Home » Eclipse Projects » Eclipse Platform » Find the Configuration directory
Find the Configuration directory [message #698104] Mon, 18 July 2011 15:11 Go to next message
Yigal Spinner is currently offline Yigal Spinner
I want to find the "configuration directory" (the location where config.ini reside in - usually it is the <eclipse install>/configuration). Platform.getConfigurationLocation gives the current plugin in the .metadata area. When eclipse is run with the option "-configuration" and the configuration changes, I would like the find it while the plugin starts.
What is the best command to do so?
Yigal
[Updated on: Mon, 18 July 2011 15:56]
Report message to a moderator
Re: Find the Configuration directory [message #698400 is a reply to message #698104] Tue, 19 July 2011 08:29 Go to previous message
Paul Webster is currently offline Paul Webster
There's a system property, osgi.configuration.area. If you go to Help>About>Installation Details>Configuration you can see the list of properties that are set in your running instance.
Also check out http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Freference%2Fmisc%2Fruntime-options.html for a description of most properties.
PW
Previous Topic:Intermittent ClassCastException in PolicyHandler
Next Topic:How to get an instance of the IWorkbenchPart?
Current Time: Sat May 25 01:10:24 EDT 2013
Powered by FUDForum. Page generated in 0.18678 seconds
