| how to make AND operation between two conditions in EmfFacet [message #707125] |
Mon, 01 August 2011 05:13  |
barthelemy Messages: 7 Registered: May 2011 |
Junior Member |
Hi everybody,
currently, i'm able to precise with condition a value of a customfeature in uiCustom file.I would like to know how i can associate several conditions to the same value or i would like to know, how i can do AND operation between my conditions.
thanks for your answers
| Re: how to make AND operation between two conditions in EmfFacet [message #708219 is a reply to message #707125] |
Tue, 02 August 2011 11:28  |
Fabien Giquel Messages: 134 Registered: July 2009 |
Hi Barthelemy,
thanks for your interest in EMF Facet features.
Unfortunately you may attach only one Query condition to one conditional feature value(FeatureValueCase.condition multiplicity is [1] in customization metamodel).
I do not know if it may work in your use case : as a work around you may inverse conditions. Considering A AND B = NOT(NOT A OR NOT B), you may specify (NOT A) as a first FeatureValueCase and (NOT B) as a second one with some "default/blank" value, and put your wished feature value (for A AND B) directly on the feature ("edit feature value..." button).
Else, you will have to write some agregation Query which calls your two leaf queries, and use it as a condition.
You are free to fill some bugzilla https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT.facet for asking the enhancement.
Fabien.
Fabien GIQUEL
R&D Engineer
Mia-Software
4, rue du Château de l'Eraudiere
44324 NANTES CEDEX 03
FUDForum. Page generated in 0.06393 seconds
