Home » Eclipse Projects » Rich Client Platform (RCP) » how to define enabledwhen of a self instantiated command ?
how to define enabledwhen of a self instantiated command ? [message #695153] Mon, 11 July 2011 02:14 Go to next message
heaad  is currently offline heaad
hi,
I define a coolbar in my view using this code :
// define a CommandContributionItem
IWorkbenchWindow window = getSite().getWorkbenchWindow() ;
CommandContributionItemParameter p = new CommandContributionItemParameter(
window, "",
"myCommandID",
SWT.PUSH);
CommandContributionItem contributionItem = new CommandContributionItem( p );
// I define coolbar in my view
CoolBar coolBar = new CoolBar( coolBarContainer, SWT.FLAT );
final IToolBarManager toolbar = new ToolBarManager(SWT.FLAT | SWT.RIGHT);
// add my CommandContributionItem to the toolbar
toolbar.add( contributionItem ) ;
ToolBarContributionItem toolBarContributionItem = new ToolBarContributionItem( toolbar, "model") ;
toolBarContributionItem.fill(coolBar, 0) ;
In the same view ,there is a TreeViewer , the command should be enabled if and only if a certain type of node of the TreeViewer is selected.
how to define the enabledwhen of the command ?
thanks!
[Updated on: Mon, 11 July 2011 02:18]
Report message to a moderator
Re: how to define enabledwhen of a self instantiated command ? [message #698069 is a reply to message #695153] Mon, 18 July 2011 13:58 Go to previous message
Paul Webster is currently offline Paul Webster
Where is your handler defined for that command? In the plugin.xml, it's org.eclipse.ui.handlers that defines an enabledWhen clause for a handler. If it was activated programmatically in your view, it's your handler that contols its enabled state.
PW
Previous Topic:Key binding with command framework in a dialog
Next Topic:handle EditorActions
Current Time: Fri May 24 22:00:28 EDT 2013
Powered by FUDForum. Page generated in 0.01474 seconds
