Home » Eclipse Projects » Rich Client Platform (RCP) » Browser in RCP application triggers multiple combination on key strokes
Browser in RCP application triggers multiple combination on key strokes [message #708470] Tue, 02 August 2011 17:09
jimi_lmf is currently offline jimi_lmf
I have a SWT.Browser that use IE by default within my RCP application. I turned on the debug for the key binding and every time i have the focus on the browser and press a key combination like CTRL+SHIFT+M the log displays:
potentialKeyStrokes = [CTRL+SHIFT+, CTRL+M, CTRL+SHIFT+M]
which then make my command binded to CTRL+SHIFT+M not called but the one binded to CTRL+M be called instead
Is it the swt.Browser component not working properly or is it the expected behavior ?
Thx
Previous Topic:Adding Show View menu in plugin.xml
Next Topic:Adding context sensitive Help
Current Time: Fri May 24 05:39:05 EDT 2013
Powered by FUDForum. Page generated in 0.02181 seconds
