Home » Eclipse Projects » Rich Client Platform (RCP) » View persistency in workbench
View persistency in workbench [message #695928] Tue, 12 July 2011 16:43 Go to next message
Jean Bovet is currently offline Jean Bovet
Member
I am facing a problem that is probably easy to solve. My application
needs to dynamically create the views in the perspective at each
startup, depending on some external configuration. The problem so far
is that the views are persisted in the workbench.xml so after the first
restart, the same views are re-created again and again. Is there a way
to tell the workbench to not store the view configuration (or to delete
is somehow on startup - I could delete the workbench.xml file but some
other information in there are useful)?
Thanks a lot,
Jean
Re: View persistency in workbench [message #696135 is a reply to message #695928] Wed, 13 July 2011 06:02 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
On 12.07.2011 22:43, Jean Bovet wrote:
> first restart, the same views are re-created again and again. Is there
> a way to tell the workbench to not store the view configuration (or to
> delete is somehow on startup - I could delete the workbench.xml file
> but some other information in there are useful)?
Try
org.eclipse.ui.application.IWorkbenchConfigurer.setSaveAndRestore(boolean).
Dani
> Thanks a lot,
> Jean
Re: View persistency in workbench [message #696326 is a reply to message #696135] Wed, 13 July 2011 12:11 Go to previous message
Member
Thanks, that's exactly what I'm looking for.
Jean
> Try org.eclipse.ui.application.IWorkbenchConfigurer.setSaveAndRestore(boolean).
> Dani
>> Thanks a lot,
>> Jean
Previous Topic:How can I create a texteditor with hyperlink support?
Next Topic:how to set the color of text in state line
Current Time: Sun May 19 01:57:30 EDT 2013
Powered by FUDForum. Page generated in 0.01669 seconds
