Home » General (non-technical) » Eclipse Foundation » not connect to cvs server(not connect to cvs server)
not connect to cvs server [message #507600] Wed, 13 January 2010 21:19 Go to next message
liuqian  is currently offline liuqian
hi, i use myeclipse to connect cvs server,it ok,but when i use eclipse ,but it give a exception "Could not connect to :pserver:user1@192.168.187.9:/home/cvsrepo/gz2010: I/O exception occurred: ProxyHTTP: java.io.IOException: proxy error: Proxy Error ( The specified Secure Sockets Layer (SSL) port is not allowed. ISA Server is not configured to allow SSL requests from this port. Most Web browsers use port 443 for SSL requests. )
ProxyHTTP: java.io.IOException: proxy error: Proxy Error ( The specified Secure Sockets Layer (SSL) port is not allowed. ISA Server is not configured to allow SSL requests from this port. Most Web browsers use port 443 for SSL requests. )"?Please tell me how to slove it ? Thanks
myeclipse version:6.5
eclipse version: Eclipse IDE for Java EE Developers 1.2.1.20090918-0703 epp.package.jee
Re: not connect to cvs server [message #513558 is a reply to message #507600] Wed, 10 February 2010 10:01 Go to previous messageGo to next message
Selva  is currently offline Selva
I had the same problem. Basically the proxy is ON. You need to remove the proxy or get your proxy server to allow this cvs server.
To access direct ( not through proxy) : In the "Add a new CVS Repository" screen click Configure connection preference" -> General -> Network Connection -> Active Provider -> Direct ( Native is proxy i think native is default).
Selva.
Re: not connect to cvs server [message #653284 is a reply to message #513558] Wed, 09 February 2011 03:38 Go to previous messageGo to next message
Raghavendra  is currently offline Raghavendra
Thanks you are correct and it works fine
Re: not connect to cvs server [message #714015 is a reply to message #513558] Tue, 09 August 2011 11:39 Go to previous message
CLAUDIO  is currently offline CLAUDIO
Gracias , me sirvió!!
Saludos
Previous Topic:Re: Eclipse.org website extremely slow
Next Topic:Two weeks until ECon Europe submission deadline
Current Time: Sat May 25 12:43:58 EDT 2013
Powered by FUDForum. Page generated in 0.05105 seconds
