Home » Language IDEs » AJDT » Compile error
Compile error [message #70368] Sun, 05 August 2007 03:06 Go to next message
Eclipse User
Originally posted by: stepper.sympedia.de
I'm trying to make a method intertype dclaration for a subtype of
ArrayList<E> but I can't get it running.
I get a compiler excpetion:
java.lang.ClassCastException
org.aspectj.weaver.BoundedReferenceType.parameterize(Bounded ReferenceType.java:64)
at org.aspectj.weaver.ResolvedType.parameterize(ResolvedType.ja va:1884)
org.aspectj.weaver.ResolvedMemberImpl.parameterize(ResolvedM emberImpl.java:682)
org.aspectj.weaver.ResolvedMemberImpl.parameterizedWith(Reso lvedMemberImpl.java:644)
org.aspectj.weaver.NewMethodTypeMunger.parameterizedFor(NewM ethodTypeMunger.jav
Compile error: ClassCastException thrown:
org.aspectj.weaver.UnresolvedTypeVariableReferenceType cannot be cast to
org.aspectj.weaver.ReferenceType
for the following decl:
public boolean EcoreEList<T>.addAll(Collection<? extends T> collection)
return super.addAll(collection);
When I remove the <T> from the target type spec:
public boolean EcoreEList.addAll(Collection<? extends T> collection)
the compiler doesn't say a word but at rntime when calling addAll(...)
on EcoreElist I get the following exception:
!ENTRY org.eclipse.ui 4 0 2007-08-04 20:28:28.625
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.VerifyError: (class: org/eclipse/emf/ecore/util/EcoreEList,
method: ajc$superDispatch$org_eclipse_emf_ecore_util_EcoreEList$addA ll
signature: (ILjava/util/Collection;)Z) Illegal use of nonvirtual
function call
org.eclipse.emf.ecore.impl.EPackageImpl.getEClassifiers(EPac kageImpl.java:394)
org.eclipse.emf.ecore.impl.EPackageImpl.createEClass(EPackag eImpl.java:721)
org.eclipse.emf.ecore.impl.EcorePackageImpl.createPackageCon tents(EcorePackageImpl.java:1923)
org.eclipse.emf.ecore.impl.EcorePackageImpl.init(EcorePackag eImpl.java:489)
at org.eclipse.emf.ecore.EcorePackage.<clinit>(EcorePackage.java:63)
org.eclipse.emf.internal.cdo.util.ModelUtil.addModelInfos(Mo delUtil.java:291)
org.eclipse.emf.internal.cdo.CDOSessionPackageManager.<init >(CDOSessionPackageManager.java:37)
org.eclipse.emf.internal.cdo.CDOSessionImpl.<init>(CDOSessionImpl.java:112)
org.eclipse.emf.internal.cdo.CDOSessionFactory.create(CDOSes sionFactory.java:38)
org.eclipse.emf.internal.cdo.CDOSessionFactory.create(CDOSes sionFactory.java:1)
org.eclipse.net4j.internal.util.container.ManagedContainer.c reateElement(ManagedContainer.java:394)
org.eclipse.net4j.internal.util.container.ManagedContainer.g etElement(ManagedContainer.java:248)
org.eclipse.emf.cdo.internal.ui.views.CDOSessionsView$OpenSe ssionAction.doRun(CDOSessionsView.java:89)
at org.eclipse.net4j.ui.actions.SafeAction.run(SafeAction.java: 50)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:443)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
I installed the AJDT from Europa update site.
Cheers
/Eike
Re: Compile error [message #70389 is a reply to message #70368] Sun, 05 August 2007 03:15 Go to previous message
Eclipse User
Minor correction:
It's a subtype of AbstractList<E> not of ArrayList<E>
Another observation:
gives a compile problem at <T>
It works with <E> so somehow the compiler seems to look for the type
parameter in the target type and not the target type spec of my declaration.
Is that correct?
But if, then why doesn't it work at runtme?
Cheers
/Eike
Eike Stepper schrieb:
> at
> at
> at
> at
> to org.aspectj.weaver.ReferenceType
> !STACK 0
> function call
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Cheers
> /Eike
Re: Compile error [message #596291 is a reply to message #70368] Sun, 05 August 2007 03:15 Go to previous message
Eike Stepper is currently offline Eike Stepper
Minor correction:
Is that correct?
Cheers
/Eike
> at
> at
> at
> at
> !STACK 0
> function call
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Cheers
> /Eike
Previous Topic:Compile error
Next Topic:Another internal NPE
Current Time: Fri May 24 03:35:14 EDT 2013
Powered by FUDForum. Page generated in 0.02089 seconds
