| Birt and Hive [message #692511] |
Mon, 04 July 2011 11:59  |
Wouter de Bie Messages: 2 Registered: July 2011 |
Junior Member |
Hi all,
Today I stumbled upon BIRT and saw that the 3.7 release is able to communicate with Hive 0.7.0 (clouderas cdh3u0 release). I've tried setting this up, but I have been unlucky so far. When I setup a data source select hive and add the jars that are shown on the "Notable 3.7" page, testing the connection doesn't give any feedback. When I finish creating the datasource and want to add a data set, clicking Finish does nothing.
I have a hive server running on port 10000 and with a commandline tool, I'm able to query hive tables.
Does anyone know where I can look for errors or have a set of hive jars that are supposed to work?
Wouter
| Re: Birt and Hive [message #698800 is a reply to message #692511] |
Wed, 20 July 2011 04:45  |
al Messages: 3 Registered: July 2011 |
Junior Member |
Hi all,
I am currently trying to connect Birt 3.7 to Hive 0.7.0 with the new plugin, but I am experiencing troubles as well. My configuration is a windows 7 on which I run Birt 3.7 and a virtual machine with the pre-packed cloudera : CDH3u0 on ubuntu 10.10. The VM is accessible at 192.168.18.129 from my local and I can run Hue beeswax from both the VM and windows.
The only documentation I found on this matter is the Birt's new feature page..Here are the points where I am blocking:
- First the validation button in birt does not work, but it's no big deal..
- Then the lack of description regarding the syntax : I use "jdbc:hive://192.168.18.129:10000/default" but I can only assume it's correct.
- Regarding the id/pwd I use cloudera/cloudera as they are the one set for hive.
- The "Add file statement" is not very clear also, I didn't find any documentation on that point, so I tried several things such as "add file /user/hive/warehouse/sample_07/sample_07.csv" which seems to look like the print screen on Birt's new feature page...
So you would have understood that I cannot connect and the log only says :
!ENTRY org.eclipse.ui 4 0 2011-07-20 10:44:11.947
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.NoClassDefFoundError: org/slf4j/LoggerFactory
at org.apache.thrift.transport.TIOStreamTransport.<clinit>(TIOStreamTransport.java:38)
at org.apache.hadoop.hive.jdbc.HiveConnection.<init>(HiveConnection.java:100)
at org.apache.hadoop.hive.jdbc.HiveDriver.connect(HiveDriver.java:110)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager$WrappedDriver.connect(JDBCDriverManager.java:1159)
at java.sql.DriverManager.getConnection(Unknown Source)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doConnect(JDBCDriverManager.java:253)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getConnection(JDBCDriverManager.java:188)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.tryCreateConnection(JDBCDriverManager.java:728)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.testConnection(JDBCDriverManager.java:634)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.testConnection(DriverLoader.java:120)
at org.eclipse.birt.report.data.oda.hive.ui.profile.HiveSelectionPageHelper.testConnection(HiveSelectionPageHelper.java:410)
at org.eclipse.birt.report.data.oda.hive.ui.profile.HiveSelectionPageHelper.access$4(HiveSelectionPageHelper.java:398)
at org.eclipse.birt.report.data.oda.hive.ui.profile.HiveSelectionPageHelper$2.widgetSelected(HiveSelectionPageHelper.java:340)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.birt.report.designer.data.ui.actions.NewDataSourceAction.run(NewDataSourceAction.java:126)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.birt.report.designer.ui.rcp.DesignerApplication.run(DesignerApplication.java:38)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.ClassNotFoundException: org.slf4j.LoggerFactory
at org.eclipse.birt.core.framework.URLClassLoader.findClass1(URLClassLoader.java:188)
at org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClassLoader.java:156)
at org.eclipse.birt.core.framework.URLClassLoader$1.run(URLClassLoader.java:1)
at org.eclipse.birt.core.framework.URLClassLoader.findClass(URLClassLoader.java:151)
... 55 more
I hope someone was able to go further than me and take some time to explain how he managed to..
Thank you in advance,
Al
FUDForum. Page generated in 0.04265 seconds
