How to avoid duplicate requests for Birt reports. [message #704228] |
Thu, 28 July 2011 08:02  |
vijay kumar Messages: 26 Registered: October 2010 |
Junior Member |
Hi, I am having an issue with duplicate request for same report (report called two times immediately). I am getting the following exception
org.eclipse.birt.report.service.api.ReportServiceException org.eclipse.birt.report.service.api.ReportServiceException atorg.eclipse.birt.report.service.ReportEngineService.openReportDocument(ReportEngineService.java:504)
I am running the birt reports using My Eclipse IDe 7.5. It uses the version 2.3.1. When I goolged for this error they are saying it is due to some session management and they are saying "we introduced a new session management mechanism in 2.3.2, which includes quite complex changes. I would suggest you upgrade to 2.3.2 in this case". Is this upgrade going to resolve my problem? Failed to upgrade my Ide.
Any Suggestion on this. Thank you in advance
Vijay Kumar Bolisetti
[Updated on: Thu, 28 July 2011 08:03] Report message to a moderator
FUDForum. Page generated in 0.02051 seconds
