Home » Eclipse Projects » JFace » Checkboxcelleditor in treeviewercolumn(Adding an image other than the check images in the tree viewer column)
Checkboxcelleditor in treeviewercolumn [message #713792] Tue, 09 August 2011 00:47
Aravindhan Annamalai is currently offline Aravindhan Annamalai
Member
I am using checkboxcelleditor in my treeviewercolumn.
The getImage() method in the label provider renders either the check image (or) the uncheck image depending on the selection.
I need to have an additional icon on that treeviewer column next to the column text other than the check image...
How to proceed on this..?
Aravind
Previous Topic:selectionChanged listener not getting called when view is minimized
Next Topic:MasterDetails and inital master selection
Current Time: Sat May 18 15:17:54 EDT 2013
Powered by FUDForum. Page generated in 0.01687 seconds
