| Linking to Help Content from Cheat Sheet [message #697157] |
Fri, 15 July 2011 13:01  |
Rich Payton Messages: 21 Registered: June 2011 |
Junior Member |
As I create Cheat Sheets I try to link to the related help content whenever possible.
The way I retrieve the Help Content link is by:
1. Navigating to the Help page
2. Hovering over the link in the TOC
3. Copying the link
I then paste this link into the Cheat Sheet Editor in the Help area after choosing the type to be "Help Document Link".
There is a problem though the next time I launch Eclipse; the port has changed. Here is an example of the link I copied:
http://127.0.0.1:59185/help/topic/com.tsccos.rwb.vstrp.reference/doc/milestone/7/MS7-Section8.pdf
Is there a permanent link?
If I use the Content ID instead will I avoid this problem?
Can I insert the port variable into the Cheat Sheet so that the link will change to have the currently active port?
Is this problem a result of having a pdf file as the help document?
FUDForum. Page generated in 0.01830 seconds
