Home » Eclipse Projects » EPF » EPF Composer - Activity Diagram Editor fail to open
EPF Composer - Activity Diagram Editor fail to open [message #599053] Tue, 12 January 2010 21:51 Go to next message
Yeu Wen Mak is currently offline Yeu Wen Mak
Can someone let me know why I am unable to open the activity diagram editor when I am working in my own Method Library? When I switch to EPF Practice library, I am able to open the same diagram editor, by right-clicking a delivery process or activity and selecting Open Activity Diagram.
What possibly could be the differences between EPF Practice library and my self-defined library?
Any log files I can check?
I am using Eclipse Process Framework Composer Version: 1.5.0.4 on Windows.
Thank you for your help.
regards,
yeuwen
Re: EPF Composer - Activity Diagram Editor fail to open [message #599060 is a reply to message #599053] Wed, 13 January 2010 00:43 Go to previous messageGo to next message
An update to my problem posted earlier.
What is interesting is that when I import my Method Plug-in into EPL Practice 1.5.0.1 library, I am able to open the activity diagram editor in the process editor of my own process. My method plug-in has absolutely no dependencies on EPL Practice library.
Therefore, I can only conclude that something in the EPL Practice library is needed to open this Activity Diagram editor, a resource perhaps.
How can I isolate this dependency so that my method plug-in can exist independently of EPL Practice library?
Thanks.
yeuwen
Re: EPF Composer - Activity Diagram Editor fail to open [message #599067 is a reply to message #599060] Wed, 13 January 2010 20:46 Go to previous messageGo to next message
Also, I found out that diagrams that belong to a plug-in is not exported together with the plug-in (at least in xml format) because when I import that plug-in into another library, a pop-up appears asking if I want to create a new diagram whenever I attempt to open the diagram editor.
Please help.
Re: EPF Composer - Activity Diagram Editor fail to open [message #676733 is a reply to message #599067] Mon, 06 June 2011 07:18 Go to previous messageGo to next message
No real name is currently offline No real name
I am also not able to open activity diagram editor in epf. It was working fine, but suddenly it stopped appearing.
Not sure what went wrong.
Any help is appreciated.
Re: EPF Composer - Activity Diagram Editor fail to open [message #697798 is a reply to message #599053] Mon, 18 July 2011 00:45 Go to previous message
Vladimir  is currently offline Vladimir
I don't know what caused the problem but Ï've found that you need to remove the folder "workspace...". By this new workspace is created and then you can open any diagram.
Vladimir
Previous Topic:About Getting task from XMI files
Next Topic:EPF XMI files to XHTML
Current Time: Mon May 20 04:36:48 EDT 2013
Powered by FUDForum. Page generated in 0.08825 seconds
