Home » Eclipse Projects » XML Schema Definition (XSD) » URIConverter question.
| URIConverter question. [message #70848] |
Fri, 01 December 2006 11:16  |
Originally posted by: ashish.deshpande.cc
I am having trouble understanding URIConverter. I have a serialized
(XMI) file from a colleague with the following content (a string
XSDSimpleTypeDefinition):
<typeDefinition xsi:type="xsd:XSDSimpleTypeDefinition"
href=" jar:file:/D:/Projects/eclipse-projects/frevvo/workspace/com. gauss.forms/lib/org.eclipse.xsd_2.2.0.v200606271057.jar!/cac he/www.w3.org/2001/XMLSchema.xsd#//string;XSDSimpleTypeDefin ition=7 "/>
As you can see, the href points to a specific file (D:/....). That path
does not exist on my machine making this file non-portable. So,
1) Can I make this portable? I can put the jar file in a common relative
directory (say ../../lib, which will work on all machines for my
application). Can I force the href to point to
jar:file:../../lib/org.eclipse etc.
instead of the D:/Projects?
2) How can I use a URIConverter to affect this? I know what the
URIConverter should do but I am unable to attach my custom URIConverter
to handle this URI. Specifically, MyCustomConverter.normalize(uri) is
never called for this URI even though I have done:
resourceSet.setURIConverter (new MyCustomConverter());
Is it that this particular URI is loaded using a Resource from a
different ResourceSet but I don't understand how to affect that.
Thx,
-Ashish
| Re: URIConverter question. [message #70871 is a reply to message #70848] |
Fri, 01 December 2006 13:42   |
--------------090805020003010803090605
Ashish,
Ouch. That's nasty! The built-in schema for schemas is loaded like
this in XSDSchemaImpl:
public static synchronized XSDSchema getSchemaForSchema(String
namespace)
if (XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001.equals(namespace))
if (xsdSchemaForSchema2001 == null)
try
String baseURL = XSDPlugin.INSTANCE.getBaseURL().toString();
getMagicSchemaForSchema(namespace);
getGlobalResourceSet().getLoadOptions().put("XSD_XML_SCHEMA ",
XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001);
getGlobalResourceSet().getResource
(URI.createURI(baseURL +
"cache/www.w3.org/2001/XMLSchema.xsd"), true);
In an Eclipse/OSGi environment this would use
"platform:/plugin/org.eclipse.xsd/" but when running standalone, it will
reference the physical jar location and then the reference will not be
portable. :-(
I've been playing with
https://bugs.eclipse.org/bugs/show_bug.cgi?id=164597 but have not had a
chance to work on it for a while, but that could be used (instead of a
specialization of XMLHelperImpl.deresolve) to turn the non-portable
physical location into a logical URI while saving and then you could use
a URI mapping to ensure that that logical URI maps to the right physical
location. Another wrinkle though is that since this schema for schema
resource is in a separate resource set you'd need to specialize
ResourceSetImpl.delegatedGetResource to look in the special resource set
containing the schema for schemas.
Probably the simplest brute force approach is to specialize
ResourceSetImpl.delegatedGetResource to look for a URI with path
/cache/www.w3.org/2001/XMLSchema.xsd, ignoring the non-portable
authority, and redirect it to return the schema for schemas's resource.
Ashish Deshpande wrote:
> path does not exist on my machine making this file non-portable. So,
> relative directory (say ../../lib, which will work on all machines for
> my application). Can I force the href to point to
> URIConverter to handle this URI. Specifically,
> MyCustomConverter.normalize(uri) is never called for this URI even
> though I have done:
> Thx,
> -Ashish
<html>
<head>
</head>
Ashish,<br>
<br>
this in XSDSchemaImpl:<br>
<blockquote><small> public static synchronized XSDSchema
getSchemaForSchema(String namespace)</small><br>
<small> {</small><br>
<small> if
(XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001.equals(namespace))</small ><br>
<small> if (xsdSchemaForSchema2001 == null)</small><br>
<small> try</small><br>
<small> String baseURL =
XSDPlugin.INSTANCE.getBaseURL().toString();</small><br>
<small> getMagicSchemaForSchema(namespace);</small><br>
<small>
XSDConstants.SCHEMA_FOR_SCHEMA_URI_2001);</small><br>
<small> getGlobalResourceSet().getResource</small><br>
<small> (URI.createURI(baseURL +
"cache/www.w3.org/2001/XMLSchema.xsd"), true);</small><br>
</blockquote>
will reference the physical jar location and then the reference will
not be portable. :-(<br>
<br>
I've been playing with <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=164597">https://bugs.eclipse.org/bugs/show_bug.cgi?id=164597</a>
but have not had a chance to work on it for a while, but that could be
used (instead of a specialization of XMLHelperImpl.deresolve) to turn
the non-portable physical location into a logical URI while saving and
then you could use a URI mapping to ensure that that logical URI maps
to the right physical location. Another wrinkle though is that since
this schema for schema resource is in a separate resource set you'd
need to specialize ResourceSetImpl.delegatedGetResource to look in the
special resource set containing the schema for schemas. <br>
<br>
authority, and redirect it to return the schema for schemas's resource.<br>
<br>
<br>
<blockquote cite="midekpkgi$gbi$1@utils.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
href=<a class="moz-txt-link-rfc2396E" href=" jar:file:/D:/Projects/eclipse-projects/frevvo/workspace/com. gauss.forms/lib/org.eclipse.xsd_2.2.0.v200606271057.jar!/cac he/www.w3.org/2001/XMLSchema.xsd#//string;XSDSimpleTypeDefin ition=7 ">" jar:file:/D:/Projects/eclipse-projects/frevvo/workspace/com. gauss.forms/lib/org.eclipse.xsd_2.2.0.v200606271057.jar!/cac he/www.w3.org/2001/XMLSchema.xsd#//string;XSDSimpleTypeDefin ition=7 "</a>/>
<br>
<br>
<br>
<br>
jar:<a class="moz-txt-link-freetext" href="file:../../lib/org.eclipse">file:../../lib/org.eclipse </a> etc.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thx,
<br>
-Ashish
<br>
</blockquote>
<br>
</body>
</html>
--------------090805020003010803090605--
| Re: URIConverter question. [message #70889 is a reply to message #70871] |
Mon, 04 December 2006 12:02   |
Oof! Thanks Ed for your response. I will have to parse this and play
with it a little bit but I think I understand the gist of what you're
saying.
-Ashish
Ed Merks wrote:
> Ashish,
> namespace)
> try
> portable. :-(
>> though I have done:
>> Thx,
>> -Ashish
| Re: URIConverter question. [message #70909 is a reply to message #70889] |
Mon, 04 December 2006 13:13  |
Ashish,
I'm willing to consider making changes in XSD 2.3 that would make life
easier. For example, perhaps the URI of these special resources should
really be their physical location on the web...
> saying.
> -Ashish
> Ed Merks wrote:
>> Ashish,
>> namespace)
>> try
>> String baseURL =
>> a chance to work on it for a while, but that could be used (instead
>> of a specialization of XMLHelperImpl.deresolve) to turn the
>> the special resource set containing the schema for schemas.
>>> Hi,
>>> for my application). Can I force the href to point to
>>> though I have done:
>>> Thx,
>>> -Ashish
| Re: URIConverter question. [message #599209 is a reply to message #70848] |
Ed Merks Messages: 24538 Registered: July 2009 |
Ashish,
namespace)
try
portable. :-(
> though I have done:
> Thx,
> -Ashish
<html>
<head>
</head>
Ashish,<br>
<br>
<small> if
<small>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Thx,
<br>
-Ashish
<br>
</blockquote>
<br>
</body>
</html>
| Re: URIConverter question. [message #599220 is a reply to message #70871] |
saying.
-Ashish
Ed Merks wrote:
> Ashish,
> namespace)
> try
> portable. :-(
>> though I have done:
>> Thx,
>> -Ashish
| Re: URIConverter question. [message #599228 is a reply to message #70889] |
Ashish,
> saying.
> -Ashish
> Ed Merks wrote:
>> Ashish,
>> namespace)
>> try
>> String baseURL =
>>> Hi,
>>> though I have done:
>>> Thx,
>>> -Ashish
Current Time: Mon May 20 12:06:26 EDT 2013
Powered by FUDForum. Page generated in 0.02136 seconds
