| ODA Data source causing NPE in org.eclipse.birt.report.designer.data.ui.dataset.DataSetBasePage [message #706110] |
Sat, 30 July 2011 17:48  |
Originally posted by: rbenjamin
I'm using Indigo.
I used the new plugin wizards to create two projects, and ODA Data
Source Designer and an ODA data source driver. This part seems to work
very well.
I've added the necessary implementation code to expose Cassandra CQL via
the two new plugins (above). The ODA classes created by the wizard for
the driver have been changed to act as facades for the Apache Cassandra
JDBC driver.
Next I created a basic Birt report project. I added the Cassandra CQL
data source in the Data Explorer tab.
Then I try to define a Data Set based on the data source.
I get an NPE, and for some reason I'm unable to debug through it. I
don't believe it's a Birt bug (but maybe). These Birt features have
been working well for some years.
I assume the problem must be with the new ODA data source I am
providing. However, as far as I can tell none of the Cassandra data
source code I wrote is actually accessed. At least the debugger never
stops in one of my classes.
I right click on "Data Sets" in the "Data Explorer" tab and pick "New
Data Set". The NPE occurs when clicking "Finish".
Any known issues with ODA data sources here? Any idea why Eclipse
cannot 'see' any of the Birt classes? The plugins are all there, and
starting etc... but Ctr+Shift+T (for example) can't find *any* of the
classes in any of the Birt plugins. I've never seen anything like this.
Any pointers appreciated... I'll provide any additional info if needed.
Thank You
Roy
!ENTRY org.eclipse.ui 4 0 2011-07-30 14:44:49.144
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.birt.report.designer.data.ui.dataset.DataSetBasePage.createDataSetODAV3(DataSetBasePage.java:902)
org.eclipse.birt.report.designer.data.ui.dataset.DataSetBasePage.createSelectedDataSet(DataSetBasePage.java:861)
org.eclipse.birt.report.designer.data.ui.dataset.DefaultDataSetWizard.performFinish(DefaultDataSetWizard.java:84)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
org.eclipse.birt.report.designer.data.ui.actions.NewDataSetAction.createNewDataSet(NewDataSetAction.java:193)
org.eclipse.birt.report.designer.data.ui.actions.NewDataSetAction.run(NewDataSetAction.java:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
FUDForum. Page generated in 0.01789 seconds
