Home » Eclipse Projects » Web Tools Project (WTP) » setting org.eclipse.wst.xsl.jaxp.launching.ATTR_TRANSFORMER_FACTORY in the xsl launch configuration(I suspect a bug in eclipse)
setting org.eclipse.wst.xsl.jaxp.launching.ATTR_TRANSFORMER_FACTORY in the xsl launch configuration [message #651599] Mon, 31 January 2011 15:11 Go to next message
Cornelia Davis is currently offline Cornelia Davis
I am using Galileo with WTP for editing xml, xslt and applying xslt transformations. Recently I had a need to use xslt 2.0 so obtained Saxon - in particular, from some other discussions individuals reported success with Saxon-b which I downloaded from http://saxon.sourceforge.net/.
I've installed the Saxon-B processor with Windows->Preferences->XML->XSL->Java Processors - adding a processor that points to the saxon9.jar file and then set up the run configuration for my transformation to use this processor. I get an error message that says:
Exception in thread "main" javax.xml.transform.TransformerFactoryConfigurationError: Provider com.icl.saxon.TransformerFactoryImpl not found
Of course this is not found because in the saxon9.jar the factory impl is in net.sf.saxon.TransformerFactoryImpl.
Looking at the launch configuration file that is created I see the following line:
<stringAttribute key="org.eclipse.wst.xsl.jaxp.launching.ATTR_TRANSFORMER_FACTORY " value="com.icl.saxon.TransformerFactoryImpl"/>
So where is eclipse getting that value? I've dug through the saxon9.jar file and in the META-INF/services/javax.xml.transform.TransformerFactory find the value
So why is eclipse still using the com.icl.saxon value and where the heck does it come from?
BTW, if I change the launch.xml file to read
<stringAttribute key="org.eclipse.wst.xsl.jaxp.launching.ATTR_TRANSFORMER_FACTORY " value="net.sf.saxon.TransformerFactoryImpl"/>
and restart eclipse then everything runs fine. Of course, any time I change the launch config in eclipse the bad value is written again.
Re: setting org.eclipse.wst.xsl.jaxp.launching.ATTR_TRANSFORMER_FACTORY in the xsl launch configurat [message #697588 is a reply to message #651599] Sun, 17 July 2011 06:13 Go to previous message
Alexey Morozov is currently offline Alexey Morozov
I found that Eclipse Saxon Plugin (shipped with my Linux Indigo distribution as plugins/org.eclipse.wst.xsl.saxon_1.0.200.v201103081922.jar) contains file plugin.xml with the following contents:
<?eclipse version="3.2"?>
<plugin>
<extension
point="org.eclipse.wst.xsl.jaxp.launching.processorType">
<processorType
attributeProperties="SaxonAttributes.properties"
id="org.eclipse.wst.xsl.saxon_1_0.processorType"
label="%processorType.label.1"
outputProperties="SaxonOutputProperties.properties">
<transformerFactory
factoryClass="com.icl.saxon.TransformerFactoryImpl"
name="%transformerFactorySaxon6">
</transformerFactory>
</processorType>
<processorType
id="org.eclipse.wst.xsl.saxon.processorType"
label="%processorType.label.0"
<transformerFactory
factoryClass="net.sf.saxon.TransformerFactoryImpl"
name="%transformerSaxonXSLT2">
</processorType>
</extension>
</plugin>
So, I guess, the problem is that incorrect processor type is chosen. As I have just figured, that happened because I chose Saxon (XSLT 1.0) in the properties of the processor upon creation. When I re-created the processor definition using appropriate processor type, everything got fixed.
[Updated on: Sun, 17 July 2011 06:22]
Report message to a moderator
Previous Topic:WTP XML Editor in a RCP Application
Next Topic:new context to template editor
Current Time: Wed May 22 11:29:17 EDT 2013
Powered by FUDForum. Page generated in 0.01539 seconds
