| Re: Help Wanted: Ranking Strategy for Subwords Completion Engine [message #690420 is a reply to message #689209] |
Wed, 29 June 2011 09:49   |
Johannes Lerch Messages: 18 Registered: February 2011 |
Junior Member |
I just integrated your latest contribution. You might have to search a little to find it, as i refactored a lot of stuff. I also added some tests and found some bugs. For example i think qgrams is symmetric and your implementation was not. I fixed those issues, but i would appreciate that you will take a look on that to verify that i didn't broke it.
The main classes of interest are now SubwordsRelevanceCalculator, QGramSimilarity and the corresponding test classes SubwordsRelevanceCalculatorTest, QGramSimilarityTest and ExpectedScoringsTest. As you can see your current approach matches my expectations. Nice job!
But can you give me more details on the weighting function? What was the intent of the factor 20 and why is the difference of the length of both strings relevant?
For all who want to test the current state: Get it from the head channel. I turned off the default java proposals and will check what it feels like to only have the subwords completion.
[Updated on: Thu, 30 June 2011 03:10] Report message to a moderator
| Re: Help Wanted: Ranking Strategy for Subwords Completion Engine [message #696053 is a reply to message #696040] |
Wed, 13 July 2011 03:43   |
Marcel Bruch Messages: 188 Registered: July 2009 |
Hi Pef,
we adapted some parts of your code. You find the latest version in the org.eclipse.recommmenders git repository. We came across an issue with relevance scoring since JDT does not support updating the relevance of a proposal. This is annoying and confusing when typing.
I'm not sure whether we can (yet) deliver the bigrams solution with that issue. I reported the issue here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=350991 JDT is yet not very responsive because of the upcoming Java7 release. But I hope we'll get a solution rather soon.
In the meanwhile it would be cool if you could install the latest version from HEAD update site and give it a try?
Best,
Marcel
tw: @MarcelBruch
tw: @Recommenders
FUDForum. Page generated in 0.01841 seconds
