Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » TCL - Step Into not working while debugging
TCL - Step Into not working while debugging [message #703548] Wed, 27 July 2011 13:19
Frank is currently offline Frank
Under Eclipse 3.7, doing some TCL work with the Active State Komodo Debug Engine, "Step Into" while debugging doesn't work.
For example:
File1:
puts "Starting"
utilLibTest::testDebugStepInto
puts "Done"
File2:
proc utilLibTest::testDebugStepInto { } {
	puts "Line 1"
	puts "Line 2"
In File1, if I try "step into" on the utilLibTest::testDebugStepInto, it simply puts me on the 'puts "Done"' line. The proc ran as I see the "Line 1" and "Line 2" output. Also, if I put a breakpoint on utilLibTest::testDebugStepInto itself, it will correctly stop there. I just can't step in.
The folks at ActiveState verified this works fine in the debug engine using Komodo as the IDE.
Any thoughts?
Frank
Previous Topic:[BUILD] S-3.0RC4-201106091504
Next Topic:Debug Perspective not triggering on program suspend
Current Time: Wed May 22 18:42:04 EDT 2013
Powered by FUDForum. Page generated in 0.01524 seconds
