I'm quite new into BIRT; I am developing a report that shows the content of a database table which is selected by a parameter in a previous JSP page.
I have modified the "this.queryText" within the beforeOpen event in the dataset ( this.queryText.replace("TABLENAME",parms["MYPARAMETER"].value)") And I just get the data I really want from the table I selected, but I don't know how to "print it" into the report, if I just draw a table within the layout view I got the following message
Column binding "CUSTOMERNUMBER" has referred to a data set column "CUSTOMERNUMBER" which does not exist. (Element ID:967)
because the name of the columns do not match with the name of the supossed table I selected (for example ORDERS)
I also tried to change the column data binding expression like this
if (parms["MYPARAMETER"] =table1)
setDataRow["Rowoftable1"]
if (parms["MYPARAMETER"] =table2)
setDataRow["Rowoftable2"]
but It doesn't work neither
So, in a nutshell, how can I show in a table the content of a "parametrized DataSet" wich I don't know the name of the columns in advance ?
This is simpler than calling the de api to change a tables bindings.
Jason
On 7/28/2011 2:01 PM, josete4ever wrote:
> Hello BIRT comunity,
> page.
> dataset (
> advance ?
> Thank you very much
Sounds good, but remember hidden tables still run queries.
Jason
On 7/29/2011 12:08 PM, josete4ever wrote:
> Thanks for your response, at the end of the day what i did is to change
> the expression for visibility of some tables in the report like this:
> Visible if ---> params["TableName"].value != "ParameterTableName"
> :blush:
> Thank for your response.
