Home » Eclipse Projects » Target Management » RSE memory leak(rse memory leak)
RSE memory leak [message #708004] Tue, 02 August 2011 06:28 Go to next message
rupp  is currently offline rupp
I have been running RSE server using the dameon.pl perl script to start it but the available memory is rapidly decreasing. As it is almost the only application running on the dev server except a glassfish server I assume it comes from there , the available memory is decreasing at a speed of ~ 5Mb/sec !
in a few minutes the available memory goes from 1.2Gb to ... 3Mb
my O.S is a debian 5 lenny server , 2GB ram , VPS , XEN
[Updated on: Tue, 02 August 2011 06:29]
Report message to a moderator
Re: RSE memory leak [message #709127 is a reply to message #708004] Wed, 03 August 2011 10:15 Go to previous message
David McKnight is currently offline David McKnight
When using the daemon.pl perl script, there are two things going on. There
is a java daemon (started by daemon.pl), running under root, that waits on a
port to authenticate and start a java server under a given user's ID. I
suspect that, in your case, it's not the daemon that is running into memory
problems but rather the launched server. There are cases where the server
uses a lot of memory and there are some ways to help with that but it may
depend on what you're doing. What kind of operations are you doing when the
memory is rapidly consumed?
"rupp" <forums-noreply@eclipse.org> wrote in message
news:j18isv$55r$1@news.eclipse.org...
>I have been running RSE server using the dameon.pl perl script to strat it
>but the memory is rapidly decreasing. As it is almost the only application
Previous Topic:Questions about debugging on target via Target Management vs typical CDT
Next Topic:RSE 2048 key?
Current Time: Sat May 25 12:03:29 EDT 2013
Powered by FUDForum. Page generated in 0.01459 seconds
