Home » Modeling » OCL » Error while testing OCLinEcore Tutorial(OCL ecore tutorial)
Error while testing OCLinEcore Tutorial [message #701944] Mon, 25 July 2011 15:04 Go to next message
fafanellu  is currently offline fafanellu
Member
I'm trying to do the tutorial "Working with OCLinEcore" (I use Helios Service Release 2)
I managed to create the library metamodel, then the dynamic model instance, which can be successfully validated.
But, after adding the simple constraint "invariant SufficientCopies", when I try to re-validate, there is an error, but unfortunately not about the violation of the constraint.
Here is what I get : An exception occurred while delegating evaluation of the 'SufficientCopies' constraint on 'Book b2': null
any idea about what this is ?
thanks for helping
bye
[Updated on: Mon, 25 July 2011 15:06]
Report message to a moderator
Re: Error while testing OCLinEcore Tutorial [message #701947 is a reply to message #701944] Mon, 25 July 2011 15:11 Go to previous message
Member
that's ok, I re-created my metamodel and it seems to work now, although I don't understand why...thanks
Previous Topic:Accessing Message sequence number
Next Topic:[CompleteOCL] Problems with CompleteOCL editor
Current Time: Fri May 24 04:03:29 EDT 2013
Powered by FUDForum. Page generated in 0.01597 seconds
