar@:start,\
file:/C:/OSGI/equinox/plugins/org.eclipse.equinox.cm_1.0.200.v20100520.jar@:start,\
file:/C:/OSGI/equinox/plugins/org.eclipse.equinox.ds_1.2.1.R36x_v20100803.jar@:start,\
file:/C:/OSGI/equinox/plugins/org.eclipse.equinox.event_1.2.0.v20100503.jar@:start,\
file:/C:/OSGI/equinox/plugins/org.eclipse.equinox.log_1.2.100.v20100503.jar@:start,\
file:/C:/OSGI/equinox/plugins/org.eclipse.equinox.util_1.0.200.v20100503.jar@:start,\
file:/C:/OSGI/equinox/plugins/org.eclipse.equinox.http_1.0.400.v20100503.jar@:start
eclipse.ignoreApp=true
I checked the registered services using the "service" command, the httpService is correctly registered. So how come there could be a NullPointerException within the setHttpService method which binds the httpService?
Thanks in advance
StefanK
| Re: OSGi + Http Service [message #721593 is a reply to message #714736] |
Fri, 02 September 2011 04:32  |
Ivan Larionov Messages: 37 Registered: July 2009 |
Member |
Have you tried to debug? I mean, clearly, the following is not a simple
setter method
if NPE occurs there.
On 11.08.2011 15:10, StefanK wrote:
> Hi everyone,
> values. If i´m running the application within the eclipse platform,
> java.version=1.7.0
> java.vendor=Oracle Corporation
> -clean
> Details:
> unsetHttpService]
> bundle location =
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 16 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> the HttpService it works just fine.. So is there a problem with
> xml code:
> <implementation
> policy="dynamic"/>
> </component>
> -console -clean
> osgi.bundles=\
> httpService?
> Thanks in advance
> StefanK
Current Time: Fri May 24 19:48:17 EDT 2013
Powered by FUDForum. Page generated in 0.01552 seconds
