Home » Eclipse Projects » EGit » File URI not working correctly
File URI not working correctly [message #710264] Thu, 04 August 2011 17:24 Go to next message
CrypticMetaphor88 is currently offline CrypticMetaphor88
My brother and I are working on a small project in Windows, we almost always work on a LAN network and I'm currently working on setting up a distributed svn that allows us to share files, merge code, etc.
I'm trying to clone a project form another computer via EGit and I only want to use the "file" protocol, because it's the simplest and easiest. I specifically don't want to use anything else because we are working on a lan and security is not an issue.
The problem is that if I try to clone a project with the file protocol and I fill in the URI with the following:
file:///MyComp/C:/wsShared/repository
I get an error in the upper left part of my screen saying:
C:\eclipse\.\MyComp/C:/wsShared/repository does not exist.
Where is the "C:\eclipse." coming from? shouldn't the file URI scheme allow me to connect to another computer?
Thank you for your time.
Cryptic.
[Updated on: Thu, 04 August 2011 17:25]
Report message to a moderator
Re: File URI not working correctly [message #710697 is a reply to message #710264] Fri, 05 August 2011 06:16 Go to previous messageGo to next message
Manuel Doninger is currently offline Manuel Doninger
I think the url should be file://///MyComp/sharename/wsShared/repository where sharename is the name of your shared folder on the computer. C: would be the drive letter of a local drive, so you can't use drive letters if you want to access network shares of another computer.
Re: File URI not working correctly [message #710840 is a reply to message #710697] Fri, 05 August 2011 09:21 Go to previous message
*face palm* I'm such a tard.
Yeah I figured that out 15 minutes after I posted this went to bed.
thank you for your reply
Previous Topic:How do you add a change to the index?
Next Topic:Merge "using strategy resolve resulted in: Failed."
Current Time: Thu May 23 19:33:03 EDT 2013
Powered by FUDForum. Page generated in 0.02571 seconds
