| XML datasource with dynamic URL [message #713685] |
Mon, 08 August 2011 15:36  |
Tuco Messages: 6 Registered: August 2011 |
Junior Member |
I am trying to use an XML datasource in the BIRT reports.
We have REST webservices which expose the data in the form of "http://<serverName>/subject/{Id}.xml?user=<User>&token=<token>".
When i try in Eclipse, i need to give the whole URL but i want to avoid that because the server url, id, user and the token will be dynamic.
Is it possible to use report parameters in the URL of the XML so that they could be set dynamically as the report task parameters?
I know how to set the report task parameters but can i set the parameters in the URL of the XML datasource?
Is there a way?
Thank you
Tuco
| Re: XML datasource with dynamic URL [message #713697 is a reply to message #713685] |
Mon, 08 August 2011 16:22  |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Have you tried changing the url using a beforeOpen script like:
this.setExtensionProperty("FILELIST", params["myxmllocation"].value);
If you want to change the query you need to set query text in the
beforeOpen of the dataset like
this.queryText = "table1#-TNAME-#table1#:#[/companies/company[@id='" +
params["companyid"].value
+"']/employee]#:#{id;STRING;/@id},{companyid;STRING;../@id}"
Jason
On 8/8/2011 3:36 PM, Tuco wrote:
> Hello,
> Is there a way?
> Thank you
> Tuco
Jason Weathersby
BIRT Exchange
| Re: XML datasource with dynamic URL [message #713699 is a reply to message #713685] |
Jason
> Hello,
> Is there a way?
> Thank you
> Tuco
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.01802 seconds
