Home » Eclipse Projects » Standard Widget Toolkit (SWT) » ComboBox sizing
ComboBox sizing [message #710614] Fri, 05 August 2011 04:09 Go to next message
Thomas Singer is currently offline Thomas Singer
Member
We have a dialog where a non-editable combobox may contain very long items (paths to be precise). By default, the combobox' preferred size is determined by the longest item (at least on Windows). I've tried to limit the combobox's width, but unfortunately, this also limits the width of the combobox' popup. How to make the popup as wide as necessary, but limit the collapsed combobox's width?
Thanks in advance,
Tom
Re: ComboBox sizing [message #714358 is a reply to message #710614] Wed, 10 August 2011 08:10 Go to previous messageGo to next message
Vijay Raj
Did you try CCombo?
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
[Updated on: Wed, 10 August 2011 08:11]
Report message to a moderator
(no subject) [message #714378 is a reply to message #710614] Wed, 10 August 2011 08:10 Go to previous message
vijay is currently offline vijay
Did you try CCombo
Vijay
Previous Topic:Useless post
Next Topic:REPOST: Detached views to be brought up independently (Parent shell behaviour)
Current Time: Fri May 24 18:43:41 EDT 2013
Powered by FUDForum. Page generated in 0.01538 seconds
