Home » Eclipse Projects » BIRT » Dynamic prefill of parameter
Dynamic prefill of parameter [message #366285] Fri, 12 December 2008 11:44 Go to next message
Don Taggart is currently offline Don Taggart
I've looked around the message board quite a bit and haven't found what
I'm looking for.
I'm using a text box as a date entry field (calendar control would be nice
:-) and I'd like to prefill it with todays date. That's a pretty easy
javascript thing, but there is no expression builder on the parameter
default entry area.
Any decent ideas?
Don
Re: Dynamic prefill of parameter [message #366287 is a reply to message #366285] Fri, 12 December 2008 14:33 Go to previous messageGo to next message
Eclipse User
Originally posted by: mwilliams.birt-exchange.com
Hi Don,
Check out these forum posts:
http://www.birt-exchange.com/forum/designing-birt-reports/12 699-default-parameter-value.html?WT.mc_id=10021
-AND-
http://www.birt-exchange.com/forum/designing-birt-reports/11 498-birt-datepicker-plzzzzzzzzzzz.html?WT.mc_id=10021
These may help with your issue.
Michael Williams
Birt-Exchange Contributor
> I'm looking for.
> default entry area.
> Any decent ideas?
> Don
Re: Dynamic prefill of parameter [message #699091 is a reply to message #366287] Wed, 20 July 2011 15:54 Go to previous messageGo to next message
Rory  is currently offline Rory
these links seem to be broken. Is there anyway you can repost them Mike?
Re: Dynamic prefill of parameter [message #699128 is a reply to message #699091] Wed, 20 July 2011 18:02 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
Here they are:
http://www.birt-exchange.org/org/forum/index.php/topic/12699-default-parameter-value/
http://www.birt-exchange.org/org/forum/index.php/topic/11498-birt-datepicker-plzzzzzzzzzzz/
Jason Weathersby
BIRT Exchange
Previous Topic:how to calculate uptime as java expression
Next Topic:BIRT RCP designer - Section 508 information
Current Time: Thu May 23 05:10:21 EDT 2013
Powered by FUDForum. Page generated in 0.01595 seconds
