| Dependency of all other projects [message #710530] |
Fri, 05 August 2011 01:45  |
Thomas Wiedmann Messages: 69 Registered: July 2009 |
Member |
is there a plugin or function within Eclipse which shows all dependent
projects of the project - even the inherited ones, selected?
Within the project properties at Java Build Path/[Projects] only the
directly dependent projects are listed. To get all relevant projects I have
to select these projects and to search their dependent projects - thus an
expensive recursion. Is there an easier way - by a plugin or feature; if
yes, by which?
I use Eclipse 3.5.2.
Thomas Wiedmann
FUDForum. Page generated in 0.01723 seconds
