Home » Eclipse Projects » BIRT » Birt 404 and JDBC error
Birt 404 and JDBC error [message #697161] Fri, 15 July 2011 13:12 Go to next message
Marcelo is currently offline Marcelo
Hi folks!
Well, i'm doing some fixes on an old system and never worked with Birt before.
Here is what is happening:
When i try to generate some reports it gives me a 404 Not Found and on JBoss log i got the following error message:
16:13:54,156 ERROR [STDERR] 14/07/2011 16:13:54 org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager loadDriverExtensions
INFO: Found JDBC driverinfo extension: driverClass=org.apache.derby.jdbc.EmbeddedDriver, connectionFactory=null
INFO: Found JDBC driverinfo extension: driverClass=org.eclipse.birt.report.data.oda.sampledb.Driver, connectionFactory=org.eclipse.birt.report.data.oda.sampledb.SampleDBJDBCConnect
ionFactory
I did a lot of research and got no results.
Try to configure the right JDBC Driver just as the documentation says, something like that: (i cannot post links yet =( ).
Also tryed a lot of alternatives, but no even a signal =( .
Any hints? I sware i tryed everything and did a lot of research before posting here.
Thanks a lot!
[Updated on: Fri, 15 July 2011 13:12]
Report message to a moderator
Re: Birt 404 and JDBC error [message #697186 is a reply to message #697161] Fri, 15 July 2011 14:08 Go to previous messageGo to next message
Michael Williams is currently offline Michael Williams
What steps are you following to deploy to JBoss? Were you able to access the viewer, but just not run reports? Is there any more to the error in the log file?
Michael
BIRT Evangelist on
http://www.birt-exchange.org
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Birt 404 and JDBC error [message #697197 is a reply to message #697186] Fri, 15 July 2011 14:39 Go to previous messageGo to next message
Actualy it was working before (they said...) and o don't know exactly how it is deployed since it has an automated.
There is no more erros, only that one (about jdbc).
What should i be aware on deploying a Birt application?
Some "hidden" important tasks, i don't know how to proceed.
Thanks!!
Re: Birt 404 and JDBC error [message #698006 is a reply to message #697197] Mon, 18 July 2011 11:01 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
Marcelo,
What version of BIRT are you using? The deployment for JBoss is
described on the BIRT
website:http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php#jboss
The only other step is to add your jdbc driver to the web-inf/lib
directory of the webapp.
Jason
> Thanks!!
Jason Weathersby
BIRT Exchange
Previous Topic:IOException with the image in BIRT 2.6.1
Next Topic:Java and beforeOpen: stop birt execution
Current Time: Sat May 25 21:40:18 EDT 2013
Powered by FUDForum. Page generated in 0.01792 seconds
