Home » Eclipse Projects » Web Tools Project (WTP) » DOM of editing file(Is it accessible?)
DOM of editing file [message #710853] Fri, 05 August 2011 09:31 Go to next message
MarcoGT  is currently offline MarcoGT
Member
Hi all,
I am extending XML Editor of Eclipse.
Is it possible to access to DOM of the XML file opened inside the editor?
How?
Marco
Re: DOM of editing file [message #710996 is a reply to message #710853] Fri, 05 August 2011 12:59 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
On 8/5/2011 9:31 AM, MarcoGT wrote:
> Hi all,
> How?
That depends on what you mean by extending the XML Editor. What do you
mean?
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: DOM of editing file [message #711000 is a reply to message #710996] Fri, 05 August 2011 13:12 Go to previous messageGo to next message
Member
I am extending the content assist as I said in other posts.
I am working on org.eclipse.wst.xml.ui plugin and everything works fine.
I would like, if possible, get the DOM of the XML file opened inside the editor.
Marco
[Updated on: Fri, 05 August 2011 13:19]
Report message to a moderator
Re: DOM of editing file [message #711027 is a reply to message #711000] Fri, 05 August 2011 13:36 Go to previous messageGo to next message
On 8/5/2011 1:12 PM, MarcoGT wrote:
> I am extended the content assist as I said in other posts.
So where from, exactly, are you trying to get the DOM, from the editor
class, or somewhere else?
Also, if you're changing org.eclipse.wst.xml.ui itself, the license may
place additional requirements on you, i.e.
http://www.eclipse.org/legal/eplfaq.php#MODDIST .
Nitin Dahyabhai
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: DOM of editing file [message #711030 is a reply to message #711027] Fri, 05 August 2011 13:47 Go to previous messageGo to next message
Member
At the moment I am working on AbstractXMLModelQueryCompletionProposalComputer.
And, about license, I do not distribute the code to any others people, I will keep it only for me.
19) If I modify a Program licensed under the EPL, but never distribute it to anyone else, do I have to make my modifications available to others?
No. If you do not distribute the modified Program, you do not have to make your modifications available to others.
Marco
[Updated on: Fri, 05 August 2011 13:50]
Re: DOM of editing file [message #711167 is a reply to message #711030] Fri, 05 August 2011 17:07 Go to previous messageGo to next message
Assuming you're in one of the methods with a ContentAssistRequest object passed in as an argument, the node and parent node in that object are part of the DOM model already. Otherwise it's really a question of what objects you have on-hand to work from.
Nitin Dahyabhai
Eclipse WTP, IBM
Re: DOM of editing file [message #711448 is a reply to message #711167] Sat, 06 August 2011 02:22 Go to previous messageGo to next message
Member
At the moment I am working in addAttributeValueProposal to add proposal for attribute values.
Here so I have access to DOM in particular I have the current node, right?
But is there a way to have the DOM of the whole document?
Marco
Re: DOM of editing file [message #713106 is a reply to message #711448] Mon, 08 August 2011 01:15 Go to previous messageGo to next message
You seem to be using DOM in a generic sense while I'm using it to refer to the org.w3c.dom.* interfaces which we mostly implement, and those have clear means for getting the object that represents the entire document. Or do I misunderstand?
Nitin Dahyabhai
Eclipse WTP, IBM
Re: DOM of editing file [message #713114 is a reply to message #713106] Mon, 08 August 2011 01:23 Go to previous messageGo to next message
Member
No no, like you, I mean to referring to org.w3c.dom Smile
I saw that for example, in addAttributeValueProposal an object org.w3c.dom.Node, is it right?
So at ervery call to the content assist I have an object containing that particular node, is it right?
Thanks a lot
Marco
Re: DOM of editing file [message #713814 is a reply to message #710853] Tue, 09 August 2011 02:18 Go to previous messageGo to next message
Member
Is it possible to build an XPath query on the current node?
I am trying to do that but probably I did errors somewhere; I am in "addAttributeValueProposals" and I have the "node" variable (org.w3c.node) which contains the current node.
If I do
XPath xpath = XPathFactory.newInstance().newXPath();
XPathExpression xPathTest = null;
NodeList o = null;
try {
    xPathTest = xpath.compile("//@*");
    o = (NodeList) xPathTest.evaluate(node, XPathConstants.NODESET);
} catch (XPathExpressionException e1) {
  e1.printStackTrace();
System.out.println(o.getLength() + " length");
I obtain the number of ALL attributes inside the node and not inside the current node, where I am wrong?
Re: DOM of editing file [message #713833 is a reply to message #713814] Tue, 09 August 2011 03:03 Go to previous message
Member
Ok, the error was inside the XPath expression:
from
to
xPathTest = xpath.compile("./@*");
Now it works.
Previous Topic:Problem in generated server.xml preventing web-app from reading files
Next Topic:associate a project with server
Current Time: Sat May 25 23:52:03 EDT 2013
Powered by FUDForum. Page generated in 0.02048 seconds
