Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo]issue with migration to version 0.1.0.v201107070719
[Texo]issue with migration to version 0.1.0.v201107070719 [message #699986] Fri, 22 July 2011 12:50 Go to next message
Aurelien Pupier is currently offline Aurelien Pupier
I try to upgrade to last EMF Texo release 0.1.0.v201107070719
It seems that org.eclipse.emf.texo.generator.WorkFlowStarter no more exists.
By what it is replaced?
I found this commit that remove the file: http://dev.eclipse.org/mhonarc/lists/texo-commit/msg00492.html
Aurélien Pupier - BonitaSoft S.A.
My blog
My company Eclipse-related blog
Re: [Texo]issue with migration to version 0.1.0.v201107070719 [message #700120 is a reply to message #699986] Fri, 22 July 2011 16:43 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Yes I completely removed the usage of MWE as the workflow was very simple and MWE did not provide any advantage. Can you
tell me what problems you have?
gr. Martin
On 07/22/2011 06:50 PM, Aurelien Pupier wrote:
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Texo]issue with migration to version 0.1.0.v201107070719 [message #700325 is a reply to message #700120] Sat, 23 July 2011 03:40 Go to previous messageGo to next message
we were using it to generate model code.
final WorkFlowStarter wfs = new WorkFlowStarter();
wfs.generateModelCode(project.getName(), ePackages, modelController, genOutputFolder);
I suppose that I need to call the generation from other class now. Can you kindly indicate it to me? or point me to the right documentation, please?
My blog
Re: [Texo]issue with migration to version 0.1.0.v201107070719 [message #700345 is a reply to message #700325] Sat, 23 July 2011 03:54 Go to previous messageGo to next message
Hi Aurelien,
This code is what I use in the testcases:
final ModelController modelController = new ModelController();
modelController.setEPackages(ePackages);
modelController.annotate(new ArrayList<ModelAnnotator>());
final ArtifactGenerator artifactGenerator = new ArtifactGenerator();
artifactGenerator.setModelController(modelController);
artifactGenerator.setOutputFolder("src-test-gen"); //$NON-NLS-1$
artifactGenerator.setProjectName(TEST_MODEL_PROJECT);
artifactGenerator.run();
Where ArtifactGenerator is located in this package: org.eclipse.emf.texo.generator
Does this help?
gr. Martin
On 07/23/2011 09:40 AM, Aurelien Pupier wrote:
The Netherlands
Re: [Texo]issue with migration to version 0.1.0.v201107070719 [message #700476 is a reply to message #700345] Sat, 23 July 2011 10:12 Go to previous message
it seems to be exactly what I need.
Thank you very much for your responsiveness and accurate answers.
My blog
Previous Topic:[EMFCompare] Comparison of unordered lists
Next Topic:Is the EMF search project still active?
Current Time: Fri May 24 01:02:06 EDT 2013
Powered by FUDForum. Page generated in 0.01995 seconds
