| On install plugin not visible in the "Open Perspective" nor "Show View" menus [message #711198] |
Fri, 05 August 2011 18:08 |
SAM Messages: 3 Registered: August 2011 |
Junior Member |
I have been working on a plug-in for eclipse that has 7 views contained in a Perspective.
When I test my plug-in as an eclipse application from my development environment (Helios for RCP and RAP developers) my perspective and views work correctly and show up in both the "Open Perspective" and "Show View" menus and I can then load and use my plug-in.
However when I export my plugin as a jar file and place it in the dropins folder of various Helios and Indigo builds OR create (following the instructions on wiki.eclipse.org/FAQ_How_do_I_create_an_update_site_%28site.xml%29%3F) and install from a local update site (Help->Install New Software->Add->Local->etc...), my perspective, views and toolbar buttons do not show up (neither before nor after restart). I know that the plugin or at least the Feature is installed because when I look in Help->About->Installation Details, the feature shows up and can be uninstalled.
I have tried to follow steps and suggestions detailed on various sites about setting up/starting plugins as well as following the exporting steps on the overview page of the plugin.xml file.
My assumption, correct or not, is that if everything shows up fine when testing, by running the project from my developing instance of eclipse, then the plugin.xml file is mostly correct and I have the plug-in project set up correctly to be exported and still work as set up.
Does anyone have suggestions about what could be missing in my process or that I might be doing wrong such that my plug-in is un-findable when installed? Or somewhat more detailed information about how the Extensions section of plugin.xml is used by eclipse when loading/installing a plugin?
Thank you.
[Updated on: Fri, 05 August 2011 18:16] Report message to a moderator
FUDForum. Page generated in 0.04622 seconds
