Home » Modeling » OCL » [CompleteOCL] Problems with CompleteOCL editor
[CompleteOCL] Problems with CompleteOCL editor [message #686047] Tue, 21 June 2011 09:56 Go to next message
Ambros Morscher is currently offline Ambros Morscher
Hi all,
I'm using CompleteOCL to attach OCL constraints to my UML model.
When using the CompleteOCL editor i get several errors when trying to use packages or classes (contexts)from my uml model. I import my metamodel to the ocl file as follows:
import '../../RangeDB_cdm.uml'
package MonitoringData::MonitoringGroups
context GRPK
--Value constraint String--
	inv checkGRPKNameValue :
	let name :String = self.GRPK_GNAME in
	 	name.size()<=12
endpackage
The editor behaves really buggy. Did I do something wrong when importing my metamodel? Has anyone a good example how to use CompleteOCL in combination with UML?
Is there a problem with nested packages? Because the editor is not able to resolve classes in the package like in my example GRPK.
Thanks Ambros
icon4.gif  Re: [CompleteOCL] Problems with CompleteOCL editor [message #703259 is a reply to message #686047] Wed, 27 July 2011 07:10 Go to previous messageGo to next message
This is a very important request. And i am really looking forward to get some answers.
Is the question not clear. If this is the case please let me know so that i can clarify.
Re: [CompleteOCL] Problems with CompleteOCL editor [message #703519 is a reply to message #703259] Wed, 27 July 2011 12:38 Go to previous messageGo to next message
Hi Ambros
The question is far from clear.
My newsgroup reader shows no previous message, so what is the question?
Ed Willink
> get some answers. Is the question not clear. If this is the case
Re: [CompleteOCL] Problems with CompleteOCL editor [message #704188 is a reply to message #703519] Thu, 28 July 2011 07:12 Go to previous messageGo to next message
Posted my problem/question again
context GRPK
	 	name.size()<=12
endpackage
Re: [CompleteOCL] Problems with CompleteOCL editor [message #704431 is a reply to message #704188] Thu, 28 July 2011 11:59 Go to previous message
Hi Ambros
The addition of UML editing support was a late addition just in time for
Indigo. It uses a double translation from UML to Ecore and then to Pivot
even though a direct UML to Pivot should be much easier since the Pivot
is UML-derived. Unfortunately the profile support is not yet present so
via Ecore was a better option than no UML support.
I'm not entirely surprised that there are problems. Sorry. Can you raise
Bugzillas with example files so that I cannot forget about the problems.
Ed Willink
> context GRPK
> name.size()<=12
> endpackage
Previous Topic:Error while testing OCLinEcore Tutorial
Next Topic:oclIsTypeOf error with OCLinEcore
Current Time: Wed May 22 10:26:41 EDT 2013
Powered by FUDForum. Page generated in 0.01731 seconds
