| Re: [EEF] No EEF component & view element created Single Valued Containment References [message #696796 is a reply to message #696611] |
Thu, 14 July 2011 15:48  |
Goulwen Le Fur Messages: 115 Registered: July 2009 |
Hi Nidhi, you're right for the moment no PropertiesEditionElement (or
ElementEditor) is created for the case single valued containment
reference. You can manually create a ElementEditor with a
AdvancedEObjectFlatComboViewer as representation and a
PropertiesEditionElement binding your reference and the newly created
ElementEditor.
Regards.
Goulwen Le Fur - goulwen.lefur@obeo.fr
Le 14/07/2011 13:58, Nidhi a écrit :
> I am using EEF to generate the UI corresponding to my ecore metamodel.
> However, for any single valued containment reference, there is no
> "Properties Edition Element" in the component as well as "Elememt
> Editor" created in the view. However, for multivalued containment
> references this is created.
> It would be really helpful to get some pointers.
> Thanks a lot in advance,
> Best Regards,
> Nidhi
FUDForum. Page generated in 0.04486 seconds
