Home » Eclipse Projects » EclipseLink » Accessing outer query in Eclipselink subquery(Accessing outer query in Eclipselink subquery)
Accessing outer query in Eclipselink subquery [message #708534] Tue, 02 August 2011 18:59 Go to next message
Kamal  is currently offline Kamal
Is accessing an outerExpression from a subQuery supported in Eclipselink? I get an error when I do this. The query works fine in Toplink 10.1.3.
The query also works if I remove the reference to the outerExpression and replace it with an identifier.I could not find an example for this in Eclipselink documentation.
I' am using separate Expression Builders for the queries.
Re: Accessing outer query in Eclipselink subquery [message #713491 is a reply to message #708534] Mon, 08 August 2011 10:36 Go to previous message
James Sutherland is currently offline James Sutherland
Please include your code for your query.
James : Wiki : Book : Blog
(no subject) [message #713518 is a reply to message #708534] Mon, 08 August 2011 10:36 Go to previous message
James is currently offline James
James : http://wiki.eclipse.org/EclipseLink : http://en.wikibooks.org/wiki/Java_Persistence : http://java-persistence-performance.blogspot.com/
Previous Topic:(no subject)
Next Topic:(no subject)
Current Time: Sat May 18 16:59:09 EDT 2013
Powered by FUDForum. Page generated in 0.01648 seconds
