| Questions about debugging on target via Target Management vs typical CDT [message #698577] |
Tue, 19 July 2011 14:12  |
Jusctsch Messages: 22 Registered: July 2011 |
Junior Member |
Hello all,
I have a setup which would work great for gdbserver.
I would like to keep my sources local, my symbol file local. The target is currently running a stripped binary of my intended-to-debug program.
However, the platform doesn't currently have a thread-conscious gdbserver (FreeBSD), so we can throw out that idea. Also, there is no UI on the target system and I would like to debug it via a UI such as Eclipse.
So, it would seem that the best solution would be to attempt a gdb session over ssh, and pump that into the Eclipse UI. If only this was simple; there are at least 3 methods AFAIK in which I could do this, being the following:
(in the debug configuration tab)
C/C++ Attach to Application
GDB Hardware Debugger
Target Communication Framework (? purpose of posting here)
My question is then, is this something that is still in the area of RSE/TM? Should I be using the 'Target Communication Framework' or should I make do with the above two.
Any thoughts on which of them is closer to my situation, or are they functionally equivalent?
Thanks-!
*Edit*
For those stumbling on this question looking for answers, this may provide something...
htt p://w w w.slideshare.net/kepler2/eclipse-con-talk2273
[Updated on: Wed, 20 July 2011 11:33] Report message to a moderator
FUDForum. Page generated in 0.01530 seconds
