Home » Eclipse Projects » BIRT » Java and beforeOpen: stop birt execution
Java and beforeOpen: stop birt execution [message #517958] Tue, 02 March 2010 05:40 Go to next message
Nicola is currently offline Nicola
how can I stop birt from continuing its execution in a beforeOpen method?
What command should be called (if any)?
public void beforeOpen(IDataSourceInstance dataSource, IReportContext
reportContext) throws ScriptException {
if (hasPermission(reportContext)) {
// show report
super.beforeOpen(dataSource, reportContext);
} else {
// Stop BIRT from continuing
thank you
Nicola
Re: Java and beforeOpen: stop birt execution [message #517995 is a reply to message #517958] Tue, 02 March 2010 07:08 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Nicola,
Another approach would be to do this in the beforeFactory and just drop
the report items. Then you could display a message to the user with a
BIRT label report item.
Jason
nicola wrote:
> @Override
> // show report
> } else {
> thank you
> Nicola
Jason Weathersby
BIRT Exchange
Re: Java and beforeOpen: stop birt execution [message #518000 is a reply to message #517995] Tue, 02 March 2010 12:42 Go to previous messageGo to next message
thank you for the reply.
Is there an example of code?
Nicola
Jason Weathersby ha scritto:
> Nicola,
> Jason
> nicola wrote:
>> @Override
>> // show report
>> } else {
>> thank you
>> Nicola
Re: Java and beforeOpen: stop birt execution [message #518014 is a reply to message #518000] Tue, 02 March 2010 13:04 Go to previous messageGo to next message
Nicola,
In script it would be something like:
reportContext.getDesignHandle().findElement("mytable").drop();
Just name the table "mytable" in its general properties. You could then
add a label that says "You do not have permission to view this report".
and drop it if they do have permission.
Jason
nicola wrote:
> Nicola
>> Nicola,
>> Jason
>> nicola wrote:
>>> Hi,
>>> @Override
>>> // show report
>>> } else {
>>> thank you
>>> Nicola
Jason Weathersby
BIRT Exchange
Re: Java and beforeOpen: stop birt execution [message #531518 is a reply to message #518014] Wed, 05 May 2010 06:02 Go to previous messageGo to next message
is there a way to drop the source before doing any query?
I have my datasource defined in a library.
I named it and try the code you suggested, but with no results.
Am I wrong or there's a problem with dropping a datasource defined in a
library?
Thank you,
Nicola
> Nicola,
> Jason
> nicola wrote:
>> Regards,
>> Nicola
>>> Nicola,
>>> Jason
>>> nicola wrote:
>>>> Hi,
>>>> method?
>>>> @Override
>>>> // show report
>>>> } else {
>>>> thank you
>>>> Nicola
Re: Java and beforeOpen: stop birt execution [message #531691 is a reply to message #531518] Wed, 05 May 2010 15:07 Go to previous messageGo to next message
I assume you named it in the library. If your script is in the report
it does not have access to the name. So do something like:
//Get the first datasource and drop it
reportContext.getDesignHandle().getDataSources().get(0).drop ();
Jason
On 5/5/2010 6:02 AM, nicola wrote:
> library?
> Thank you,
> Nicola
>> Nicola,
>> Jason
>> nicola wrote:
>>> Hi,
>>> Regards,
>>> Nicola
>>>> Nicola,
>>>> Jason
>>>> nicola wrote:
>>>>> Hi,
>>>>> method?
>>>>> @Override
>>>>> // show report
>>>>> } else {
>>>>> thank you
>>>>> Nicola
Jason Weathersby
BIRT Exchange
Re: Java and beforeOpen: stop birt execution [message #538265 is a reply to message #531691] Mon, 07 June 2010 03:20 Go to previous messageGo to next message
Hi Jason,
this solution does not work.
Nothing happens and the report is shown.
Nicola
> Jason
>> library?
>> Thank you,
>> Nicola
>>> Nicola,
>>> report".
>>> Jason
>>> nicola wrote:
>>>> Hi,
>>>> Regards,
>>>> Nicola
>>>>> Nicola,
>>>>> drop
>>>>> Jason
>>>>> nicola wrote:
>>>>>> Hi,
>>>>>> method?
>>>>>> @Override
>>>>>> // show report
>>>>>> } else {
>>>>>> thank you
>>>>>> Nicola
Re: Java and beforeOpen: stop birt execution [message #538399 is a reply to message #538265] Mon, 07 June 2010 10:47 Go to previous messageGo to next message
You may need to change the index number (ie get(0) to get(1)) depending
on what datasource it is. You also may need to drop the dataset.
Jason
On 6/7/2010 3:20 AM, nicola wrote:
> Hi Jason,
> Nicola
>> Jason
>>> Hi,
>>> library?
>>> Thank you,
>>> Nicola
>>>> Nicola,
>>>> report".
>>>> Jason
>>>> nicola wrote:
>>>>> Hi,
>>>>> Regards,
>>>>> Nicola
>>>>>> Nicola,
>>>>>> drop
>>>>>> Jason
>>>>>> nicola wrote:
>>>>>>> Hi,
>>>>>>> method?
>>>>>>> @Override
>>>>>>> // show report
>>>>>>> } else {
>>>>>>> thank you
>>>>>>> Nicola
Jason Weathersby
BIRT Exchange
Re: Java and beforeOpen: stop birt execution [message #696559 is a reply to message #538399] Thu, 14 July 2011 05:49 Go to previous messageGo to next message
arlene86  is currently offline arlene86
Hi...
I need some help here...
i put below codes to my beforeFactory event :
if (params["name"].value == null) {
javax.swing.JOptionPane.showMessageDialog(null,"ALERT", "ALERT",
javax.swing.JOptionPane.ERROR_MESSAGE);
The message appear when i put null for my parameter input. But, i want report stop from continue running after i click "OK" button on my message dialog.Can anyone help me...
thanks,
Arlene
[Updated on: Thu, 14 July 2011 05:52]
Report message to a moderator
Re: Java and beforeOpen: stop birt execution [message #696692 is a reply to message #696559] Thu, 14 July 2011 11:53 Go to previous messageGo to next message
sam va is currently offline sam va
I have a similar requirement.
If the number of data rows is more than 10000 records, the report execution should STOP. There will not be any report output.
Any pointers will be helpful.
Using BIRT 2.6.2
Re: Java and beforeOpen: stop birt execution [message #696694 is a reply to message #696692] Thu, 14 July 2011 12:04 Go to previous messageGo to next message
Can I throw a java exception.
if (row > 10000)
throw new EngineException()
I mean call a java class which just throws this exception
[Updated on: Thu, 14 July 2011 12:07]
Re: Java and beforeOpen: stop birt execution [message #698041 is a reply to message #696694] Mon, 18 July 2011 12:45 Go to previous message
There is a way to cancel the task but this will cause a very generic
exception. Is forwarding the request an option?
Jason
> if (row > 10000)
Jason Weathersby
BIRT Exchange
Previous Topic:Birt 404 and JDBC error
Next Topic:birt.ini
Current Time: Sat May 18 12:42:02 EDT 2013
Powered by FUDForum. Page generated in 0.02123 seconds
